#3515 |
Grip>Slip
| The Following User Says Thank You to xjohnx For This Useful Post: | swift996 (02-19-2014) |
#3516 | |
Road Warrior
Drives: Toyota 86 Satin Pearl White
Taking pipes off you lose about half a liter if that. I let the coolant run into a small 500ml jug, from the front pipe, once cooler empty remove rear. Just keep both ends elevated to stop gravity feed and lose more coolant. Suggest maybe some Castrol Engine cleaner, to spray over the engine and hose down with water when you done, to ensure you don't get the coolant drying on your engine. Red rubber grease which I'm sure you have from installation. Some things I did while kit was off. Resealed the L connectors Red rubber greased the manifold o rings Red rubber grease the SC main o ring Pulled the back off Sc checked for oil Most important check if you can see any signs of coolant leak into the manifold or the ports. I also got carb spray and cleaned out the manifold. |
#3517 | ||
Grip>Slip
AFR is going lean at higher RPM's. No vacuum leaks could be found. I spoke with Bill @ Delicious and after reviewing my logs he didn't see anything out of the ordinary (other than the lean condition). He suggested the two seals that go on top of the IC (pictured below, the ones that go in the machined channels at the top and bottom) can sometimes leak, so that's what I'm verifying. ![]() Quote:
#3518 |
Drives: 2013 Black FR-S
My intercooler kit didn't come with seals for those 2 channels. What exactly are those channels sealing?
#3519 |
Grip>Slip
#3520 |
WUB WUB
Drives: 2013 Firestorm
woo! i may have finally gotten the thing i need to make my (current) problems a thing of the past. new tensioner arrived, so now all that's left to do is install it, turn the one that's broken into a manual tensioner, and be happy.
| The Following User Says Thank You to wrxgoose For This Useful Post: | xjohnx (02-19-2014) |
#3521 | |
Drives: 2013 SWP BRZ
Permatex Tune Up Grease |
| The Following User Says Thank You to xxscaxx For This Useful Post: | xjohnx (02-19-2014) |
#3522 | |
Drives: Raven FR-S
I don't have those o ring seals installed on my kit. I ordered my kit through fa20club along with their "custom" intercooler kit and Toni told me that those seals weren't needed.....I have them now since I went with the standard innovate intercooler but haven't installed them. I'm not looking forward to taking the blower off and installing these IF they really are necessary.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
#3523 | |
Road Warrior
If it's the 3 on each adapter it is most definitely needed, as they stop coolant and boost leaks in the core. |
#3524 | |
Road Warrior
While you have the cooler out, if you can take to your nearest radiator shop and have them pressure test the cooler. That's where I found my leak. There 4 tubes in the core each have o rings, which did not seal. Test under 1 bar up to 1.5 bar pressure under water. Use your adapter plugs in the cooler, that will also tell you if they sealing. |
#3525 | |
Drives: Raven FR-S
I'm referring to the rubber strips that fit in the grooves on top of the laminova core
#3526 |
BAMF
Any word on the release of the upgraded blower? I tried searching but my phone doesn't support typing into the popup for the search.
#3527 |
#3528 |
BAMF
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
