Old 02-18-2014, 02:23 PM   #435
stugray
Drives: 2013 GBS BRZ Limited
Question:
If you pull an old ROM that has no ECUFlash definition and save it as a 'stockROM.srf', can you flash it back on the car?
I see in this thread: http://www.ft86club.com/forums/showthread.php?t=58399
where:
Originally Posted by FRS-AZ View Post
3. After it bombed, I closed ecuflash while the ignition is on position. And reopen ecuflash again, decided to use stock.srf instead. The flash completed successfully, there is a god. Waited and crank it over, somehow the car was flashed with stock. I send amen and call it the night. I'm chalking this as hell of experiment.
It seemed to work for FRS-AZ.
That would be great news, but I didnt think that would work and I dont want to "experiment".
Old 02-18-2014, 08:51 PM   #436
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Question:
where:
Which older Rom CAL id is it? It's trivial to put together a flashing XML for Ecuflash - let me know the CAL id, and I'll pop it up on Github.
The only difference between srf and bin is that srf deal with sparsely populated roms, as opposed to raw files. Only Ecuflash can read those now, unfortunately. I'm hoping Colby will implement the Ecuflash kernel code soon that replaces the OEM bootloader, will be much quicker and I suspect dispense with any of these flashing issues.
Td-d is offline   Reply With Quote
Old 02-18-2014, 11:26 PM   #437
stugray
Thanks for the offer. I had ZA1J700c on until very recently.
The dealer updated me to ZA1JA00c about a week ago, but that is far as they would go with the older car.
Old 02-21-2014, 04:40 AM   #438
Td-d
No problem.
Old 02-25-2014, 03:24 PM   #439
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Anyone have a rough eta on when this and romraider will be polished enough to tune with?
GR86 MT premium
StormTrooper is offline   Reply With Quote
The Following 2 Users Say Thank You to StormTrooper For This Useful Post:
hmong337 (02-25-2014), reardrv (02-25-2014)
Old 02-25-2014, 04:18 PM   #440
Td-d
The romraider definitions are well defined, in fact the OFT guys are using them now. DSchultz also just managed to get his hands on an ecu, which will speed up the integration of (ODB) logging into the Romraider logger. As to when Ecuflash will move out of beta, not sure - but it is all usable as we speak.
Old 02-25-2014, 10:20 PM   #441
StormTrooper
Are the expanded parameters defined yet.... Those needed to properly tune, like injector duty cycle, fkc and so on?
GR86 MT premium
Old 02-26-2014, 02:24 AM   #442
Td-d
Some are (well the one's I've managed to pull out, and Ztan has also been adding to the list). FBKC and FLKC is, I posted the addresses somewhere on here (the RR thread, I think).
IDC is a derived parameter:
<conversion units="%" expr="(RPM*Fuel Injector Pulse Width)/1200" format="0.00" />
And both of those parameters are defined, so could be included in a logcfg.txt file.
The logging side definitely needs bolstering - I've just not had time, unfortunately, and without a BRZ to test on, sometimes a shot in the dark... Dale will definitely be able to fill the parameter set out once he has an ecu.
Old 02-26-2014, 08:49 AM   #443
Td-d
Can one of you guys test these addresses out for me, for A01C?
Code:
E_AF_Learning_1_A_StoredExt_E44 FFF815C4
E_AF_Learning_1_B_StoredExt_E45 FFF815CC
E_AF_Learning_1_C_StoredExt_E46 FFF815D4
E_AF_Learning_1_D_StoredExt_E47 FFF815DC
E_AF_Learning_Airflow_Range_CurrentExt_E61 FFF8A788
The stored AF learning are float values, and the current range is an 8 bit value.
Conversion for AF Learning is:
<conversion units="%" storagetype="float" expr="x*100" format="0.00" />
Old 02-26-2014, 01:14 PM   #444
StormTrooper
Wish I could help but I'm computer illiterate....
Trying to arrange tuning but not going to use EcuTek.
GR86 MT premium
Old 02-26-2014, 06:56 PM   #445
stugray
Where can we dowload the latest RR beta?
The old location is no longer valid:
https://dl.dropboxusercontent.com/s/...WWhQkeA8mqZAhg
Old 02-27-2014, 01:53 AM   #446
Td-d
If you're talking about the OBD logger beta, in the thread where it was posted:
http://www.romraider.com/forum/viewt...it=OBD+logging
If you're talking about the editor, check out the official download link on the RR forum - it's always up to date.
Old 02-27-2014, 03:27 AM   #447
steve99
Drives: FT86
ecuflash logging
I have got ecuflashh rom reading writing sorted. Interested in giving the logging via tacrix/ecuflash a go, relise its a work in progress but could some point me to the info needed to get it started thanks.
have micro sd in tactrix
created logcfg.txt file and added triggers
unfortunately no logged data
Would be happy to test ram addresses and logging if I get it going ect
Old 02-27-2014, 09:07 AM   #448
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Code:
here's what I added:
Code:
;E_AF_Learning_1_A_StoredExt_E44 FFF815C4
paramname = AF_Learning_1_A
paramid = 0xFFF815C4
isfloat = 1
;E_AF_Learning_1_B_StoredExt_E45 FFF815CC
paramname = AF_Learning_1_B
paramid = 0xFFF815CC
isfloat = 1
;E_AF_Learning_1_C_StoredExt_E46 FFF815D4
paramname = AF_Learning_1_C
paramid = 0xFFF815D4
isfloat = 1
;E_AF_Learning_1_D_StoredExt_E47 FFF815DC
paramname = AF_Learning_1_D
paramid = 0xFFF815DC
isfloat = 1
;E_AF_Learning_Airflow_Range_CurrentExt_E61 FFF8A788
paramname = AF_Learning_Range_Current
paramid = 0xFFF8A788
databits = 8
Here's the result
Can you help me out with implementing the conversion?
if you want to see some real driving action I can log this afternoon.
AdrianG is offline   Reply With Quote
Close iJason Member's Car Journals 1 08-04-2013 09:26 PM
Close pche Engine, Exhaust, Bolt-Ons 3 08-04-2013 03:04 AM
Sorry. please close. finch1750 Scion FR-S / Toyota 86 GT86 General Forum 1 07-31-2013 02:00 AM
please close abutterman Wheels and Tires 0 07-05-2013 10:40 AM
