Old 03-10-2014, 07:40 AM   #239
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Originally Posted by tbrocato View Post
Running Toyota 0w20 right now and I love it! I think its better than eneos sustina 0w20 and Subaru 0w20. Those are the other two I have tried.
As in the factory oem supplied oil? What UOA did you run for comparisons between all the oils you have tried?
Old 03-10-2014, 08:17 AM   #240
frslee
Just drive it
Drives: 13' FR-S
Last time I went to walmart I found 0w20 in extended performance version. I thought it was pretty interesting to see those.
frslee is offline   Reply With Quote
Old 03-11-2014, 05:57 PM   #241
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
I have a great maintenance plan on my BRZ, do you know if my dealer would put fluids that I request in? I'd be happy to supply or even buy from them.
leicaboss is offline   Reply With Quote
Old 03-11-2014, 06:19 PM   #242
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I wouldn't trust any dealer to change my oil, but yeah they should use whatever oil you give them. Of course you have no way of really knowing...
Originally Posted by humfrz
I'm old and lazy
Old 03-11-2014, 07:06 PM   #243
PMok
Codename: Stitch
PMok's Avatar
The only way to answer that question is to ask your dealer.
For many years I would take my MR2 into the Toyota dealer and bring my own Mobil1 syn oil and ask them to use that instead of whatever oil they typically used. They were typically okay with that, and even charged me less for the oil change since I was providing my own oil. However I tended to stick around and would watch them as they did the oil change from outside the service bay, and at least once I caught the guy starting to pump regular oil into the car. I don't know if he just didn't read the directions in the work order, or was planning to steal the oil for himself, but I walked over there and told him to use the oil I provided. He apologized, and since he had already started pumping the regular oil in, had to drain the car again then he used my oil after.
Also this will probably make you hardcore Subie guys spit your coffee out or something, but the local Subie dealership that I go to here uses Mobil 1 synthetic 0W20.
I let them change my oil every 7500 miles to keep the warranty satisfied, but I change it at 3500 miles in between myself for additional peace of mind/care, using either Subie/Idemitsu or toyota 0W20 syn. Though as I am starting to go to the track more, I will probably be switching over to Redline 0W30 soon for a little more viscosity at high temps. I may also try Motul or go back to M1 in the future, not averse to trying different brands.
Old 03-11-2014, 09:35 PM   #244
OmarYasin
OmarYasin's Avatar
Did a oilchange lastnight im on eneos 0w20
Sent from my SGH-T599N using Tapatalk
OmarYasin is offline   Reply With Quote
Old 03-12-2014, 07:17 AM   #245
regal
Drives: Scion FR-S/Toyota Yaris
Smart move save you camshafts. Its a tossup with these cars higher weights saved the rod beardings, spec'd oil (0w20) saves the heads.
Did you get the Eneos Sustania?
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 03-12-2014, 10:11 AM   #246
bluesubie
Drives: 2004 Subaru Forester 2.5XT
I didn't spit my coffee out because the bad reputation that Mobil1 has among hardcore Subaru guys is from knuckleheads running the wrong viscosity for their application. Yes, modifying an STI to 400 whp and running M1 5W-30. M1 0W-40 is excellent for WRX's and STI's and M1 0W-20, and moreso the 5W-20, is excellent for the BRZ/FR-S.
For Red Line, you wouldn't need to go with 0W-30. Even their 5W-20 is more robust than most xW-30's (it has a very high HTHS and kinematic viscosity). The 0W-20 has an HTHS the same as some 5W-30's and the kinematic viscosity at 100C for both Red Line's is just below a 30 grade.
-Dennis
bluesubie is offline   Reply With Quote
Old 03-12-2014, 12:02 PM   #247
frs10
Drives: tezla
just dropped in 5.7 of toyota stock 0w-20... coming from sustina... lets see how this chapter goes...
frs10 is offline   Reply With Quote
Old 03-12-2014, 12:45 PM   #248
OmarYasin
OmarYasin's Avatar
Hmmmmm ill have to look at the label I thought the higher grades were sustina but most likely it is
Old 03-13-2014, 12:55 AM   #249
regal
That sustania claims to have advanced (obviously unmeasureable by a UOA) additives that my protect the rods and and have the rheology to flow thru the heads as the engineers intended. But damn that expensive oil.
This forum is huge and full of information, but the most important one oil pressure vs rpm logs. Amazing.
Mods:
Old 03-13-2014, 01:58 AM   #250
OmarYasin
OmarYasin's Avatar
Mine was 8 bucks a quart I got that napa hookup lol
Old 03-17-2014, 03:04 PM   #251
frs10
Drives: tezla
wow mine was around $15/qt
Old 03-17-2014, 03:13 PM   #252
OmarYasin
OmarYasin's Avatar
I work at napa autoparts so I bout nearly get it at store cost
