#30 | ||
Drives: 2013 Whiteout Scion FR-S 6MT
#31 |
Drives: brz
So I read the instructions. I thought I would have to dig up the inside of the car and take apart the shifting area like you have to on the kartboy shifter. But actually, you do all the work on the under side of the car. It looks like you remove 2 bolts on the drive shaft bracket... and then kind of go from there. Should hopefully take 2 hours at most. Oh and FYI, the printing date for these instructions is 5/09/13... I wonder what else TRD has sitting on the shelf waiting to be released
#32 | |
#33 |
Avid searcher of things
Drives: Scion Fr-s 10 series
| The Following User Says Thank You to Scavanger For This Useful Post: | rxpx2012 (02-21-2014) |
#34 |
Drives: 2013 asphalt frs
#35 |
It's stiff compared to the stock one but that's because the retaining pin was a super tight fit so it will need to be broke in and then it will losen up
#37 |
Well I had a lot done, like I got LCAs, coilovers, new rims, tires, strut bar, catback exhaust, light kit, shark fin antenna, camber bolts, short throw shifter, and cold air intake done all together for parts and labor was 5100
#38 | |
I'm hoping the shifter was just a very,very small part of that : ) |
#39 |
LCAs - 250
Coilovers - 960 Rims & tires - 1500 Shark fin antenna - 100 Cold air intake - 350 Camber bolts - 45 Catback exhaust - 750 Strut bar - 250 Light kit - 260 Short throw shifter - 260 The rest was tax and labor |
| The Following User Says Thank You to Scavanger For This Useful Post: | sanmarcosfrs (02-21-2014) |
#40 |
Drives: 16 CBS WRX Limited
Goddamn I wish I had 5k to drop like that.
| The Following User Says Thank You to AznBRZer For This Useful Post: | Scavanger (02-21-2014) |
#41 |
| The Following User Says Thank You to Scavanger For This Useful Post: | AznBRZer (02-21-2014) |
#42 | |
Are the throws actually shorter or does it just stiffen it up? I guess I'm just wondering if it is worth it as an effective part or is it just another TRD expensive stupid part? |
| Buying computer parts compared to suspension parts | Anomie | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 12-09-2013 11:56 AM |
| [Group Deals] SoCal Subaru BRZ parts or Any Parts | Giccin | Southern California | 25 | 08-26-2012 10:30 AM |
