Old 03-06-2014, 01:38 PM   #1
FReddy
FReddy's Avatar
Drives: 2013 Argento
M/T CCOLD!
Transmission is TIGHT in cold weather. Thinking about a lighter weight gear oil. First and second is hard to engage in cold weather.
Any suggestions?
Fred
153®
FReddy is offline   Reply With Quote
Old 03-06-2014, 02:17 PM   #2
Thorpedo
The SquadWhisperer
There are already so many threads on this.... The search button on this site sucks, but you can use google. Input this exactly as you see it. You can change the words after the ".com" to find what you want.
Site:http://www.ft86club.com hard shifting in cold
Thorpedo is offline   Reply With Quote
Old 03-06-2014, 02:28 PM   #3
canu_50
canu_50's Avatar
Drives: Scion fr-s
shift over 3500rpm in very cold weather and it goes a lot smoother. also running MT-90 from redline.
Coming from a canucks
canu_50 is offline   Reply With Quote
The Following User Says Thank You to canu_50 For This Useful Post:
FReddy (04-05-2014)
Old 03-06-2014, 02:38 PM   #4
Thorpedo
The SquadWhisperer
PLEASE do not rev your engine to 3.5k before you shift when your engine is cold. Once it passes that first bar on the temp gauge do as you please, but your trans will likely be somewhat better by that point anyway.
Old 03-06-2014, 03:26 PM   #5
wheelhaus
wheelhaus's Avatar
I agree shifting above 3000rpm with a cold engine isn't a terribly good idea. I'm using MT90 and cold shifting is a little stiff but it goes away quickly. By the time the needle is above the low mark the transmission feels much better.
The factory fill doesn't like to cooperate when it's cold, different fluid will definitely help but I'm a little wary of the thin fluids at the edge of spec or thinner.
Old 03-06-2014, 04:56 PM   #6
canu_50
canu_50's Avatar
Drives: Scion fr-s
You know that bringing the car up to 3500 rpm won't really make any change....
It is better to keep a light throttle all the way up to 3500rpm, then shift, then put even greater load on the engine and shifting it at 1500 rpm..
The Following 2 Users Say Thank You to canu_50 For This Useful Post:
continuecrushing (03-07-2014), STV3 (03-06-2014)
Old 03-06-2014, 05:17 PM   #7
STV3
Señor Member
STV3's Avatar
This^^^
STV3 is offline   Reply With Quote
Old 03-06-2014, 05:20 PM   #8
STV3
Señor Member
STV3's Avatar
Do not do as you please, just because you water temp is up to operating temps does not mean you oil temp is.
The Following User Says Thank You to STV3 For This Useful Post:
canu_50 (03-06-2014)
Old 03-06-2014, 06:56 PM   #9
thebus
Drives: Whiteout
Your water temp can be 120 and the oil in the engine at 60-90 takes quite a bit for the oil to warm up.. I recommend a scangauge really helps see your warm up times and how hot the car runs under loads!
thebus is offline   Reply With Quote
The Following User Says Thank You to thebus For This Useful Post:
Old 03-11-2014, 02:46 PM   #10
Thorpedo
The SquadWhisperer
Wrong. When the engine is cold the effects of RPM are far more detrimental than when the engine is warmed up. Cold oil on a wrist pin is a fine example. The "twist" exerted on the piston from rotational forces of the rod are not exactly good for the engine when the pistons have not fully warmed up and developed proper piston/bore clearance.
Of course throttle should be kept to a minimum as well, but that is beside the point. In my original post I should have been more clear. When the engine is warmed to the normal range you can certainly rev it to 3.5k before shifting (everything has obtained sufficient heat for that). Do not go balls out until your oil temp is up though.
Old 03-12-2014, 12:36 AM   #11
lickitysplit
Don't care
Drives: 2013 Whiteout FRS
just drive the car for 5-7 minutes and its fine. its normal and there is nothing you can do about it. Coming from someone that has a 500 gram knob, aftermarket shifter, amsoil fluid, positive shift kit and the rear stay bushing.
lickitysplit is offline   Reply With Quote
The Following User Says Thank You to lickitysplit For This Useful Post:
FReddy (04-05-2014)
