Old 03-06-2014, 10:00 PM   #1
ButtonMasher
ButtonMasher's Avatar
Drives: 2013 Ultramarine Scion FR-S
CV joint problem?
Hi guys,
Quick question. My FR-S makes a clicking sound (exactly like hot metal cooling down after you shut off the car) . This sound only happens when I turn or change lanes. It also only happens once per turn/lane change. Is this a bad CV joint?
ButtonMasher is offline   Reply With Quote
Old 03-06-2014, 10:42 PM   #2
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Could be a loose axle nut, you can take it to the dealer and have it greased and re-torqued, those with the click have reported that this can solve the click.
Edit: Should be a simple warranty operation, maybe half an hour of time if they're greedy enough to charge.
ineedyourdiddly
Old 03-06-2014, 10:57 PM   #3
kodyo
Drives: Scion FR-S
CV joint issues do exist on occasion based on the setup of the car and how it has been driven (Lowered, clutch drops with sticky tires, etc.)
kodyo is offline   Reply With Quote
Old 03-06-2014, 11:27 PM   #4
ButtonMasher
Is this an urgent problem? I have "my hands tied behind my back" at the moment and probably won't be able to bring it in for 2-3 weeks.
Sent from my Nexus 4 using Tapatalk
Old 03-06-2014, 11:28 PM   #5
ButtonMasher
Also my car is bone stock and I also purchased Toyota Extra Care Platinum so I won't have to worry about them charging me
Old 03-07-2014, 02:37 AM   #6
strat61caster
I doubt you will have a problem, broken axles have only happened on cars with aftermarket suspension.
Re-reading your OP it sounds a bit weirder than I thought, it may be something bigger but I think you should be ok if you take it easy. Hell it could be the rear deck lid popping, completely unrelated to suspension/drivetrain.
Those extra care packages may not cover everything, despite what the salesman tells you at the time. I'm not too interested in the details but I would read the package thoroughly before being sure.
ineedyourdiddly
Old 03-07-2014, 08:10 AM   #7
AznBRZer
Drives: 16 CBS WRX Limited
Weird. I'm getting the same sound when my car is on regardless of it moving.
AznBRZer is offline   Reply With Quote
Old 03-07-2014, 12:39 PM   #8
ButtonMasher
I think it was only a temporary problem. On my way to school today, there was absolutely no sound. If it is the CV joints, then it is thankfully covered under the platinum care so at least I have that peace of mind. Thanks for all the help though!
Old 03-07-2014, 12:41 PM   #9
ButtonMasher
That sure is strange. I wonder what it is. To my knowledge, CV joints only make sound when in motion and when you're turning. But hey, I'm no expert. I could be wrong. Might wanna get that checked out. Good luck to you!
Old 03-07-2014, 01:09 PM   #10
AznBRZer
Yeah, I'm pretty sure it isn't the joint, but it's just odd to me that my car is making that ticking noise while the car is on and it's getting more frequent.
Old 03-08-2014, 01:16 PM   #11
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
CV joints can make a clicking noise while turning and while driving straight.
If it's happening when you're turning, the cv joint is obviously going out, but it can still last a bit before being replaced (although I wouldn't put it off). If it's clicking while driving straight, it's about to go...
Doesn't sound like a cv joint issue though. Stock suspension and ride height with normal everyday driving isn't enough to cause the OEM cv joints to prematurely wear out like that.
Old 03-08-2014, 02:03 PM   #12
Mikem53
Drives: FR-S 6MT
They already charged you up front.. But I guess you don't have to worry..
Mikem53 is offline   Reply With Quote
Old 06-12-2014, 04:44 AM   #13
gonzo
Drives: frs
Mine is clicking when taking off from a stop, especially while turning
Stock suspension and ride height with normal everyday driving (except for 4-5 autocross events in the past two years)
gonzo is offline   Reply With Quote
Old 05-22-2015, 09:32 PM   #14
AreteAuto
Racing Enthusiast
AreteAuto's Avatar
Drives: Bone stock 2019 BRZ manual
Did you ever get yours fixed? I'm having a similar problem...
“$20 per diddle? I can diddle myself for free and do a fine job”
AreteAuto is offline   Reply With Quote
exlpoded cv joint ben15r Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 09-01-2018 04:12 AM
Front ball joint dimensions J-W Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-02-2013 05:31 PM
loose ball joint Grip Ronin Issues | Warranty | Recalls / TSB 15 07-09-2013 01:16 PM
What if...Honda and Mazda joint together to come up something to compete with 86? 86BRZ FR-S / BRZ vs.... 77 02-11-2013 05:51 PM
Toyota and GM Joint Venture Dragonitti Other Vehicles & General Automotive Discussions 19 03-31-2011 03:34 PM
