Old 02-21-2014, 10:10 PM   #1
ts87
18x9.5 +30 anyone?
Hi, a buddy of mine recommended i run 18x9.5 +30 offset for the FR-S, i was just wondering what i should be worried about and/or what i may need to get done/replaced in order to have it fit fine. i saw @autofashionfred was running this setup and seemed alright, hoever he was on coils and i didnt see what camber he was running. any help is appreciated. Thanks!
My current setup:
Eibach sportline springs
Koni Yellow shocks/struts
SPC Front camber bolt
SPC control arms
ts87 is offline   Reply With Quote
Old 02-21-2014, 10:14 PM   #2
s2d4
s2d4's Avatar
Why don't you ask your buddy since it is his recommendation? He should know everything about it to make that call.
Old 02-22-2014, 12:42 AM   #3
ts87
Hey was saying most likely require pull and camber, i just wanted to see what settings peoe are currently running if they are running the 18x9.5 +30 or what the professional input is
Old 02-22-2014, 12:50 AM   #4
FR-S Matt
Running 18x9.5 +38 square with plenty of room for camber adjustment or no camber. Don't see why +30 would require rolling. Sub 30 though is a different story.
Old 02-22-2014, 02:09 AM   #5
s2d4
s2d4's Avatar
Don't listen to him then since he doesn't appear to know what he is talking about, or listen to him and get him to sort it all out for you.
Old 02-22-2014, 08:09 AM   #6
Cone_killer
About that...
Cone_killer's Avatar
Drives: WRB LTD BRZ
Also depends on how much you're willing to run camber and/or stretched tires. +20 on 9.5 is possible without pulling your fenders.
Cone_killer is offline   Reply With Quote
Old 02-22-2014, 05:01 PM   #7
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
That offset isn't ideal, 45+ is what I recommend, It will fill the space under the fenders, and you will need less camber, and you won't need to stretch the tires.
adprokid is offline   Reply With Quote
Old 02-24-2014, 04:22 AM   #8
Kai Uhl
Kai Uhl's Avatar
18x9.5 +25 with 215/40s. square setup. all fenders rolled. I think -3.5 degrees of camber in the front and 4 in the rear. Maxed out my camber plates and have whiteline front camber bolts. Camber in the rears are just from natural camber
Kai Uhl is offline   Reply With Quote
Old 02-24-2014, 12:44 PM   #9
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Look up Turn In Concepts. They are/were running 18x9.5" +30 with nice fat tires (I want to say 265s), with no modification other than camber bolts up front (before going to coilovers).
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 02-24-2014, 12:47 PM   #10
Vten
Drives: Too heavy
Any link ? I'm in the same boat as the op ...thanks in advance
Vten is offline   Reply With Quote
Old 02-24-2014, 12:57 PM   #11
NemeGuero
http://www.ft86club.com/forums/showthread.php?t=32699
no roll or pull, -2 deg up front -1.5 out back
NemeGuero is offline   Reply With Quote
The Following User Says Thank You to NemeGuero For This Useful Post:
ts87 (02-28-2014)
Old 02-24-2014, 01:31 PM   #12
2point0
2point0's Avatar
I don't have a list of links sitting around, but you can check their build thread.
Old 02-26-2014, 12:15 AM   #13
Vten
Drives: Too heavy
Thanks neme! How's the steering response toward the road with that camber specs ?
Old 02-26-2014, 04:12 AM   #14
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
So you're the one who bought sultan's rims. I keep thinking your car is(was) his lol.
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
Wheel Directory: Work Meister S1 3-Pc 18x9.5 +29 / 18x9.5 +24 PradiG Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 12-12-2013 04:15 AM
** Volk TE37SL 18x9.5 +40 (Rear) 18x9 +45 (Front)** SOURCE,LLC Wheels and Tires 23 09-17-2013 10:25 PM
Considering going from 18x8.5ft/18x9.5back to 18x9.5 squared what to expect?? OICU812 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 07-18-2013 11:10 AM
18x9.5 +45 (square) VS 18x9.5 +35 Front 18x8.5 +40 Rear (staggered) Funky Fresh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 05-07-2013 10:52 AM
F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires SsmoothyMonster Wheels and Tires 17 09-24-2012 02:52 AM
