Old 03-07-2012, 08:01 PM   #1
gdi2290
Web Designer/Programmer
gdi2290's Avatar
Drives: WRB BRZ Limited (Lemon)
Post Everything BRZ: Price, Features, Allocations, Production Numbers, Spec. [v1.10]
This is crowdsource and independent research meant to help members to better assess his or her investment, so everything will be subject to change and correction. Although this thread focuses on the US model much of the information are the same internationally.
Boxer engine,
Rear-wheel drive
Zenith in passion
Specifications
"Subaru plans a longer life-cycle for the car, six to seven years instead of four to five, and it was strongly hinted that we would see a power bump during a mid-cycle refresh – but not a turbocharged bump" -Autoblog.com
BRZ Codes: Premium 6MT = DZA/01, Premium 6AT = DZB/01, Limited 6MT = DZE/01, Limited 6AT = DZF/01
Engine: FA20 aluminium alloy 4-cylinder 16 valve Subaru Boxer, DOHC 2.0 Liter (1998cc / 121.93 cu in)
Fuel Delivery: D-4S Direct and Port-injected
Transmission: Aisin 6-speed, Manual and Automatic
Valvetrain: Duel-Overhead Camshafts, Four Valves per Cylinder, Dual Active Valve Control System , Variable Valve Timing
Aspiration: Naturally Aspirated
Compression Ratio: 12.5:1
Bore and Stroke: 3.386 in x 3.386 in (86.0mm x 86.0mm)
Horsepower: 200 @ 7000 rpm
Wheel Horsepower: 170~175
Torque: 151lb/ft @ 6400-6600 rpm
Redline: 7400 rpm (7450 rpm fuel cutoff)
Drivetrain Layout: Front Engine/Rear-Wheel Drive
Front Suspension: Independent MacPherson Strut, Lower L-Arms, Coil Springs, Stabilizer Bar
Rear Suspension: Independent Double Wishbone, Coil Springs, Stabilizer Bar
Limited Slip Differential: Torque-Sensing
Weight Distribution: 55.7% Front, 44.3% Rear
Final Drive Ratio: 4.10:1
Steering: Electric Power Assisted Steering lock-to lock 2.48 turns
Steering Wheel: 14.4 in
Steering Ratio: 13.1:1
Turning Circle: 35.4 ft
Drag Coefficient: 0.27 Cd
Curb Weight: Premium 2762/2809 lbs , Limited 2776/2822 lbs
Length: 166.7 in
Width: 69.9 in
Roof Height: 50.6 in
Ground Clearance: 4.9 in
Wheelbase: 101.2 in
Wheels: 17x7 in, Dark Gray Aluminum Alloy
Track (Front/Rear): 59.8 in / 60.6 in
Brakes: 11.6 two-piston front / 10.4 single-piston rear, Power-assisted ventilated disc brakes
Tire Size: 215/45WR17 87W 35psi Michelin Primacy HP summer performance tires
Seating: 2+2
Body Style: 2 Door Coupe, Right-Side Fuel Door
Fuel: 91-93 AKI (95-98 RON) Octane Premium Unleaded Gas; maximum of 10% ethanol
Fuel Economy: 22/30 mpg (manual) / 25/34 mpg (automatic)
Fuel Tank: 13.2 US gal (50 L)
Oil Grade: International Lubricant Standardization and Approval Committee (ILSAC) multigrade engine oil
Oil Capacity: Without Filter 5.5 qt, Filter: 5.8 qt
Oil Viscosity: SAE 0W-20
Cooling System: Automatic: 7.9 qt, Manual: 7.6 qt
Spark Plug Make: DENSO ZXE27HBR8
Spark Plug Gap: 0.031 in. (0.8 mm)
Differential Oil Capacity: 1.20 qt
Differential Oil type and viscosity: Differential Gear Oil LX; API GL-5 and SAE 75W-85 or GL-5 and SAE 75W-90
Automatic Transmission Oil: ATF WS 7.9 qt
Manual Transmission Oil: 2.3 qt; “MG Gear Oil special II”; API GL-3 and SAE 75W-90
Clutch Fluid: FMVSS No.116 fresh DOT 3 or DOT 4
Brake Fluid: FMVSS No.116 fresh DOT 3 or DOT 4
Trunk Space: 6.9-cubic-foot (rear seats up)
Top Speed: 140 Mph
Acceleration 0-60 Mph: 7.3 seconds
Braking 60-0: 114 ft
1/4 Mile: 15.3 second @ 92.1 MPH
Slalom: 69.1
Skid Pad: 0.92 g
Center of Gravity: 18.1 in
Warranty
Basic Warranty: 3 yrs/36,000 miles
Powertrain: 5 yrs/60,000 miles
Corrosion: 3 years/Unlimited miles
Roadside assistance: 3 yrs/36,000 miles
Free scheduled maintenance: 1 year/10,000 miles
Break-in Period
Oil Change: 1000 miles
1000 miles Avoid: Aggressive Driving, Redlining, Constant Speeds, Extreme Acceleration, Long Road Trips, Cruise-Control, Extended Idling, Drag Racing, Top Speed, Towing, Drifting
Brakes: Avoid high-speed stops or dragging the brakes for 200 miles
Paint Protection: Apply Opti-Coat 2.0
Features
100% Subaru Engineering
Close-ratio 6-speed short-throw manual transmission
(Optional) Adaptive 6-speed automatic transmission with Sport mode and Paddle Shifters
Throttle Blip Function
Limited-slip rear differential
Aluminum Hood
Thinner Glass to reduce weight
17-inch aluminum-alloy wheels
Five Settings for Stability/Traction
High-Intensity Discharge (HID) Xenon Fully automatic headlights
Vehicle Dynamic Control (VDC)
Traction Control System (TCS)
Four-channel/four-sensor Anti-lock Braking System (ABS)
Electronic Brake-force Distribution (EBD)
Emergency locking retractor (ELR)
Automatic locking retractor (ALR)
Supplemental Restraint System (SRS) six airbags
Front, side, curtain and knee airbags
Steering wheel- tilt and telescope
Leather-wrapped steering wheel, shift knob, and brake handle
Black Cloth upholstery
Alcantara bucket seats
Power-adjustable foldable mirrors
Power windows and door locks
Aluminum alloy sport pedals
Dual exhaust with stainless steel tips
Brake Assist
Brake Override System
Cruise Control System
Alarm System
Engine Immobilizer System
Air-conditioning System
8-speaker HD Radio Audio system
Reinforced Frame System
PREMIUM
LED daytime running lights
6.1 in Display AM/FM/CD/MP3/WMA/DVD/DivX audio stereo 196-watt
Integrated audio and voice-activated GPS navigation system
Bluetooth audio streaming and hands-free phone connectivity
USB/iPod control and 3.5mm auxilliary jacks
HD Radio with iTunes tagging capability
SiriusXM Satellite Radio and NavTraffic
LIMITED
Bluetooth Keyless Access & Push Start Button
Smart Key Answer-back electronic chirp
Black Leather/Alcantara upholstery
Dual-Zone Automatic climate control
Heated front seats
Heated side mirrors
Fog Lights
Rear Trunk Spoiler
Individual Options
Fog Lights: (code QEM) $TBA late availability
Interior Illumination Kit: (code NEA) $280 late availability
10 in Subwoofer: (code DEA) $499 late availability
Rear Bumper Underskirt: (code QEX) $TBA
Chrome Fender Trim: (code QER) $TBA
Chrome Fuel Door Cover: (code QES) $TBA
Wheel Locks: (code H8B) $51
Trunk Cargo Tray: (code MEA) $75 late availability
Rear bumper paint protector applique: (code QEV) $80
Auto dimming rear view mirror with compass: (code KEA) $205
Auto dimming rear view mirror with compass and Homelink garage door opener: (code KEB) $281
Rear spoiler, body colored: $567
Optional Packages
Popular Package 1A (code B1A). Includes Auto dimming mirror/compass/Homelink, Rear bumper applique', Wheel locks. $423
Popular Package 1B (code B1F). Includes Auto dimming mirror/compass/Homelink, Rear bumper applique', Chrome fender trim, Wheel locks $502
Popular Package 2A (code B1C). Includes Auto dimming mirror/compass/Homelink, Rear bumper applique', Interior Illumination kit, Wheel locks.
Popular Package 2B (code B1D). Auto dimming mirror/compass/Homelink, Rear bumper applique', Cargo tray, Interior illumination kit, Wheel locks.
Popular Package 2C (code B1E). Includes Auto dimming mirror/compass/Homelink, Rear bumper applique', Chrome fender trim, Cargo tray, Wheel locks. $TBA late availability
Dealer Installed Options
Engine block heater
Battery warmer
Ash tray, ashtray holder, cigarette lighter
SPT battery tie down
SPT Oil filler cap
Owner's Manual
Decoding
(Combined Version)
TABLE OF CONTENTS
For your information
Symbols used throughout this manual
Section 1 - Before driving
Section 2 - When driving
Section 3 - Interior features
Section 4 - Maintenance and care
Section 5 - When trouble arises
Section 6 - Vehicle specifications
Section 7 - For owners
Index
What to do if...
Colors
WR Blue Mica (Metallic)
Sterling Silver (Metallic)
Satin White Pearl (Pearl)
Crystal Black Silica (Metallic)
Dark Grey Metallic (Metallic)
Galaxy Blue Silica (Metallic)
Lighting Red
(Solid)
Reviews
Top Gear
Car and Driver
Motor Trend
Wall Street Journal
Car Magazine
Evo Magazine
Automotive Magazine
Jalopnik
Pre-Order List
Most people, if not everyone, here said they're getting $500 refundable pre-order with guaranteed MSRP
Official BRZ Pre-Ordered Database
Official BRZ Pre-Order Map
Official BRZ Dealership Blacklist
Initial Allocations for Dealerships
"It is important dealers fully understand the order filling process as you submit your sold orders. In summary, allocations for the 7 months May-November have been developed for each dealer. Fulfillment of a dealer’s allocation quantity will be spread basically pro-rata over the 7-month period and will not accelerate based on the number of sold orders submitted nor will it be reduced based on the number of sold orders other dealers submit. The most important factor is for individual dealers to ensure their sold orders are submitted in the order with which they want them filled. SOA will look to fill the oldest sold order within a dealer’s allocation from the pool of cars available irrespective of when that order came in versus any other dealer’s order." -Subaru of America
"Keisuke Kirimoto officially confirmed that there are no production limits, and that they will sell as many as possible."
Dealerships in Red are blacklisted as BAD dealerships
Post your dealership and allocation amount for them to be added to the list
50 Renick Subaru, Fullerton California
35 Irvine Subaru, Lake Forest California
35 Capitol Subaru, San Jose California
35 Stevens Creek Subaru, San Jose California
17 Carlsen Subaru, Redwood City California
15 Livermore Subaru, Livermore California
15 Sierra Subaru, Monrovia California
14 Puente Hills Subaru, Industry California
11 Kearny Mesa Subaru, San Diego California
10 Subaru of Sherman Oaks, Van Nuys California
10 Frank Subaru, National City California
10 Bob Baker Subaru, Carlsbad California
2 Lithia Subaru of Fresno, Fresno California
21 Gillman Subaru Southwest, Houston Texas
14 West Houston Subaru, Houston Texas
9 Gillman Subaru North, Houston Texas
14 Subaru of Plano, Plano Texas
12 Subaru of Austin, Austin Texas
10 North Park Subaru, San Antonio Texas
7 Sewell Subaru of Dallas, Dallas Texas
6 Garcia Subaru, El Paso Texas
4 Huffines Subaru Denton, Denton Texas
3 Darrell Waltrip Subaru, Franklin Texas
. Hiley Subaru, Fort Worth Texas
11 Hatfield Subaru, Columbus Ohio
10 Ganley Westside Subaru, North Olmsted Ohio
9 Brunswick Subaru, Brunswick Ohio
7 Wagner Subaru, Dayton Ohio
7 Beechmont Subaru, Cincinnati Ohio
2 Waikem Subaru, Massillon Ohio
2 Park Subaru, Akron Ohio
2 Cascade Subaru, Cuyahoga Falls Ohio
12 Lancaster County Subaru, East Petersburg Pennsylvania
8 Fred Beans Subaru, Doylestown Pennsylvania
8 A&T Subaru of Sellersville Pennsylvania
7 #1 Cochran Subaru, Pittsburgh Pennsylvania
4 W&L Subaru in Sunbury, Northumberland Pennsylvania
. Colonial Subaru, Feasterville Pennsylvania
13 Subaru of Annapolis, Annapolis Maryland
10 Fitzgerald Subaru, Rockville Maryland
9 Herb Gordon Subaru, Silver Spring Maryland
3 Frederick Subaru, Frederick Maryland
. Fitzgerald Auto Mall, Gaithersburg Maryland
9 Bloomington Acura Subaru, Bloomington Minnesota
9 Morrie's Minnetonka Kia Subaru, Minnetonka Minnesota
6 Morrie's Brooklyn Park Nissan Subaru, Brooklyn Park Minnesota
5 Walser Burnsville Subaru, Burnsville Minnesota
16 Grand Subaru, Bensenville Illinois
16 Autobarn Subaru of Countryside, Countryside Illinois
15 Evanston Subaru, Evanston Illinois
11 Napleton's Subaru, Rockford Illinois
6 Hodges Subaru, Ferndale Michigan
5 Dunning Subaru, Ann Arbor Michigan
2 Williams Subaru, Lansing Michigan
2 Dwyer Subaru, Waterford Michigan
20 Carter Subaru, Shoreline Washington
18 Chaplins Subaru, Bellevue Washington
16 Walkers Renton Subaru, Renton Washington
12 Don Miller Subaru, Madison Wisconsin
6 Don Miller Subaru East, Madison Wisconsin
6 Don Miller Subaru West, Madison Wisconsin
13 Bob Moore Subaru, Edmond Oklahoma
7 Ferguson Subaru, Broken Arrow Oklahoma
6 Hudiburg Subaru, Oklahoma City Oklahoma
16 Mastro Subaru, Tampa Florida
10 Mastro Subaru, Sanford Florida
7 Sport Subaru and Mitsubishi, Orlando Florida
1 Romain Subaru, Evansville Indiana
1 Nielson Subaru, Portage Indiana
2 Bryan Subaru, Metairie Louisiana
5 Baldwin Motors Subaru,Covington Louisiana
25 Patrick Subaru, Shrewsbury Massachusetts
7 Steve Lewis Subaru, Hadley Massachusetts
49 Manchester Subaru, Manchester New Hampshire
20 Subaru of Keene, Keene New Hampshire
11 Subaru of Cherry Hill, Cherry Hill New Jersey
4 Miller Subaru, Lumberton New Jersey
4 Landers McLarty Subaru, Huntsville Alabama
. Koby Subaru, Mobile Alabama
8 Delta Imports, Grand Rapids Michigan
7 Johnson Subaru of Cary, Cary North Carolina
6 Subaru of Richmond, Richmond Virginia
3 Troncalli Subaru, Cumming Georgia
12 Continental Subaru, Anchorage Alaska
22 Carr Subaru, Portland Oregon
5 Servco Subaru, Honolulu, Hawaii
3 Paul Moak Subaru, Jackson Mississippi
7 Adventure Subaru, Fayetteville Arkansas
2 Belknap Subaru, Tilton New Hampshire
7 Lee's Summit Subaru, Kansas City Missouri
4 Briggs Subaru, Lawrence Kansas
23 Subaru of Las Vegas, Las Vegas Nevada
Speculations of Price
Redesign of WRX will probably increase it's price since it's not sharing the Impreza platform
BRZ said to cost 1k more than FR-S
Automatic said to add $1.1k
Destination Charge $700-$750
BRZ Price
"Subaru does say that the BRZ will start at about $25,000"
"STI: It is likely to produce around 250bhp. "We can definitely develop the intake system," Atake said. "There is certainly room for improvement there." In addition, there is likely to be a freer-flowing exhaust and modifications to the engine's variable valve control system, along with an even higher rev limit of around 7,500rpm. As well as more power, the BRZ STI is set to weigh even less than the 1,250kg standard car, thanks to racing bucket seats and potentially a carbonfibre roof and bonnet, which will further help to lower the car's centre of gravity. Other tweaks will include a dramatic bodykit, stiffened and lowered suspension, lighter but larger 18-inch alloy wheels and upgraded brakes."
No Turbo Version Ever
2013 BRZ
(FR-S is the base model)
Premium: Manual $25,495; Automatic $26,595
Limited: Manual $27,495; Automatic $28,595
STI (30k-35k?)
2013 FR-S
Manual: $24,200
Automatic: $25,300
TRD ?
Five-Axis ?
2013 WRX
Base: 25.5k
Premium: 28k
Limited: 29k
STi: 34k
STi Limited: 37.4k
2015 Redesign WRX
29k?
Speculations of Production Numbers
"As you might expect of such a vehicle, the all-new Subaru BRZ will be built in extremely limited quantities. The rare driver lucky enough to own one will experience Subaru engineering distilled to its essence." -Subaru.com
Toyota will get a "vast majority" of the production
The convertible version next year (2013) after release in Japan
(these numbers are purely guessing to give you an idea until we can confirm the right amount)
2700 Pre-Ordered in USA
2600 Ordered in Japan
500 a month for North America (BRZ)
6000 a year for North America (BRZ)
500 a month for Europe (BRZ)
500 a month for Asia (BRZ)
7000 Ordered GT 86 in Japan
10,000-15,000 for the first year (FR-S)
750 a month for North America (FR-S)
500 a month for Europe (GT 86)
1000 a month for Asia (GT 86)
Goal of 100,000 BRZ/GT86/FR-S a year
Release Date
Pre-Orders will have priority.
BRZ and FR-S
On sell April 20th
Most dealerships will have 1 a month to begin with
In Dealerships as early as May and as late as November
BRZ STI
Might be in August
gdi2290 is offline   Reply With Quote
The Following 7 Users Say Thank You to gdi2290 For This Useful Post:
denkigrve (07-10-2012), Giccin (08-07-2012), grst1 (05-08-2012), hav0c (07-25-2012), LivingLegend (05-22-2012), NRGBalanced (05-25-2012), Tad_07 (07-07-2012)
Old 03-07-2012, 08:05 PM   #2
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
BRZ 25k (base)
BRZ Limited 30k
Speculation of Production Numbers
540 per month
Las Vegas is to get 23 for the year.
Where are you getting the $30k for the limited? It should be more like $27k.
tranzformer is offline   Reply With Quote
Old 03-07-2012, 08:06 PM   #3
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
the list is pretty much useless.. =/
some dealerships are either trying to mark up the price or making you feel better
Also nobody will buy limited if the price is 5k difference!
hanabie is offline   Reply With Quote
Old 03-07-2012, 08:09 PM   #4
gdi2290
gdi2290's Avatar
that wasn't base limited it was more of spec'd out version I'll fix it
the thread was meant to collect data and to help members better assess his or her investment
Old 03-07-2012, 08:11 PM   #5
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
49 Manchester Subaru, Manchester, NH
800 for Subaru of New England
sources:
http://forums.nasioc.com/forums/show...&postcount=637
http://forums.nasioc.com/forums/show...1&postcount=17
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 03-07-2012, 08:13 PM   #6
tranzformer
Drives: Zoom Zoom
Seriously? That is very impressive. Wonder if they will have any problems selling them that far north compared to a dealer in CA or FL?
Old 03-07-2012, 08:15 PM   #7
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Y no luv for San Diego Subaru dealerships!?!
Old 03-07-2012, 08:16 PM   #8
gdi2290
gdi2290's Avatar
I couldn't find the numbers or else I would. do you know how many they will have?
Old 03-07-2012, 08:18 PM   #9
tranzformer
Drives: Zoom Zoom
26 down, only another 574 left to go!
Old 03-07-2012, 08:32 PM   #10
gdi2290
gdi2290's Avatar
sources:
is that 800 number per year or an amount the dealership will be receiving?
Old 03-07-2012, 08:42 PM   #11
Longhorn248
Hook 'em
Longhorn248's Avatar
I believe Subaru of New England is the middle man between Subaru and a network of dealers in the New England area. My guess would be that's their allotment for the year. I may be incorrect though...
Longhorn248 is offline   Reply With Quote
Old 03-07-2012, 08:47 PM   #12
tranzformer
Drives: Zoom Zoom
Not bad considering there are 63 dealers in SNE territory. 800/63=12.7 That averages out to about 13 cars per dealership. Not bad.
Old 03-07-2012, 08:56 PM   #13
Spaceywilly
ZC6A2B82KC7J
Drives: 2002 WRX
It's the total allocation for the first allotment (May-Nov) for all the SNE dealers, although it doesn't seem like the most reliable information.
Old 03-07-2012, 08:58 PM   #14
RRnold
2 wheel member
RRnold's Avatar
I've emailed all 4 Subaru dealerships and so far only one dealership (Subaru of El Cajon) called me back. He couldn't provide with any details since their BRZ training isn't until the end of this month.
brz, dealership, features, prices, subaru brz
Brz Production Numbers WRB Bandit BRZ First-Gen (2012+) — General Topics 29 03-07-2012 10:53 PM
Any Idea of U.S. Pre-Order Numbers? markemark24 Scion FR-S / Toyota 86 GT86 General Forum 1 02-21-2012 01:29 PM
What can we do? (RE: dealership problems) D4ng3r Off-Topic Lounge [WARNING: NO POLITICS] 2 02-03-2012 11:36 AM
Japan BRZ / 86 pre-order numbers AVOturboworld BRZ First-Gen (2012+) — General Topics 55 01-21-2012 03:18 AM
AE86 production numbers vs future? EJ20 Scion FR-S / Toyota 86 GT86 General Forum 84 03-24-2011 06:21 PM
