Old 02-11-2014, 02:24 PM   #1
derek9010
Drives: asphalt
Camber correction
Just installed Rs-r Super Down springs, also have 20mm spacers in the front and 25 in the rear. I was just wondering as to whether I only need front camber bolts and rear lower control arms?
derek9010 is offline   Reply With Quote
Old 02-11-2014, 10:58 PM   #2
wparsons
wparsons's Avatar
Depends on what your camber is now and how much you want to adjust it. Bolts up front will give you an adjustment range of around +/- 1*, possibly more. The rear LCA's will give you a much bigger range, but if you're adjusting it too much you'll also need aftermarket toe links or you'll run into issues getting the rear toe within spec.
flickr
Old 02-12-2014, 01:09 AM   #3
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
How low is your car? Measure from center of hub to edge of wheel well.
mwjcyber is offline   Reply With Quote
Old 02-12-2014, 02:24 PM   #4
derek9010
Drives: asphalt
This doesn't really help. They are suppose to drop 1 inch in the front and 1.2 in the back.
Old 02-12-2014, 02:29 PM   #5
CSG David
CSG David's Avatar
Camber bolts or rear lower control arms are not absolutely necessary but they are nice to have to increase or reduce camber settings. What you do need is to get the toe aligned properly so you don't eat at your tires. If you want more or less camber, then purchase the camber bolts or LCA. Will PM you.
Old 02-12-2014, 08:38 PM   #6
derek9010
Drives: asphalt
Ok exactly what I wanted to know. Thanks
Old 02-22-2014, 08:35 AM   #7
BRZ888
BRZ888's Avatar
Drives: 2014 Toyota GT86
Does anyone has the stock alignment specs? I lowered my car using Tein Street advance about 1" and i wanted to know the spec of the alignment.
BRZ888 is offline   Reply With Quote
Old 02-22-2014, 10:35 PM   #8
wparsons
wparsons's Avatar
0* camber front, -1.5* camber rear IIRC, not sure of the caster up front or toe at either end.
flickr
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 11:09 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
Enjuku Racing - Whiteline Control arm inner bushing (camber correction) Enjuku Racing Brakes, Suspension, Chassis 0 04-11-2013 12:21 PM
WORKS Rear Upper Control Arm Bushing - Inner Camber Correction 86_ZN6 Brakes, Suspension, Chassis 0 02-06-2013 01:20 AM
