#43 | |
Drives: 08 IS-F, 02 IS520, 09 Tundra
but I guess the next one will be easier eh?Mike |
#44 |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
Hopefully there won't be a next one for me, lol. And again, I'm doing this as someone who has never done this before. I said in the beginning that I might take extra steps that others wouldn't, and me doing it the way I am does involve a little bit of trial and error but makes me content in my own head. For me to be content I wanted all new. Others will be content with reusing what they have. Also the way I'm doing it leaves no stone unturned. So anyone else who might need to do even one of the many things I am doing will be able to by seeing what I have done. Example, when these cars reach 100k plus, maybe someone will need to replace an axle seal or replace a carrier bearing. Here's the DIY for that as well.
#45 |
Twin Screw You
Backlash is set on the differential. This hopefully will be installed this weekend. I'm replacing the carrier bushings and hope they will be finished by the weekend so I can finish the install.
#46 |
Twin Screw You
Installed and DONE!!! First post updated. Thanks for bearing with me. It took longer than expected, but the end results are well worth it.
#47 | |
Drives: FR-S 6MT
You did a good job expressing how important it is to get the preload and clearances correct for this job.. It doesn't take but being off a little bit to destroy a set of gears.. Nice job! Enjoy! |
| The Following User Says Thank You to Mikem53 For This Useful Post: | Dustin (01-27-2014) |
#48 | |
Twin Screw You
And yes, checking clearances and making sure everything is spot on when installing a diff or a new final drive is THE MOST important part about doing this. If anyone else attempts this and has any questions or concerns, please feel free to PM me and I'll be happy to answer any questions to the best of my ability.
#49 |
Twin Screw You
Updated 2nd post with initial thoughts.
#50 |
Drives: Scion FRS
This was great info and a great write up! Definitely doing this in the next year or so.
| The Following User Says Thank You to Freshfrs86 For This Useful Post: | Dustin (02-07-2014) |
#51 |
Shipping to Hawaii?...
Drives: '13 Asphalt FR-S
Nice DIY. Anyone else having a hard time putting the axle back into the diff? I'm wailing on it with a rubber mallet and punch on the same pry lip but nothing moves. Tried a heavier hammer and just didn't want to over do it. Any suggestions?
~Matt
Efimia (asphalt FRS) |
#52 | |
Twin Screw You
Also I hit here with a regular hammer and not a rubber mallet.
#53 | |
) and then just pounded it in (again that's what she said) with a wide punch on that pry lip. Anti rust on the hub end and bolted it down nicely.Seriously thank you. I would've been at a lost without your DIY. ![]() Buy you a case of beer for you and your brother if you're ever in Hawaii.
~Matt
#54 |
Drives: Brz
What brand is your fd?
any noise? |
#55 |
Drives: Brz
I just installed my fd
But it had some noise like cranking metal sound |
#56 |
Drives: Brz
What brand is ur fd?
any noise? |
| Mfactory Final Drive Ring and Pinion | Crossover Auto | Engine, Exhaust, Transmission | 87 | 05-26-2017 03:21 AM |
| Considering going to 3.727 gear/pinion in 6MT | HotLavaMann | Engine, Exhaust, Transmission | 83 | 01-10-2015 11:34 AM |
| 3.9 final gear - ring and pinion | PantsDants | Engine, Exhaust, Bolt-Ons | 5 | 11-08-2013 04:06 AM |
| MFactory Ring and Pinion Sets | JMPoole | Engine, Exhaust, Bolt-Ons | 14 | 07-31-2013 01:09 PM |
| Differential and Transmission Fluid Swap with Red Line Oil - 2013 Subaru BRZ | JPxM0Dz | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 05-05-2013 06:12 PM |
