Old 03-12-2014, 09:53 PM   #141
imom
Drives: BRZ sold
I'm sorry I do not but this is the first time I have read of this. Not the difficult 2nd gear change but the suspension and drive shaft being the cause.
Capt... There could be a variety of issues... right now it's only speculation on my part...but this is what I've done so far. Mtec springs, MTL in the tranny, diff oil changed too. I have shifter bushing and the tranny mount... there was improvement, but still not fixed. Definitely the shifting is smoother after 30 minutes of driving...so I will try pentosin next... even then...I suspect the tranny floats so much that it's causing shifting issues.
The other recommendation is to change the engine mount but I won't do that...too much headache and noise to contend with. I do notice the tranny moving via the shifter when the car is moving on uneven road... I never liked the 2 piece drive shaft...it's low cost budget nonsense.
That is why I am asking if the 1 piece driveshaft will improve shifting. It's just sad for Japanese cars to have these known issues. Had I known I would have gotten a different car or stuck with my M roadster. The car would be more enjoyable if the 2nd gear nonsense was fixed.
imom is offline   Reply With Quote
Old 03-13-2014, 02:05 AM   #142
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Given how direct the linkage is to the gearbox I am suggesting that transmission movement is not the cause.
This issue has been attributed to double synchros and often resolves itself within a few kilometers but it reads like you are having more issues than most.
Old 03-13-2014, 03:05 AM   #143
Turdinator
Señor Member
Turdinator's Avatar
I very much doubt the driveshaft would change the shift feel in any instance of driving. A lighter flywheel MAY help as the engine will drop revs quicker helping slow the gearbox input shaft which in turn would help the synchros do thier job. But this would really only be evident during high RPM and fast shifts. But a light drive shaft will still be doing the same RPM as a stock one. Also a 1pce drive shaft should transmit more movement to the gearbox than a 2pce.
Have you spoken to toyota about your gearbox?
1974 TA22 Celica
2013 86 GT
Old 03-13-2014, 03:47 AM   #144
imom
Drives: BRZ sold
From my experience dealer doesn't do jack. If there's a reputable dealer I would consider it...otherwise I try to fix it myself. Don't matter what dealer manufacturers...I had multiple BMW dealer do bad work as well other stories I hear. Sure there are good people as well...but I have coin flip experiences...hit and miss.
I don't the synchros will break in will fix...it's got 3,000 miles on it and still the same. I hope the pentosin being lighter than MTL will fix the issue.
Old 03-14-2014, 09:34 AM   #145
M1K3
M1K3's Avatar
Drives: vrooom...
Originally Posted by OICU812 View Post
I'd like to know hoe you torqued these bolt/nuts, what attachment?... Last time I messed with shaft I can't see how there's room for anything other then a standard wrench??
I really like the motion pro torque wrench adapter for that type of work:
M1K3 is offline   Reply With Quote
Old 03-14-2014, 10:09 AM   #146
troek
troek's Avatar
Drives: 2012 Toyota 86
is that a diagram of our transmission? it dosnt seem like our shifter sits that far back on the transmission.
EDIT: yeah i just looked, i guess it does lol.
troek is offline   Reply With Quote
Old 04-10-2014, 05:29 AM   #147
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
i'm interested in the driveshaft, but i'm wondering why there doesn't seem to be any competing products on the market?
secondly, why is it that the tS BRZ has a larger drive shaft than the stock brz and this product is going in the opposite direction?
SuperDave is offline   Reply With Quote
Old 04-10-2014, 07:16 AM   #148
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Driveshaft shop also has their CF and Aluminum version, HKS also has a CF shaft coming. As well to note if you google alternate driveshafts for these cars there are 2-3 others. As far as why the TS driveshaft goes in regards to diameter that's tough to say if I was a guessing man I would say much of aftermarket CF shafts are keeping in mind clearance on aftermarket exhaust etc. The fact they're good for 600+ whp the diameter should be of non concern.
Old 04-10-2014, 05:18 PM   #149
fr-sTony
Happy Camper
fr-sTony's Avatar
Drives: ultram 2013 FR-S, 1985 Merkur XR4Ti
I got mine from a different vendor but it's awesome at any speed. It deadens the vibrations coming from the back axle and the vibrations from the front aren't sent to the back either. It makes the car much more quiet and relaxed. It seems a little more eager at slow speeds or off the line and it doesn't take as much throttle for minute speed adjustments when cruising.
I love the quiet mostly.
fr-sTony is offline   Reply With Quote
The Following 3 Users Say Thank You to fr-sTony For This Useful Post:
Fly Guy (06-07-2014), SuperDave (04-18-2014), unsurety (06-13-2014)
Old 01-11-2015, 09:27 AM   #150
pepe
Drives: gt86
Hello! from my ignorance of mechanical issues
a question .... OEM transmission shaft, consists of two parts and a rubber gasket ... right? why?
which is the reason why Japanese engineers (which should not be too dumb), make this piece into two parts?
pepe is offline   Reply With Quote
Old 05-30-2016, 10:27 AM   #151
BigRips
They make them 2-piece from factory for the safety factor. If you experience a rear-end collision with 2-piece shaft it will collapse and fold under and away from passengers. 1 piece shaft has a greater potential to shish kabob you or a passenger in a rear end collision.
BigRips is offline   Reply With Quote
Old 05-30-2016, 10:33 AM   #152
BigRips
Originally Posted by msile View Post
True. I have lighter than stock wheels, pulley and the CF Shaft. The combo is pretty noticeable.
Thinking about adding CF driveshaft and pulley to my car. Will i need to re-tune after the additions?
Old 05-30-2016, 10:54 AM   #153
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
I added an aluminum shaft in conjunction with an FD swap. No calibration required for the shaft. That said I hear it clunk now and then. Generally more when throwing the car in reverse. I imagine the steel 2 piece factory one masks that.
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
Mim is offline   Reply With Quote
Old 08-28-2018, 04:50 PM   #154
w_guzman310
Drives: Scion frs 2014
can someone tell what this part is called
the part where they lubed. where the insert shaft is. and can this part be ordered
can someone text me 3108742336
or email me asap w_guzman310@yahoo.com
thank you
w_guzman310 is offline   Reply With Quote
PST Carbonfiber Drive Shaft In Stock and Ready To Go!! RallySport Direct Transmission and Driveline 27 11-18-2012 02:39 PM
Carbon Fiber Hoods. Asterisked Accolade Cosmetic Modification (Interior/Exterior/Lighting) 17 09-25-2012 05:44 PM
HELP...Drive Shaft/Rear Tire Shutter UM FRS Issues | Warranty | Recalls / TSB 11 09-05-2012 12:14 PM
Does FRS come with Carbon drive shaft? STi88 Engine, Exhaust, Transmission 30 07-30-2012 02:40 PM
