Old 02-17-2014, 06:41 PM   #99
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
Bayson R Motorsports Bodykits (good or bad)
Originally Posted by OURO3OROS View Post
Did you bolt or tape or both?
I tried to use the bolts that come with it, but it's seriously a pain in the ass. The tape that's pre-mounted on it works just fine.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 02-17-2014, 06:43 PM   #100
OURO3OROS
Drives: 2013 Asphalt FR-S
I'm having a shop install it this weekend. I can't wait to get rid of the stock one. I ordered the frs without it, but it came with it anyway.
OURO3OROS is offline   Reply With Quote
Old 02-18-2014, 12:01 PM   #101
Tim_Asphalt_FRS
Is it fast? No.
The stock Scion spoiler is one of the ugliest things I've ever seen.
The Following User Says Thank You to Tim_Asphalt_FRS For This Useful Post:
weedtank (02-18-2014)
Old 02-18-2014, 12:56 PM   #102
sirsol66
Drives: 2013 FRS- Hot Lava
Does this cover the holes from the OEM spoiler?
sirsol66 is offline   Reply With Quote
Old 02-18-2014, 01:26 PM   #103
Tim_Asphalt_FRS
Is it fast? No.
Yes.
Old 02-18-2014, 04:35 PM   #104
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Mounted my front lip up for good today. I came across some cracked apr brake cooling ducts so I repaired and installed them as well. I ran into some fitment issues running them that I did not have with the factory grilles. I'm guessing the issue the other guy had with the foglight bezels was similar. I had to shave a bit down where the lip wraps around into the bezel area. Would have had to do the same with an oem lip as well because the apr ducts are thicker than the oem bezels. I'll upload some pics later
The Following User Says Thank You to spitfire481 For This Useful Post:
Midarete (02-18-2014)
Old 02-18-2014, 09:40 PM   #105
aSaki
Yep that's the exact problem I was talking about. Lets see how yours turned out, I'm waiting for winter to finish before I work on the car.
aSaki is offline   Reply With Quote
Old 02-18-2014, 10:58 PM   #106
spitfire481
Drives: 2JZ FRS
heres where im at currently. no double sided tape, no clips underneath, no clips/screws in the wheel well section. just two screws in the plate frame section in the factory mounting spots. it is attached just like the oem is supposed to and fits very well, especially for having to tweak it after i decided to run the apr ducts.
jarednoel (11-06-2014)
Old 02-18-2014, 11:03 PM   #107
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
*snip*
Looks good! May I ask how you painted the black trim? Is it just a flat black, or is there a specific trim paint one can use?
Joe-G is offline   Reply With Quote
Old 02-18-2014, 11:11 PM   #108
spitfire481
Drives: 2JZ FRS
I used black ppg basecoat and clear with flattener mixed in here at the shop. sem euro trim black out of a spray can is a nice product though
Old 02-18-2014, 11:11 PM   #109
sirsol66
Can someone with the side skirts take some underbody photos? I'm curious to see the mounting points. Thanks in advance.
Old 02-18-2014, 11:16 PM   #110
spitfire481
Drives: 2JZ FRS
I'm hoping to have mine on over the weekend. Looks like a straight bracket that mounts to the skirt, then there is a 90 degree bend/channel that looks like it slides up on the pinch weld and has a set screw to keep it in place. Nothing permanent
Old 02-18-2014, 11:17 PM   #111
FRSHunter
Drives: Asphalt FRS
Is it possible to mount the front lip without bolting it behind the license plate? I was trying to avoid any drilling to the front bumper.
FRSHunter is offline   Reply With Quote
Old 02-18-2014, 11:24 PM   #112
spitfire481
Drives: 2JZ FRS
I had it without the screws but there were gaps and it was just too loose. I tried some tape but there are only two small spots where you can tape it and it just wasn't enough
Bayson R lip kit review Cjymiller Cosmetic Modification (Interior/Exterior/Lighting) 59 07-06-2017 02:23 PM
Weather strip/Rubber seal for bodykits FRSHunter Cosmetic Modification (Interior/Exterior/Lighting) 4 03-08-2016 05:34 AM
Weatherstrips for bodykits FRSHunter Exterior Parts (Aero, Lighting, Etc.) 1 12-14-2013 10:15 PM
Who has Bayson R Lip kit? Cjymiller Northern California 21 09-29-2013 10:52 AM
Bodykits....Bodykits....Bodykits.... FT-86GOD AUSTRALIA 78 08-08-2012 10:44 AM
