Old 03-13-2014, 01:06 PM   #211
regal
Drives: Scion FR-S/Toyota Yaris
Originally Posted by Luckrider View Post
I don't know what you are talking about, I picked up ~30 NA HP....
Oh wait, that was on the magical e85 with just a tune.
No e85 here. No etOH free either. On the radio there were discussing a new law which would allow additional 5% EtOH, pissed a lot of people off. They were claiming the alcohol attacks seals and shortens the life of seals.
All I know is I wish we had ethanol free gas because it gets better fuel milage. .
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 03-13-2014, 01:10 PM   #212
OrbitalEllipses
Drives: Attitude
Originally Posted by regal View Post
No e85 here. No etOH free either. On the radio there were discussing a new law which would allow additional 5% EtOH, pissed a lot of people off. They were claiming the alcohol seals and shortens the life of seals.
All I no is I wish we had ethanol free gas because it gets better fuel milage. .
Ugh the energy content of EtOH is disappointing. If I want EtOH, I'll buy it at the booze store.
Old 03-14-2014, 03:13 AM   #213
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
This issue makes me hesitant to go pick up the OFT, or for that matter any tune. Has anyone proven this to be an issue long term for the car?
I know I asked this twice but is the sound for the normal OFT tune the same as that for the supercharged?
It seems that @Dezoris heard it from the supercharged video and you also have a supercharged/tuned car if I'm correct?
calmtigers is offline   Reply With Quote
Old 03-14-2014, 03:23 AM   #214
Dezoris
Dezoris's Avatar
Does not matter if the car is supercharged or NA, if the tuner uses aggressive VVT maps to eliminate torque dip certain cars will exhibit this valve-train noise.
Tuners like Perrin and Vishnu and others who have extensive knowledge claim it's likely resonance from the VVT angle change.
But there is no proof mechanically one way or another if its good or bad.
For me, everyone who hears the car says it sounds bad including those who have mechanical backgrounds. My choice was to have the aggressive VVT map stripped out of the tune for now and it is now quiet again.
I'd rather not risk it one way or another.
Old 03-14-2014, 03:34 AM   #215
regal
@Dezoris is the reduction is mid torque enough for you to consider trying an innovate or are you sticking by your guns?
Mods:
Old 03-14-2014, 03:59 AM   #216
Dezoris
Dezoris's Avatar
Going to stick with this, already have too much money and time in it.
May do header instead but not a priority yet.
Old 03-14-2014, 07:59 AM   #217
regal
If funds are low just ream out the header cat, allows almost an aggressive tube as a good header, The stock exhaust manifold is of good design (other than the cat.)
Mods:
Old 03-14-2014, 10:28 AM   #218
andrew20195
Drives: 2013 Subaru BRZ
The sample size of stock vehicles with high mileage is still quite small, much less tuned examples.
andrew20195 is offline   Reply With Quote
Old 03-14-2014, 01:49 PM   #219
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
The sound recordings are almost too good so there is so much other noise it's hard to hear and separate "bad" from "normal" noises. I don't think I hear a major DI problem but if there is a minor one you won't hear it recording from the engine bay.
Asking tuners or engineers to specifically tell you that you do or don't have problem with a single piece of data is why they aren't jumping in (plus we all have hundreds of customers and other business that will always take priority). We simply can't make judgement calls without seeing lots of data to back up any theories we may have. If you had a data log and we could see DI pressure waves or even your cam timing plot we could say hey it all looks normal and you're just being paranoid or that you might have a legitimate problem.
Thanks,
Phil Grabow
Element Tuning is offline   Reply With Quote
Old 03-15-2014, 02:26 AM   #220
Dezoris
Dezoris's Avatar
Thanks,
Phil Grabow
Thanks appreciate it. FYI, log was attached in this post above.
http://www.ft86club.com/forums/attac...7&d=1394506085
Old 03-15-2014, 10:17 AM   #221
Captain Insano
I threw it up on my datazap for ya if you want to see pretty graphs...
http://www.datazap.me/u/captain-insa...risscproeculog
Captain Insano is offline   Reply With Quote
The Following User Says Thank You to Captain Insano For This Useful Post:
Dezoris (03-16-2014)
Old 03-15-2014, 10:32 AM   #222
wparsons
wparsons's Avatar
Just to be clear, there are two different noises being discussed here... there is a resonance/raspy noise which is normal and nothing to worry about, then there is a noise from the DI pump which might be something to worry about, or it might not.
The only way to tell for sure which noise you're hearing is to log the DI pressure and look for a consistent wave.
Now that logging is working for me again, I'm going to pull a log to see what's happening with mine. I have an early build date (delivered July 2012) and am on the original DI pump revision, but mine doesn't seem to make the bad noise at all.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
calmtigers (03-15-2014), DAEMANO (03-16-2014)
Old 03-15-2014, 10:56 AM   #223
Captain Insano
What log parameter(s) should we be watching for this DI pressure wave/flucutation?
Old 03-16-2014, 02:12 AM   #224
Dezoris
Dezoris's Avatar
Here is the comparison video of the before and after tuning. One with aggressive cam angle and one with stock angle. I am keeping the tune with the stock angle, much more refined. Dyno scheduled for 2 weeks.
[ame="http://www.youtube.com/watch?v=9t4QtTmfBsA"]Vortech FRS VVT Angle Comparison | P2 - YouTube[/ame]
The Following 4 Users Say Thank You to Dezoris For This Useful Post:
86-tundra (03-17-2014), leicaboss (03-16-2014), mxsled (03-17-2014), Sirsimon (03-17-2014)
Variable Valve "Butterfly" Exhaust dlux Southern California 19 02-22-2016 07:21 PM
First tank OFT E85 tuning. Noise? Tromatic Software Tuning 2 02-20-2014 06:43 PM
Exhaust Cut Off Valve beagoodruslan Engine, Exhaust, Transmission 2 01-01-2014 02:47 AM
Exhaust Noise that goes away after warmed up FastLane1000 Engine, Exhaust, Transmission 10 08-15-2013 11:06 PM
Knock/valve slap/crick noise under accel yomny Issues | Warranty | Recalls / TSB 47 01-07-2013 09:53 PM
