Old 03-14-2014, 02:29 PM   #939
Racecomp Engineering
Quote from OptimumG:
"On a car where rules allow, and you choose to do so, a suspension system can be designed where damping adjustments can be made that isolate ride, roll, and pitch. Finding an ideal baseline for roll and pitch damping are discussed below, however, most cars due to their suspension design are forced to make a compromise between the three (this explains the point mentioned above with successful cars using non-ideal damping ratios in ride)."
A lot of people overlook this fact and wonder why people aren't going for the 2.2 Hz number and leaving it at that.
It's also one reason why there is some wiggle room in the damping ratios.
- Andy
Old 03-14-2014, 02:35 PM   #940
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by Calum View Post
Have you studied control systems at all? That's all this really is, in a very basic form. Natural frequency, impulse response, dampers, settling time... If you haven't studied controls yet, than this is going to be a great crash course. Just remember your instructor knows 'best'.
Nope not yet! This is all inundating my brain and like slamming a dictionary on my head hoping to learn lol jk
I've dealt with frequency before, only in audio though.
I know nothing about impulse response, dampers and settling time.
Old 03-14-2014, 02:36 PM   #941
The subject of roll resistance keeps coming up, and guys like me keep getting told in some form or another that it doesn't matter, only conforming to the road surface matters. If that were true rock climbers would make the best tarmac race cars ever, with their 20 odd inchs of wheel travel and rolling like an old Corvette in a storm. Maybe I'm too old, or have read too many 'yo dogz my car iz stiff as nuts dog, coiloverrrzzzz!!' on the forums, but I can't get away from the idea that roll stiffness is still a large factor here. We need to prevent the weight from transferring around too much so the outside tires don't get overloaded and so the car can react to direction changes quickly. What am I missing?
With regards to this part, there are a couple things:
1. Remember that total weight transfer is not affected by spring rate in a given corner. You can alter the proportion of weight transfer front and rear, but not the total.
2. Firmer suspension means quicker reactions and quicker weight transfer. The car changes direction quicker and feels nice. Very quick weight transfer can overload a tire rather than loading it up nice and progressively, so there's a balance.
3. Firmer suspension (and less roll) is a good way to minimize camber loss and suspension geometry changes.
- Andy
Old 03-14-2014, 02:39 PM   #942
Take your time and read a lot. Don't let it get to you that you have to read things a couple of times for them to make sense. I've reread the same articles dozens of times before they "click".
How To Make Your Car Handle by Fred Puhn is a good book. Old, but good.
- Andy
Old 03-14-2014, 02:42 PM   #943
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I'll look into it! I hope there are some good puhns...
Old 03-14-2014, 02:51 PM   #944
- Andy
cdrazic93 (03-14-2014)
Old 03-14-2014, 03:16 PM   #945
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
So after a little reading, who is going to under take the hidiously enormous task of converting a 86 into a double wishbone suspension
Old 03-14-2014, 03:37 PM   #946
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
cheaper to buy a miata
but really, given the application requirements, the only problem we have from being on struts is limited adjustability in stock form
Old 03-14-2014, 03:41 PM   #947
wparsons
wparsons's Avatar
911's and M3's do just fine with macpherson struts...
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
andrew20195 (03-14-2014), Racecomp Engineering (03-14-2014)
Old 03-14-2014, 03:46 PM   #948
hakkoo
Quick question, I have the ST Coilovers, do i need to get camber bolts to adjust front camber or is it okay w/o it since ST's are slotted
Thanks
hakkoo is offline   Reply With Quote
Old 03-14-2014, 03:50 PM   #949
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Rather than going for the cheaper option, miata or the like, I would attempt this only due the fact of how different the car would sit and feel on the road and track, the unique appeal also has some allure to it as well
Old 03-14-2014, 03:54 PM   #950
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
From the difference in design is there any way in which the double wishbone is better?
Old 03-14-2014, 04:00 PM   #951
Calum
That Guy
Drives: 2013 asphalt FRS MT
Wait, side to side weight transfer isn't affected by roll angle? I thought stiffer springs would help manage roll which will help manage weight transferring to the outside tires.
This I understand, I think. The near instantaneous deceleration of the roll of the car can cause a great deal of force on the tire, and thus can possibly over load it...?
This makes sense as well.
- Andy
My comments are in bold.
Old 03-14-2014, 04:03 PM   #952
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
it's generally easier to make the wheel maintain a desired angle to the road during suspension movement... even a lot of movement
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
