Old 02-11-2014, 12:07 PM   #15
DC2R
Drives: 2014 Scion FR-S
Possible workaround is to copy all Google contacts to SIM. Not the most graceful solution but it should work. This is how I keep my exchange and Gmail in sync. Every six months I wipe my Gmail contacts and update from exchange
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 02-11-2014, 12:41 PM   #16
mid_life_crisis
Drives: FR-S 10 #103 AT
Problem I have with that as a solution is that many of my contacts have multiple numbers, home, work, etc. The simm will only store one number per contact, so you need to make a separate entry for each number.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 02-11-2014, 02:40 PM   #17
IronSean
Drives: 2006 Toyota Camry
If you're running stock android (ie, Samsung has it's own Samsung Bluetooth stack that none of this applies to) they recently re-wrote the entire thing for either 4.3 or 4.4. It added the ability to run in BLE (Bluetooth Low Energy) and to send audio information like title and artist information. These didn't work before. However, though in my experience things mostly improved, there could still be some weirdness to it.
And then, as I mentioned earlier, other OEMs like Samsung could be using their own thing entirely. For instance, Samsung was sending artist information since 4 or 4.1 at least, if not longer.
IronSean is offline   Reply With Quote
Old 02-11-2014, 04:13 PM   #18
1ucky11
Drives: 2013 Scion FR-S whiteout
Hey guys, new update. I just played around with my phone. and got it to transfer my contacts to the radio. Under the contacts, it looks like all sim card contacts are listed, but under settings you can just import all contacts in sim to the phone. yes, you'll have two entries for each person, but, it finally allowed me to transfer all contacts to the HU. Hope that helps some of you.
1ucky11 is offline   Reply With Quote
Old 02-11-2014, 04:40 PM   #19
DC2R
Glad to hear. Anyone running touchwiz with 4.3? Messages coming in is wonky and I can't get Pandora to show any information on screen of head unit but it does stream(poorly)
Old 03-12-2014, 02:53 PM   #20
RMStringer
RMStringer's Avatar
Drives: Scion FR-s Pearl White 6 Speed
Send a message via ICQ to RMStringer Send a message via Yahoo to RMStringer
I use Gonemad player and all my Metadata plays on Bespoke HU using Bluetooth. I worked with the dev on the 4.3 upgrade and i use Note II It is a system wide issue from samsung on the 4.3 upgrade.
RMStringer is offline   Reply With Quote
Bluetooth Disconnects (Android 4.3) spookyz Electronics | Audio | NAV | Infotainment 12 01-14-2014 10:42 AM
Messages Never Downloading via Bluetooth - Android BRZprime Electronics | Audio | NAV | Infotainment 0 07-26-2013 02:06 PM
Bluetooth audio from android phone cgrey Electronics | Audio | NAV | Infotainment 10 07-11-2013 08:56 AM
Bluetooth fix for Android/Samsung users inimitable Electronics | Audio | NAV | Infotainment 27 05-10-2013 07:52 AM
Bluetooth connect mutes android NAV Rob_g Electronics | Audio | NAV | Infotainment 6 07-04-2012 05:38 PM
