Old 02-06-2014, 11:22 AM   #1
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Arrow BRZ and FR-S HID Headlight Bulb Upgrade | BRZ FR-S Video
[ame="http://www.youtube.com/watch?v=XP2KhEsa_2E"]BRZ and FR-S HID Headlight Bulb Upgrade | BRZ FR-S Video Series (1) - YouTube[/ame]
2URGSE
JPxM0Dz is offline   Reply With Quote
The Following User Says Thank You to JPxM0Dz For This Useful Post:
BRZNutt (02-06-2014)
Old 02-06-2014, 11:38 AM   #2
sshole
Didn't watch with sound, but icky. Look at that blue light. Do people really think that looks good?
sshole is offline   Reply With Quote
The Following 2 Users Say Thank You to sshole For This Useful Post:
Acree (02-06-2014), woode (02-06-2014)
Old 02-06-2014, 11:50 AM   #3
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
10:00 with audio enabled...
2URGSE
Old 02-06-2014, 06:33 PM   #4
sshole
No doubt, do what you want to your car.
But also be considerate of your fellow man and don't put in stupid lights that will negatively effect your night time driving abilities.
JPxM0Dz (02-06-2014), woode (02-06-2014)
Old 02-06-2014, 06:36 PM   #5
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Upgrade? You mean downgrade, right? Blue lights = rice IMO. Less functional and ugly.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
The Following User Says Thank You to woode For This Useful Post:
soundman98 (02-06-2014)
Old 02-06-2014, 07:08 PM   #6
Poodles
Drives: 2015 Series.Blue
Lol you can see the reduced output. NOT an upgrade.
This is why aftermarket hid bulbs are crap. If you want bright you buy name brand stuff.
The Following 2 Users Say Thank You to Poodles For This Useful Post:
soundman98 (02-06-2014), woode (02-06-2014)
Old 02-06-2014, 08:45 PM   #7
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Regardless of peoples choices on aftermarket bulbs, this video should prove to be helpful for those just wanting to replace their stock bulbs when the time comes or for those that want to upgrade if they choose to do so.
That's what I got from the video, hopefully it will be helpful to others...
2URGSE
The Following 4 Users Say Thank You to JPxM0Dz For This Useful Post:
BeRZed (02-06-2014), BRZNutt (02-06-2014), Burrcold (02-07-2014), sshole (02-06-2014)
Old 02-07-2014, 03:53 AM   #8
Poodles
Ok, watched the full vid ( turned it off after seeing the output shots earlier).
He's 100% wrong on the color band (needing higher kelvin to get more color in the band) and that the blue color of the main part of the beam is caused from the projector and that it wouldn't be that way in a reflector housing. He's also wrong on saying blue is "modern" as nothing comes with a 6K bulb from the factory, and anything of that general color range is an old HID bulb that's color shifted (i.e. not modern but old and busted)
Just lots of fail all around (god, even the alignment of those bulbs is off as you can see the output WAS changed with the cutoff).
Want a more pure, white light? Buy a D2S ballast, buy a set of CBI's, notch the base so it fits in the headlight correctly and presto. Or just be happy with the factory setup and wait for them to color shift a little (doesn't take long for the yellow part to go away and to go completely white).
sshole (02-07-2014), woode (02-08-2014)
Old 02-07-2014, 09:25 AM   #9
sshole
I love the CBIs. dat price doe... But yeah, I'll be looking to grab some D2S ballasts in the future so I can get that 200 lumen extra.
Some cars do come from the factory with higher Kelvin bulbs than 4300K. Most notably are the newer Audis, Mercedes, and BMWs that come equipped with CBIs. Then there are the LED headlights that are ~5000-6000K. Those don't put out too much light, though, compared to their HID counterparts.
Old 02-08-2014, 01:34 AM   #10
Poodles
Keep in mind D4S is higher kelvin than 4300K, but just how much is open for debate (some specs say a lot, some say a little). Seen the same issue on how many lumens the D4S actually puts out as well.
I've heard reports that Mercedes uses CBI's, but never seen any real proof. They're the only ones that "officially" use them, but US spec cars are likely different (CBI was originally European only and their cost was crazy because of this).
WINJET H7 Bulb Upgrade HATED1 Cosmetic Modification (Interior/Exterior/Lighting) 6 05-27-2015 09:11 PM
Headlight bulb housing SavingManuals Issues | Warranty | Recalls / TSB 2 11-29-2013 12:00 AM
FR-S Headlight Bulb Swap tennisfreak Cosmetic Modification (Interior/Exterior/Lighting) 9 08-29-2013 03:48 PM
22w LED H11 Headlight Bulb (from AutomationLED) Review Chewie4299 Cosmetic Modification (Interior/Exterior/Lighting) 10 04-02-2013 07:02 AM
HID Headlight Upgrade KIT - 1st MOD completed SpecPer Exterior Parts - The Rest 76 08-03-2012 11:13 AM
