kidgogeta
Old 03-08-2014, 12:52 AM   #1597
Crashhollywood12
cam bolts
Just have camber questions. My 18x8.75 +35 XXR 527 hyper silver wheels, Eibach Pro Kit, hub centrics, and lugs are in my living room cussing me out for not installing them yet. I ordered +/- 1.75 range cam bolts for the front, but they were backordered. I've been waiting to install everything at one time. Is my cam bolt range selection enough or should I get some with a wider range? Secondly, with the Eibach Pro Kit installed, will I need control arms on the rear to adjust camber? Tires only last me me about 12k miles anyway, because I drive my dd car like someone is chasing me. I dont want to go through extra tire wear because of unnecessary camber, since I'm not taking it on the track.
Crashhollywood12 is offline   Reply With Quote
Old 03-08-2014, 01:09 AM   #1598
bfsnail
bfsnail's Avatar
The bolts for the front will give you all the street camber adjustment you need. The rear has no camber adjustment from the factory at all. I was at -2.1 and -2.5 in the rear with my sportlines which is why I wanted to get the control arms to get something a little more streetable.
bfsnail is offline   Reply With Quote
Old 03-08-2014, 01:16 AM   #1599
Crashhollywood12
cam bolts
Thanks! I appreciate the help. I guess I'll see what the camber is after lowering the inch to see whether control arms are necessary. I have hoped that maybe with such a small drop that the camber would still be pretty close to factory spec.
Old 03-08-2014, 01:18 AM   #1600
Vten
Drives: Too heavy
Originally Posted by mazzobrz View Post
Do not worry, your pics has been helpful.
bright red candy? Original!
Yup
http://www.ft86club.com/forums/showp...postcount=1463
Vten is offline   Reply With Quote
Old 03-08-2014, 02:46 AM   #1601
spdbydesignchris
spdbydesignchris's Avatar
Drives: 2013 BRZ Premium
Originally Posted by deliroast View Post
Would love to know of a lug that won't scrape the color off the first time using the supplied socket too
Ours are Anodized and will not chip.
spdbydesignchris is offline   Reply With Quote
Old 03-08-2014, 03:46 AM   #1602
friss21
Drives: raven black frs
Looking for a set of xxr 530 if anyone has em please let me know. 18x8.25 or 8.75 +20 chromium black preferred preferred PM me if you have them for sale or no where i can buy them for under 600 shipped!
friss21 is offline   Reply With Quote
Old 03-08-2014, 03:49 AM   #1603
DAEMANO
Time Traveller
Looks great!
Wheel and tire specs please!
Thanks
Originally Posted by bfsnail View Post
On sportlines. Camber bolts, rlca and 10mm spacers are in the mail
Old 03-08-2014, 03:47 PM   #1604
bfsnail
bfsnail's Avatar
Originally Posted by DAEMANO View Post
Looks great!
Thanks
18x8.75 +35 225/40/18
The Following User Says Thank You to bfsnail For This Useful Post:
DAEMANO (03-08-2014)
Old 03-10-2014, 11:30 PM   #1605
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Someone please help me! Looking to buy XXR 530 Chromium Black but I don't like the front poke you get with 18x8.75 +33.
Are there any pictures of someone with 18x7.5 +38 front and 18x8.75 +33 rear?
I've gone through 40 pages of this thread so far and I still haven't seen anyone with a staggered setup.
ericmpena is offline   Reply With Quote
Old 03-11-2014, 09:15 AM   #1606
bfrank1972
Drives: 2013 FR-S Argento
Front camber will make the 8.75 +33 flush FYI. I haven't seen anyone post a staggered setup with the 530's. I don't love staggered setups personally, but it would probably work just fine.
Sent from my QMV7A using Tapatalk
The Following User Says Thank You to bfrank1972 For This Useful Post:
ericmpena (03-11-2014)
Old 03-11-2014, 09:23 AM   #1607
CatDaddysBBQ
Drives: '13 FR-S
I think this is my fav blue car setup yet... However I can't help but wonder how amazing your blacked out badges would be if they were dark bronze to match those bomb wheels!
CatDaddysBBQ is offline   Reply With Quote
The Following 3 Users Say Thank You to CatDaddysBBQ For This Useful Post:
akahenry (03-12-2014), B-R-Z (04-15-2014), balla_08 (03-12-2014)
Old 03-11-2014, 02:36 PM   #1608
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Figured I would try something a little different with the wheel caps
Chrome lugs
Chrome center caps
55mm custom 86 center cap sticker
Pardon the dirt. I just got my wheels out of storage.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 03-11-2014, 04:45 PM   #1609
ericmpena
ericmpena's Avatar
Sorry, I'm a noob when it comes to camber. Are you talking about having the wheel tilted/slanted inward so that it appears flush with the fender instead is poking out a few mm?
Is it okay to drive like that, or will I see uneven tire wear?
Old 03-11-2014, 05:09 PM   #1610
bfrank1972
No problem Yeah camber is how much the wheel is tilted inward - stock our cars don't have any adjustability with this. You have it right though, you can get adjustable camber bolts (the bolts with cams on them) and adjust the camber (tilt) so the wheels tilt inside and the top of the tire sits flush with the top of the fender and give you a nice aggressive look. Assuming your car is aligned properly by a good shop after lowering and adjusting camber, running the camber you'll need (-1.3 to -2 degrees) won't make a big difference in tire wear. Toe changes from lowering are the biggest culprit to tire wear, and should be dealt with once you get your car aligned. A terrific benefit from a mild increase in camber is your front end will bite/feel better in turns. Anyway try adjustable camber bolts and see if you can get enough camber with them - if you need more than that you'll have to go with something else like camber plates.
17 wheels
Wheel Directory: ProDrive GC-012L 18x8.5 +48 MarkMash Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 05-12-2013 04:55 PM
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 01:24 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 01:28 PM
