Old 02-11-2014, 10:00 PM   #43
kALMIGHTY
Drives: TRD Ultramarine '13
Originally Posted by tbrocato View Post
I posted another thread about the weight of the wheels...I should of attached it on this thread! If I was to go 18 X 7.5...would I need to do anything suspension wise on the vehicle? I am a noob when it comes to anything about all the setup stuff on aftermarket wheels.
You wouldn't have any problems clearance wise. In fact, the wheels would still look tucked into the wheel wells, so you might even need spacers to bring out the wheels a bit. These wouldn't do much for the gap either, depending on the tire diameter you go with, so you'd still need a drop to get rid of the gap in the fender well if that's what you're going for. So springs + spacers is a must if you want a flush look with these wheels.
The Following User Says Thank You to kALMIGHTY For This Useful Post:
tbrocato (02-12-2014)
Old 02-11-2014, 11:31 PM   #44
nosi9frs
nosi9frs's Avatar
Drives: Raven FR-S
TRD USA Wheels
No you won't need spacers or anything. These are TRD wheels and are designed for the car. These tires have a +35 mm offset which is much more aggressive than the stock tires +48 mm offset which means the tires will be pushed out 13 mm making then much less tucked
nosi9frs is offline   Reply With Quote
The Following 2 Users Say Thank You to nosi9frs For This Useful Post:
Speeeddemon99 (02-12-2014), tbrocato (02-12-2014)
Old 02-12-2014, 10:16 AM   #45
FRSure
Drives: Toyota
Despite being a TRD Part, wouldn't the speedometer be slower because it's 18 inches?
FRSure is offline   Reply With Quote
Old 02-12-2014, 10:54 AM   #46
nosi9frs
nosi9frs's Avatar
Drives: Raven FR-S
Technically yes, however it's insignificant, but it solely depends on what tires you're running
http://www.rimsntires.com/specspro.jsp
The Following User Says Thank You to nosi9frs For This Useful Post:
Old 02-12-2014, 04:40 PM   #47
scottsampaio.com
scottsampaio.com's Avatar
Drives: 2013 Scion FR-S 6MT Argento
I like them, too bad there aren't other color options. I don't know gunmetal or something... wonder if those center caps will fit on stock rims lol
scottsampaio.com is offline   Reply With Quote
Old 02-12-2014, 04:43 PM   #48
frs10
Drives: tezla
oh sorry, i dont have an extra $10k laying around for those wheels...
frs10 is offline   Reply With Quote
Old 02-12-2014, 04:50 PM   #49
Speeeddemon99
Drives: 2014 Raven FR-S monogram
What tire size should I be getting to keep it from messing with my speedometer?
Speeeddemon99 is offline   Reply With Quote
Old 02-12-2014, 05:57 PM   #50
nosi9frs
nosi9frs's Avatar
Drives: Raven FR-S
TRD USA Wheels
Stick with 225/40R18 it's what they recommend for the rear. I would get that size all around, your speedo will be off by about 1 mph on the high side.
Old 02-12-2014, 06:00 PM   #51
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Where are you seeing $10k at?
Old 02-12-2014, 06:46 PM   #52
nosi9frs
nosi9frs's Avatar
Drives: Raven FR-S
They're $1036 for a set
Old 02-12-2014, 08:50 PM   #53
frs10
Drives: tezla
oh i just assumed since they were TRD they were gonna be priced like the JDM TRD set...
Old 02-12-2014, 09:40 PM   #54
sirsol66
Drives: 2013 FRS- Hot Lava
This TRD is NOT Japan TRD.
Japan TRD is a part of Toyota Motor Company. This TRD is a part of Toyota Motor Sales. Most of the parts are sourced through local suppliers you guys would buy from anyways (Enkei, Eibach, etc.). Even the forged Tundra wheel is not a couple thousand dollars a set, so I would guess this will be at or around $1000 for the 4.
sirsol66 is offline   Reply With Quote
Old 02-12-2014, 10:22 PM   #55
Andrew025
Andrew025's Avatar
That still doesn't answer my question.
Old 02-12-2014, 10:51 PM   #56
nosi9frs
nosi9frs's Avatar
Drives: Raven FR-S
It's called google ==> http://www.toyotaracing.com/trd/part...categories=all
259 x 4 = 1036
If you argue with math you will lose
Forgestar F14 wheels and Enkei wheels: <<RPF1 18x9.5/NT03+M 18x9.5 In Stock>> b2autodesigns Wheels and Tires 850 09-10-2017 09:29 AM
Team Dynamics Pro Race 1.3 Wheels (Track wheels) CHEAP!!!! Evasive Motorsports Wheels and Tires 4 07-29-2013 09:46 PM
Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! stratodyne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2013 03:21 PM
Wheels, Wheels, Wheels | Island Import Performance IslandImportPerformance Wheels and Tires 4 07-31-2012 11:08 PM
