kidgogeta
Old 03-15-2014, 02:16 AM   #1653
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Originally Posted by TwoFourFive View Post
Can you post a picture really showing the wheel gap on pros?
This car made me fall in love with the Pro-Kit. The car is on 18's with a Pro-Kit.
http://www.gtspirit.com/2012/09/13/r...r=1&vid=792#tp
ericmpena is offline   Reply With Quote
Old 03-15-2014, 02:18 AM   #1654
TwoFourFive
TwoFourFive's Avatar
Drives: 13 HOT LAVA
That's sick
TwoFourFive is offline   Reply With Quote
The Following User Says Thank You to TwoFourFive For This Useful Post:
ericmpena (03-15-2014)
Old 03-15-2014, 02:20 AM   #1655
DCStorm
DCStorm's Avatar
Drives: 2013 FR-S (RIP), 2017 Toyota 86
Originally Posted by BlueDubbinTDI View Post
Here are the pics you requested (not staggered but you wanted to see the 8.75s in the front)! XXR 530's 18x8.75et33 all around on 225/40's with 5mm spacers in the rear
front:
rear:
Did you need any fender work done with that setup at your ride height? I assume your on coils.
DCStorm is offline   Reply With Quote
Old 03-15-2014, 09:33 AM   #1656
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Nope no both. I'm on RS-R Superdown springs. Basically Eibach sportline ride height.
Old 03-15-2014, 09:36 AM   #1657
BlueDubbinTDI
That's some serious rake...
Old 03-15-2014, 10:19 AM   #1658
dkrou351
dkrou351's Avatar
Drives: Scion FR-S
Anyone know what kind of tire pressure the 527s use? Or does it depend on the tire? Anyway, I'm trying to see if my stock tpms will work with these wheels.
Merica.
dkrou351 is offline   Reply With Quote
Old 03-15-2014, 11:52 AM   #1659
NinjaRxMan
NinjaRxMan's Avatar
Stock tpms will work with the 527s. That's what I did with my 527s. But air pressure depends on the tire (max psi is usually on sidewall).
Old 03-15-2014, 12:02 PM   #1660
FRSTRM
Baby LFA
FRSTRM's Avatar
Drives: Baby LFA
What lugs are these?
Originally Posted by ericvanderwoodsen View Post
Got my 530s on the other day, 18x8.75 +20 offset dropped on eibach pro-kit... dont mind the dirtiness
FRSTRM is offline   Reply With Quote
Old 03-15-2014, 04:49 PM   #1661
ericmpena
ericmpena's Avatar
After coming from saggy butt Sportlines, I'll take any amount of rake!
Old 03-15-2014, 07:10 PM   #1662
deliroast
Drives: 2014 SSM BRZ
Look like mutekis. Pass on them.
M3 > BRZ
deliroast is offline   Reply With Quote
Old 03-16-2014, 05:41 AM   #1663
ericvanderwoodsen
ericvanderwoodsen's Avatar
Drives: 2013 SWP Subaru BRZ Premium
I get a lot of compliments, dislikes and questions in my inbox about my setup 18x8.75 +20 with Ziex 912 225/40/18, so thought I just answer some of them here. First I don't do stance so poke/flush are not what I aim for, I do visit the track a lot getting the widest wheel base was the goal. Wider wheel base rewards in better handling as I only really hit about 75mph.
Qustion 1: Do you rub and what is wheel gap like?
Answer: None what so ever, before switching to coilovers I was on the Eibach Pro Kit and it's was the sweet spot for this wheel setup. Wheel gap on the spings was about .8 inches.
Question 2: Is the poke as extreme as @Ericpena and others makes it sound?
Answer: That's all personal opinion and only yours matters as it's your car, but taking advice from someone about something they haven't owned or had is like asking me if I think one turbo kit is better than another when I haven't had either one I would be unreliable. My opinion doe, I like it on this car with the tires I have as the actual tire tread is under the fender and only my white Falken lettering shows in front and a little less in the rear. Here's a pic I took of what the rear looks like, the natural camber tucks it in.
Question 3: Will a staggered setup work better?
Answer: I get this one the most, yes it's fine if you want the front to be more "flush". Like I mentioned I do track the car so a staggered would create a great amount of understeer that would not benefit me as this car's center is so low plus I love the oversteer , I brake pretty well in turns and I'm not over 250hp (cars with a good amount of HP break loose quicker so wider wheels in the rear help keep it under control), on the street for someone who isn't about the "sport car" and wants a "stance car" you won't notice it at all as that's a setup I have actually driven and works really well. Not sure what a staggered offset only will do but I'm sure it's understeer as well, running +38 in front and +20 in rear will be a 1.5in shorter wheel base in the front even with the same width.
[ame="http://www.youtube.com/watch?v=z_bWWLw-60k"]Understeer & Oversteer -- AMG Driving Academy Performance Series Episode 4 - YouTube[/ame]
Question 4: Will I need an alignment for the +33, +38 or +20 offset?
Answer: I highly recommend getting an alignment anytime you change your wheels, as any change in diameter, width and offset can cause uneven wear on the tires or ride unsteady at high speeds.
Hope this helps some people, just remember it's your car so don't let others build it for you. These wheels look great on the twins no matter the offset or diameter just depends on how its executed!
ericvanderwoodsen is offline   Reply With Quote
The Following User Says Thank You to ericvanderwoodsen For This Useful Post:
chas3wba0 (03-17-2014)
Old 03-16-2014, 12:56 PM   #1664
dkrou351
dkrou351's Avatar
Drives: Scion FR-S
Tpms
Right, thanks. I'm getting Yokohama S Drive tires, so I will check on that.
Merica.
Old 03-16-2014, 08:16 PM   #1665
ericmpena
ericmpena's Avatar
Thanks for all the input! Your car looks great btw. I don't track my car nor do I drive aggressively, which is why I'll be trying out a staggered setup. Recently I had some rubbing issues and my solution was to get rid of my wheel poke. I had to take off my spacers (15 front, 25 rear) and move to just 15mm in the rear. The front and rear wheels sit slightly within the fender...which worked out perfectly in resolving my rubbing issues. On top of the rubbing issues, I really didn't like the wheels poking out in the first place.
I hope you understand, most of the information we all have to make decisions on are pictures that people post. The pictures I've seen of +20 offset definitely have poke...which I have to avoid due to my previous rubbing issues. I actually don't mind the rear poke as much, but in any case I have to avoid it. I didn't mean to make it sound all extreme! As I said, I'm just going by the pictures that others post.
"Taking advice from someone about something they haven't owned or had is like asking me if I think one turbo kit is better than another when I haven't had either one I would be unreliable."
About this...there's a reason I post pictures in a lot of my comments. I say my opinion, but I also post tons of pictures so they can see for themselves. Sure, I don't own the wheels and know very little about them...but people who do a Google search will stumble upon my posts and I would have saved them the trouble of looking through 75+ pages of comparisons. No one has to agree with my opinions about poke. Decide for yourself...but at least let me post some pictures so that you can compare for yourself. I like to think I'm being helpful, but I can see how it could come off as something else.
The Following User Says Thank You to ericmpena For This Useful Post:
ericvanderwoodsen (03-16-2014)
Old 03-17-2014, 01:19 PM   #1666
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
FINALLY had a half way decent day in this awful CNY winter to throw the rims and tires on. More pics to come as soon as there as i can wash her and there is another nice day. (may be a while)
These are 18x8.75 +35 with 235/40/18 Dunlop Direzza Z102 square.
Lowered on Hotchkiss Springs
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following User Says Thank You to Takumi788 For This Useful Post:
ericvanderwoodsen (03-17-2014)
17 wheels
Wheel Directory: ProDrive GC-012L 18x8.5 +48 MarkMash Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 05-12-2013 04:55 PM
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 01:24 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 01:28 PM
