Old 02-28-2014, 06:37 PM   #827
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Yes, I meant your subjective opinions and your experiences for specific instances, including the pros and cons. In other words - recommendations ...maybe something that will hold up all day at the track (or at least as most it can), while still being DD'able.
fooddude is offline   Reply With Quote
Old 02-28-2014, 09:12 PM   #828
Racecomp Engineering
What kind of tires?
- Andy
Old 02-28-2014, 11:10 PM   #829
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Have any of you heard about people installing eccentric bolts on the rear lower arms to gain negative camber? While it doesn't seem to be ideal, or even a very good idea, it sure sounds cost effective.
I believe I read on the board somewhere that people have installed the bolts spindle side of the lower rear arm to get a bit of negative camber.
Old 02-28-2014, 11:19 PM   #830
Malt
Drives: 2015 WRX
I have them and didn't get enough camber adjustment to fix my alignment when lowered. Save your money/time and just get adjustable LCA's.
Malt is offline   Reply With Quote
The Following User Says Thank You to Malt For This Useful Post:
solidONE (02-28-2014)
Old 02-28-2014, 11:21 PM   #831
solidONE
solidONE's Avatar
How may degrees were you able to get and which bolt did you use? And would you trust them under tracking/'high load performance' situations. It's not for a lowered car, BTW.
Old 02-28-2014, 11:54 PM   #832
Malt
Drives: 2015 WRX
H&R camber bolts. Exactly 0.1 degree of adjustment was all they were able to get. There maybe more adjustablity there but he said he was running into issues with toe. I'm running T2's with raceseng tophats in the rear. I'm lowered maybe an inch to and inch and a half, not really sure how much lower but I've got almost two finger widths between the tire and the top of the rear fender.
Speaking of that, anyone know how far a BRZ sits off the ground when measured from the rear jacking point on stock tires and stock suspension?
I had previously purchased the whiteline upper ecentric bushing kit and was quoted 6 hours for the install, which was more than I wanted to pay since the labor alone would pay for a set of adjustable LCA's, so those are sitting in my office. I thought that toe arms wouldn't be needed for that modest of a lower to help with the toe issues, but after paying $80 for an alignment, $50 for the bolts, and $130 for the install (yes I know I could of done it myself and would of if I wasn't lazy) and they didn't even adjust the front camber like I wanted, I wasn't very happy. I haven't taken it to a different shop yet but I probably will just to be certain it wasn't just a case of someone not wanting to or not having the time to do the alignment right. It's quite possible they were right and there isn't any more camber adjustment to be had. Either way I felt like I threw $270 out the window. That being said, the guys at the shop were super nice.
As for tracking with them, I don't see why it would be any different than using eccentric bolts on the front. I imagine if they are installed properly they shouldn't slip.
Old 03-01-2014, 12:05 AM   #833
solidONE
solidONE's Avatar
I thought that toe arms wouldn't be needed for that modest lower but I after paying $125 for an alignment, ~$60 for the bolts, and ~$100 for the install (yes I know I could of done it myself and would of if I wasn't lazy) and they didn't even adjust the front camber like I wanted, I wasn't very happy. I haven't taken it to a different shop yet but I probably will just to be certain it wasn't just a case of someone not wanting to take the time to do the alignment right. Either way I felt like I threw $300 out the window.
Well that sux.
The reason why they may rotate is because of where they are connected. The angle of the spindle will change relative to the control arm when the suspension does it's thing. Compress and decompress. It is effectively a hinged connection out back vs the strut and spindle connection that stays in the same position up front.
What is the diameter of that bolt BTW?
Old 03-01-2014, 12:19 AM   #834
Malt
Drives: 2015 WRX
Well that sux.
I could be wrong but I'm fairly certain its installed on the inner mount, not at the spindle. No idea on the diameter since I didn't order it. I let the shop order and install it. Supposedly its the same one thats available on the perrin site. TC112 is the part number
http://www.ft86club.com/forums/showp...15&postcount=6
For the record, no grinding was done or necessary according to the shop.
solidONE (03-01-2014)
Old 03-01-2014, 01:07 AM   #835
fooddude
What kind of tires?
- Andy
245 width... I plan on trying PSS, D2 and RS3 and switching off as time goes by; all for DD. Maybe try a Bridgestone flavor too (RE11 or other..idk which are the good ones). Don't really have money currently for a track-day-only extra set of wheels/tires; though that would be nice and maybe so in the future.
Old 03-02-2014, 11:53 PM   #836
cycleboy
Drives: 2013 Scion FR-S - Argento
Toe will be slightly affected front and rear. You'll want an alignment after installing the springs.
You don't necessarily need to add anything to the springs. However....
For the front, the "OEM" camber bolts are like 10 bucks and make a huge difference. I think every car should have them and they should have come with them from the factory. It lets you get a little more camber up front and even it out. You'd be happier with close to -1 degrees or a little more for DD. Very noticeable difference in handling. Everyone just really should do this, even without adding springs.
For the rear, you have 3 options. LCAs, rear whiteline camber bushings, and nothing.
LCAs are more expensive but easy to install and adjust.
The rear camber bushings are cheaper but a pain to install and a bigger pain to adjust. They do also add a slight performance benefit in that it's a firmer bushing.
Doing nothing is actually not a bad option as you'll end up approximately where you need to be with our mild drop RCE Yellows. Any more drop and you'd probably want to do something.
I'm anal and like things to be "perfect" and equal side-to-side, so I'd probably do something. But that doesn't mean you need to.
- Andy
Thanks for this Andy, so now I have a bit of a follow on question.
What would be the ideal alignment specs for a car lowered on Yellows, 90-95% DD, few times a year on a track or auto-x, 17X8.5 +38, 245/40-17's?
And, can I achieve this without any additional parts, or should I at least add OEM bolts? How about for the rear? (I think you've kind of answered this above, I'm just trying to make sure I understand what's a good spec and how to make that happen.)
cycleboy is offline   Reply With Quote
Old 03-03-2014, 02:20 PM   #837
I'd say get the OEM bolts and max them out evenly. Should be around -1.5 or so which is perfect for a DD fun car. You'd have the option of doing nothing in the rear and you'd end up around -1.8 to -2.0 and that would be fine. Alternatively, get some rear LCAs and even it out at -1.8 and enjoy.
0 toe front, hair of toe-in for the rear.
- Andy
cycleboy (03-03-2014), fooddude (03-03-2014)
Old 03-04-2014, 02:36 AM   #838
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Gents, how does spring pre-load factor into ride quality?
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 03-04-2014, 02:59 AM   #839
solidONE
solidONE's Avatar
It seems for car applications little or no preload is added. Come to think of it... the stock setup has preload as evidenced by the need for spring compressors to install and remove.
Old 03-04-2014, 11:06 AM   #840
wparsons
wparsons's Avatar
Not really a direct answer, but more caster will let you run less static camber BUT will also make steering input less reactive for small inputs. It's all a balance with the whole setup. Adding a bit more caster might mean you can run less (or no) toe in while still feeling stable in a straight line, but it might dull the input too much for your taste.
flickr
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
