Old 02-12-2014, 02:12 PM   #43
jamesm
Wow a proper rotational firing order, rare on kits for these cars. I thought mine was the only one that had that . Good job!
The Following 2 Users Say Thank You to jamesm For This Useful Post:
Nasty Sausage (07-06-2014), ptuning (02-12-2014)
Old 02-12-2014, 05:09 PM   #44
ptuning
ptuning's Avatar
Drives: White FR-S
Originally Posted by Victor Draken View Post
Will Nameless EL header Fit with this kit?
It should if it can bolt up to a factory overpipe.
ptuning is offline   Reply With Quote
The Following User Says Thank You to ptuning For This Useful Post:
Old 02-12-2014, 05:14 PM   #45
ptuning
ptuning's Avatar
Drives: White FR-S
Originally Posted by OICU812 View Post
@ptuning
When will that header be available, any eta? Also will there be coating options? Looks good so far that's for sure.
Also wondering if any more work on additional frame bracing has went under way since this design loses the diagonal stock bracing etc...
We're working on an ETA right now and will provide updates as soon as we can. We personally are not fans of coatings or header wrap. Heat radiation from our uncoated/unwrapped header should not be an issue at all. We do not need any additional bracing either, since the weight of our overpipe and turbo are supported by a beefy bracket off of the transmission. The header itself only needs to support it's own weight, which with a tubular (non weld-el) header, will be very lightweight. Hope this answers your question.\
- Toan
Old 02-12-2014, 05:17 PM   #46
ptuning
ptuning's Avatar
Drives: White FR-S
Originally Posted by cdrazic93 View Post
I hate asking so many questions...
I know the kit comes with a down pipe and over pipe..I plan on running this kit with a catless header. Is it possible to fit a catted down pipe?
It would be possible to add a cat to your exhaust intermediate pipe rather than our downpipe.
Old 02-12-2014, 06:35 PM   #47
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Im assuming intermediate pipe is the same as mid pipe...that clears things up a lot!!
Old 02-13-2014, 03:20 AM   #48
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
- Toan
I meant the removal of stock diagonal bracing. Sometime ago it had been mentioned somehow you guys were working on an alternative to that chassis bracing. Not turbo related but related to them having to be removed due to your IC design.
Old 02-13-2014, 06:28 PM   #49
mkivsoopra
Coming down the final stretch. I have a question though... what radiator are you guys using? I have the Robispec and it seems to be a little bit too big.
@ptuning
mkivsoopra is offline   Reply With Quote
The Following 4 Users Say Thank You to mkivsoopra For This Useful Post:
Alltezza (11-08-2015), mnsayer (03-11-2014), Mrc@ptuning (02-14-2014), Sonolin (02-17-2014)
Old 02-13-2014, 06:32 PM   #50
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Looking good! As for radiator on my end - stock.
rb6freak is offline   Reply With Quote
The Following User Says Thank You to rb6freak For This Useful Post:
mkivsoopra (02-13-2014)
Old 02-13-2014, 07:44 PM   #51
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
Has anyone in the PNW bought this kit? I'd pay for a ride along... Would like to see how the P-tuning kit compares to the AVO.
OjiGeorge is offline   Reply With Quote
Old 02-14-2014, 12:00 PM   #52
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
@ptuning
We're running the koyo racing radiator on our FRS. We've install the same radiator to @kanundrum frs as well as selling the same radiator to a few of our customers out of state that have also purchased our turbo system. We anticipated that most people running our turbo system will upgrade to an aftermarket radiator so we made sure our FMIC clears the thicker radiator core like the Koyo.
If you notice that with our FMIC, we used the largest Bell Intercooler core possible but still allow ample clearance above the FMIC and below the bumper beam to allow some fresh air to flow directly to the radiator and not just heated air from the backside of the FMIC.
MrC
Mrc@ptuning is offline   Reply With Quote
The Following 2 Users Say Thank You to Mrc@ptuning For This Useful Post:
Alltezza (11-08-2015), mkivsoopra (02-14-2014)
Old 02-14-2014, 12:22 PM   #53
jamesm
damn that's sexy in black.
cdrazic93 (02-14-2014), Sonolin (02-17-2014)
Old 02-14-2014, 04:43 PM   #54
andrew20195
Drives: 2013 Subaru BRZ
That is the setup I was considering. Is it actually interfering with the piping, or intercooler?
andrew20195 is offline   Reply With Quote
Old 02-14-2014, 05:10 PM   #55
mkivsoopra
The front bottom pushes forward, making the AC condenser contact the intercooler, and the rear top is pushed farther into the engine bay, so you can't use the intake shroud pieces that come with the turbo kit. You can make it work... I'd just rather not.
The Following User Says Thank You to mkivsoopra For This Useful Post:
andrew20195 (02-15-2014)
Old 02-19-2014, 12:20 PM   #56
bjun
bjun's Avatar
Drives: white premium brz M/T
Finally, I will be joining you guys with the turbo! Driving to PTuning on March 10 to get the turbo installed and tuned!
bjun is offline   Reply With Quote
The Following User Says Thank You to bjun For This Useful Post:
rb6freak (02-26-2014)
ptuning, turbo kit
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 11:46 AM
Full Blown Turbo Kit Owners Topic King Tut Forced Induction 2637 12-27-2020 04:44 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 07:27 PM
