alpine, ATL BRZ, ftc~brz, jamesm, King Tut, OrbitalEllipses, sklimo, SmsAlSuwaidi, Sportsguy83, whitefrs
Old 03-11-2014, 01:42 AM   #2045
jamesm
It depends on @jamesm doing cam timing changes....
I'm guessing in the next 3-4 revisions we should have all the fuel dialed in and ready to hit dyno for minor changes.
they're done i promise... i'm finally happy with it lol
The Following User Says Thank You to jamesm For This Useful Post:
Sportsguy83 (03-11-2014)
Old 03-11-2014, 01:43 AM   #2046
jamesm
Yes can be done, its not the proper way to do it.
Going over double spring pressure usually prevents you from holding max boost to redline.
note that this is true unless you use a 4-port solenoid . 4-ports use boost pressure to hold the wg shut.. so all you need is a spring stiff enough to hold it shut in vacuum and very light boost, most people go with 3psi springs and can push the boost to whatever they want using them.
Old 03-11-2014, 05:24 AM   #2047
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Lol JK man, you can take as long as needed :-D.
I see. You learn something new everyday!
Whitefrs hates my phone signature
The Following User Says Thank You to Sportsguy83 For This Useful Post:
jamesm (03-11-2014)
Old 03-13-2014, 11:06 AM   #2048
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
@Sportsguy83 I'm thinking about going with RCE Tarmac Zero Coilovers for my FR-S, would you recommend them? What are your impressions on them?
Thanks!
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 03-13-2014, 02:05 PM   #2049
Fresh86
Fresh86's Avatar
Drives: 2013 Scion FRS
Such a nice build man!
Fresh86 is offline   Reply With Quote
The Following User Says Thank You to Fresh86 For This Useful Post:
Sportsguy83 (03-13-2014)
Old 03-13-2014, 06:16 PM   #2050
Sportsguy83
Drives: Limited BRZ
Thanks!
They are pretty good. Stock like feel. I had an issue with a stripped bolt in the perch that holds the coil and prevents it from lowering, but not a big deal. A larger bolt made the trick.
Aside from that no major issues. I like them a lot.
Brody602 (03-13-2014)
Old 03-16-2014, 01:04 AM   #2051
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
no corn
Old 03-16-2014, 01:36 AM   #2052
Sportsguy83
Drives: Limited BRZ
Originally Posted by SmsAlSuwaidi View Post
no corn
James checked in his car and we still have the fuel issue at 15 psi. Looking to get that resolved this week. Dyno will be coming very very soon after the fix is done.
Sent from my SM-N900A using Tapatalk
Old 03-16-2014, 02:13 AM   #2053
SmsAlSuwaidi
Boosted
What on earth is causing that issue ?
Sent from my IBrick
Old 03-16-2014, 02:42 AM   #2054
Sportsguy83
Drives: Limited BRZ
Sent from my IBrick
Either weird ECU limiter or speed density implementation in the latest RACEROM
Old 03-16-2014, 02:44 AM   #2055
SmsAlSuwaidi
Boosted
So even james's car is doing it now ?
Sent from my IBrick
Old 03-16-2014, 02:53 AM   #2056
Sportsguy83
Drives: Limited BRZ
Sent from my IBrick
Yep.....
Old 03-16-2014, 02:54 AM   #2057
SmsAlSuwaidi
Boosted
Yep.....
Ffs
Sent from my IBrick
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
Sportsguy83 (03-16-2014)
Old 03-18-2014, 06:11 PM   #2058
ftc~brz
Done
Drives: WRB BRZ
I was tagged....I see nothing....leaving now.....
ftc~brz is offline   Reply With Quote
alpinewuzhere, better than sti, custom turbo kit ftw, epic brz build, ftc~brz, gtx30 goodness, its certainly a car, king tut, nocornnocare, sportsguy83, superior orbital fellow, thewheelsonthebusgo
Volk Racing TE37SL - Mag Blue/ Hyper Blue/ Flat Black/ Red/ Gold IN STOCK!!! Speed Element Wheels and Tires 151 09-26-2013 05:56 PM
Dream Mod For FR-S/BRZ JPxM0Dz Other Vehicles & General Automotive Discussions 22 03-08-2013 11:35 PM
Have You Had A Dream About Your Car? chanomatik Scion FR-S / Toyota 86 GT86 General Forum 7 01-29-2013 03:38 AM
Sonic Blue 86, Galaxy Blue deleted? 450hp/tonne AUSTRALIA 14 09-01-2012 08:10 PM
I had a dream... ashtray Off-Topic Lounge [WARNING: NO POLITICS] 1 03-13-2012 12:35 AM
