#29 |
i have no idea. i'm sure they'd add them by request if nothing else. it's pretty specific to each setup. in either case it's a pretty simple thing to do. i didn't notice at the time or i'd have just had them add it to mine. the car had a hallman pro mbc on it before (actually it still does until my grimmspeed ebcs arrives) so i didn't need the compressor nipple until now, and the intake bit i don't need anyway because i plan to use their new dual vented catch can.
#30 | |
Drives: DGM BRZ Limited
Playing around with this turbo I found that the 6-blade non-gtx compressor sounds incredible. Like a jet engine spooling. The GTX doesn't make any noise. The T30 turbine does seem to be pretty restrictive given the size of the compressor. The GTX3576r is a better match overall, the smaller ar housings will want more boost to compensate. I like to keep the exhaust free-flowing, it lowers backpressure, EGTs, reduces pumping losses etc. The T350 turbine in the GTX3576r is much better suited for what the GTX wheel can flow. Don't forget that improving the exhaust backpressure will also improve VE, and depending on the engine can offset the loss of transient response gained by going to a larger volute. At least, this is what my personal testing shows. |
#31 |
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
you could always weld a -3 or -4 AN fitting to the compressor housing or the cooler pipe, then run Teflon braided lines for your plumbing. That's what I've been doing with my setups for the last few years now and never have to worry about melted hoses etc
#32 | |
. not so much as @Ironsquid's 35r, which is insane, but it's definitely there and noticeable.i haven't really decided for sure what i'll do for the turbo. the 3576r actually sounds like a decent option as well, and more people are pushing me towards the .82 housing. decisions decisions... |
#33 |
Drives: Sterling BRZ Ltd
what 35 is Ironsquid running? I havent seen any 35's other then fbm
#34 |
#35 |
King of Kiwi Palace
Drives: Faster than you
Hi, build in sig.
#36 |
Junior
Drives: a car
After reading the report...you say cooling isnt an issue, even in florida, where is the turbo mounted, if not the front?
#37 |
It's in the front. People's cooling issues don't come from where the turbo is mounted. They come from removing both of the stock fans and replacing them with slimlines that flow much less air. This kit retains one of the oem fans, which apparently makes a world of difference.
| The Following 2 Users Say Thank You to jamesm For This Useful Post: | MAPerformance (02-10-2014), TRD_07 (02-19-2014) |
#38 | |
Junior
Drives: a car
| The Following User Says Thank You to cdrazic93 For This Useful Post: | jamesm (02-09-2014) |
#39 |
Just a dude
Drives: Scion FR-S 2013
So when can we see some more detailed photos of this layout/design and some dynos? Eta to market sale?
#40 |
They had an announcement thread a while back with all the build pics. A search should turn it up. Dynos were posted way back when as well, made 260whp on a mustang off the wategate (~8psi). Recent dyno showed around the same... 257 on an md-150 @8-8.5psi. Pretty much the same as any other kit with a 28r.
#41 |
Drives: Pile of junk
next friday or the friday after next muahahha
EDIT: sorry i had to say it |
| The Following User Says Thank You to Frs300 For This Useful Post: | jamesm (02-09-2014) |
#42 |
Drives: AE86, 2x GT86, TE27
How much increased snatch should one expect with this kit?
That should always be a major consideration with any modification. |
| Treadstone Performance Turbo Kit Update! | kmbkk | Forced Induction | 277 | 01-17-2020 12:15 AM |
| MAPerformance Turbo Kit Officially Released! | MAPerformance | Forced Induction | 633 | 07-26-2014 11:42 PM |
| Revworks turbo kit initial review | jamesm | Forced Induction | 31 | 02-10-2014 07:42 PM |
| Rev Works turbo kit 2k mile update | jamesm | Forced Induction | 35 | 09-06-2013 02:17 PM |
| Turbo Market and Technology Update | circuithero | Forced Induction | 9 | 06-26-2013 09:27 AM |
