Old 02-20-2014, 02:43 PM   #3543
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Area86 View Post
I think mine was caused by a loose nut as well. I ordered a new terminal and should have it today.
I went ahead and pulled the blower yesterday to change the gear oil and switch the plastic fittings to brass ones as well as change all the hex bolts to the stronger ones from McMaster. I was trying to hold off and do everything when my intercooler arrived but they are still backordered for another month. Glad I did it now because my gear oil was fairly low and plastic fittings were really loose. I also replaced my #1 coil pack which was really easy to do.
Sent from my DROID RAZR using Tapatalk
Good call on changing out the hardware, i'm actually doing the same and reinstalling everything. if all goes well i should be back on the road tonight! Going to get started on it again here in a couple hours.
Here's how she looked when we decided to call it a night last night.
Old 02-20-2014, 02:46 PM   #3544
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Clean your TB
Ryan86 is offline   Reply With Quote
Old 02-20-2014, 02:49 PM   #3545
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by Carwhisperer View Post
I've gone through 3 on my NA motor.
Same coil pack that keeps blowing?
xxscaxx is offline   Reply With Quote
Old 02-20-2014, 02:50 PM   #3546
Ryan86
Road Warrior
Ryan86's Avatar
Originally Posted by xxscaxx View Post
Hasn't there been like 4 reported cases of the coil pack going?
If so, whats the big deal? replace it.
You could find a flaw in almost every kit out there, between melted fans, improper fitment, bumpers not going back on correctly, etc. I honestly feel this is the one of the most solid solutions out there, and i'm not just saying that being an owner of one.
When it comes down to it, you have to be prepared for things like this when putting forced induction onto an NA motor. In the grand scheme of things, even the other issues other kits have, its not even a big deal.
We have had 1 NA out of 1500 odd 86 in the last 2 years reported.
Of the 4 Sprintex kits installed in the last 5 months in Sa it now seems all 4 of us have had coil packs fail.
The Following User Says Thank You to Ryan86 For This Useful Post:
kombatlion (02-20-2014)
Old 02-20-2014, 02:52 PM   #3547
xxscaxx
There are a ton of us here in the US that haven't had issues...I haven't (yet).
Old 02-20-2014, 02:56 PM   #3548
xjohnx
Grip>Slip
xjohnx's Avatar
Clean your TB
It's not that bad in person, more the lighting than anything.
Old 02-20-2014, 03:12 PM   #3549
Ryan86
Road Warrior
Ryan86's Avatar
How many IC kits would you say have been installed in US? The other consideration is most have fitted over winter, have conditions been good enough to drive your cars properly?
Old 02-20-2014, 03:13 PM   #3550
sato
sato's Avatar
Drives: Dodge Patitas
Aren't there aftermaket coil offerings?
Sent from my C6906 using Tapatalk
sato is offline   Reply With Quote
Old 02-20-2014, 03:19 PM   #3551
xxscaxx
After installing a few times I question why the coolant pump plugs into the fI harness on cylinder 1 and wonder if this has anything to do with it?
Just a flying guess
Cylinder one is passenger side front. My plug is in cylinder 4, driver rear.
Where is your's plugged into?
I don't have the factual knowledge to provide how many kits have been installed in the US. I installed mine at the end of summer, it was hot.
If it seems to be the same coil pack going (I see cyl 1 a lot), maybe it is a flat out electrical issue.
Old 02-20-2014, 03:21 PM   #3552
xjohnx
Grip>Slip
xjohnx's Avatar
I installed mine in the beginning of the summer (june-ish?), no coil pack issues yet
Old 02-20-2014, 03:42 PM   #3553
Ryan86
Road Warrior
Ryan86's Avatar
I've got the pump harness on front right injector harness, looking at the motor.
You LHD guys confuse me lol
Old 02-20-2014, 04:25 PM   #3554
stockysnail
Just the tip
stockysnail's Avatar
Intercooler and 70mm pulley are going on hopefully in the next few days. I run 92oct gas so hopefully my stock injectors and fuel pump can handle the 70mm otherwise I'll need to stick with the 75mm. I've read having headers helps drop the psi a little as there's less restriction (I have JDL UEL). I also have the Perrin intake which supposedly helps a little. Crossing my fingers that I don't need anything else for it to work 100% and reliable!
Old 02-20-2014, 04:47 PM   #3555
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Another day, the more i bug Sprintex. Have info on pricing for the 210+ now but promised i wouldn't say anything yet.
As well my coolant level is now below the min line in the overflow bottle. The shop i had the install done at wants me to go to them to have it topped up, freaking 50 minute drive /sigh.
Also a Sprintex stage 2 is going to be installed by a Toyota dealer here shortly, not to a dealership car to sell. A customer has gone to them to do the install.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 02-20-2014, 04:51 PM   #3556
evan
Drives: fr-s
Out of all the blown coil pack issues, I have yet to see another person have to replace another or the same one, someone please correct me if i'm wrong.
It is NOT that hard to get to the coils on this car. I've owned a subie for 10 years. Might have slightly less space but it is not that bad.
My opinion may be skewed since I like working on cars, if you aren't a hands on guy then I can understand.
@evan - good post, but you aren't allowed to post anymore until we see a pic of your intake/airaid setup
I was going to take a pic and post, but it's at the shop getting 'grades. I'll post up a new dyno and pics in about a week.
evan is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
