Old 03-07-2014, 01:19 AM   #1331
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by cjsporl1996 View Post
I sent the email again
Subject name: Vortech dev file cjsporl
I haven't received anything from you. Could you please email it to shiv@vishnutuning.com. Perhaps you are sending it to the sales account?
Shiv@Openflash is offline   Reply With Quote
Old 03-07-2014, 01:28 AM   #1332
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
i doubled checked the email address i sent it to. Everything is fine.
i uploaded the file you wanted to my drive account here is the link
https://drive.google.com/file/d/0By3...it?usp=sharing
could you send the dev file to cjsporl@comcast.net
Thank You
cjsporl1996 is offline   Reply With Quote
Old 03-07-2014, 03:47 AM   #1333
Shiv@Openflash
Drives: 2013 FRS
Thank You
You have email
Old 03-07-2014, 03:50 AM   #1334
cjsporl1996
You have email
Thank you shiv. I don't know why you never got the first 2 emails I have been having a few issues with my account recently. I am running the borla uel header and the perrin header back exhaust. I would assume the tune should be acceptable until you unlock the file and I can have it dialed in remotely. I will do a datalog as soon as I install the supercharger.
Old 03-07-2014, 10:42 AM   #1335
yoruck
Drives: ford fiesta st 150
hello, juste to be sure before doing something.
i juste receive my hks catless EL header and HKS hiflow sport cat front pipe.
it seems that the o2 sensor move to after the sport cat on the front pipe.
can i use the stage 2 for el with this configuration.
or the stage 2 is for afr sensor and o2 sensore on the header alone.
thanks
yoruck is offline   Reply With Quote
Old 03-07-2014, 11:18 AM   #1336
regal
Drives: Scion FR-S/Toyota Yaris
thanks
Others have used an o2 sensor wire extension for the post secondary O2 sensor, then there was no need to program out the secondary O2 cat check. Its a smart way to do things that I wish the American companies would have caught on.
You can still use stage 2 but I would turn the cat check logic back on.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 03-07-2014, 01:50 PM   #1337
yoruck
thanks regal,
where can i turn the cat check logic on.
the shiv stage 2 seem to have all the o2 cel ON
Old 03-07-2014, 08:45 PM   #1338
regal
thanks regal,
Sorry don't know that software yet. But the stage 2 should default to off. Even with the first O2 sensor in the header and the second O2 sensor after the front pipe cat you are getting an O2 CEL? Sure you are resetting it correctly? If that doesn't work try unhooking the second 02 sensor, he may have programmed for this since it is so common in the USA (unfortunately.)
As far as the MAF discussion when bosche efi was first emerging for German cars they wrote a little paper as t why MAF is better than speed density. Should have saved it but back when BMW's were reliable they used nothing but MAF,
Mods:
The Following User Says Thank You to regal For This Useful Post:
Apoc (03-07-2014)
Old 03-07-2014, 11:54 PM   #1339
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
Sorry, but I'm a complete noob and I have a quick question.. Does OFT supports the same features as the RaceRom from Ecutek (pretty sure OFT supports launch control, just not sure about rev matching downshifts) ?
Sent from my SGH-I337M using Tapatalk
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 03-08-2014, 12:12 AM   #1340
steve99
Drives: FT86
OFT has
LC Launch Control
FFS Flat foot shifting
does not have Auto Blip on downshift
To activate LC & FFS you need to use RomRaider and edit the LC and FFS paramaters then re-flash the modified ROM to car.
LC is kind of ok
Would not worry about FFS or even Blip on downshift (if it was supported) those two features cause more issues than they solve.
Old 03-08-2014, 01:41 AM   #1341
Shiv@Openflash
Drives: 2013 FRS
OFT has
LC Launch Control
LC is kind of ok
I agree. They definitely fall into the "marketing frill" category in my opinion.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
steve99 (03-08-2014)
Old 03-08-2014, 01:59 AM   #1342
steve99
Drives: FT86
thanks regal,
to remove the second o2 sensor CEL activation you need to open you tune file in Romraider, find the DTC (diagnostic trouble codes) table find the second o2 sensor then turn it off. Save tune and reflash tune to car.
Old 03-08-2014, 02:12 AM   #1343
steve99
Drives: FT86
Hi @shiv@vishnu
Been doing a bit off logging with updated parameters .
noticed my IAM drops occasionally to 0.9. Checked the Knock correction and got a small correction sometime before IAM drops .
was this the cause or what happen at the exact time the IAM drops, I am going for that as I see a drop in the KC learned at same time.
Why don't I see "Knock correction at that point ??
and do I need to be concerned with the "Knock correction spikes or just when the IAM drops ??
see log below
I assume I would pull a bit of timing at 3000rpm engine load =1 point
http://datazap.me/u/steve99/knock-co...=0&data=1-7-10
Old 03-08-2014, 02:21 AM   #1344
Shiv@Openflash
Drives: 2013 FRS
Hi @shiv@vishnu
see log below
Changes in Adv Mult are delayed and rarely coincide with exact time of knock correction so that is nothing unexpected. Just as the gradual increase back towards 1.0 after knock-free running. Most of the minor knock activity you saw was at pretty low engine speeds (~1600rpm). So maybe just take 0.5 deg of timing out there if you want to. Other than that, I wouldn't recommend making changes until you see repeatable knock correction behavior. And even in your current situation, the knock correct you see in your logs is pretty darn minor. Before detuning your map, I would suggest at least trying a different brand of gas if you haven't tried already. Then again, I'm not familiar with the gasoline situation down there in Australia
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
