#16 | |
Drives: Toyota FT/MT 86
Like top of the line Audi cars do have xenon hids installed from factory and " I think " do not have any humm. So at last which places should I check for HID kits? (for my Toyota 86 FT) www.diodedyanmics.com ? with kits which would just swap the bulb and replacing plug and play without any modification. Again what's the maximum watts on the xeno hids ? 6000k means the output color spectrum right? |
#17 |
Drives: 2014 Scion FR-S
I've only seen them with a maximum of 100 watts. Doesn't mean there aren't higher ones out there. Be careful though, because if you go too high, you're running the risk of melting and fire. 6000k is the color spectrum but anything higher and you start to lose good "seeing light"
#18 |
Drives: 2019 BMW ///M4
#20 |
#21 |
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
http://www.theretrofitsource.com/hid...l#.Uu3e2n-9KK0
Most lumens you can get from these kits 4300k XB35 bulbs.. But the 5000k are almost as good. Again the XB35 bulbs.. The higher the kelvin the lower the lumen. Anything higher then 6000k and your just looking for looks, not proper lighting.. And my morimoto ballast don't make any noise, but I have came across a couple that do have a slight whine.. Nothing you could hear outside the car over the engine running.. |
#22 | |
I think I'll get these ones. Should I get spare bulbs? (remember I live in argentina everything here it's complicated and a friends of mine wife is coming over in next couple months). How do these morimoto compare to the ones from diode dynamics http://www.diodedynamics.com/store/2...rsion-kit.html I've seen in diode dynamics website there are 2 kits another one for Low beam so I guess the kits from morimoto are only for High beam. Could you post a video of the morimoto you got installed to see how they look ?
#23 | ||||
ProCrastinationConsultant
just the first part of wikipedia covers that [ame="http://en.wikipedia.org/wiki/Color_temperature"]Color temperature - Wikipedia, the free encyclopedia[/ame] this is roughly what the different k-colors look like(roughly because this is a photo-chopped image to simulate the colors) ![]() original image here it is also important to reference the human eye color chart here-- during the day, the human eye is most sensitive to reds/yellows, and at night, that response shifts somewhat to green. at no point is blue a dominant color to the eye, so increasing the blue output of the headlights only makes it harder for you to see what the headlights are lighting up. ![]() as far as wattage goes, i wouldn't get any kit over 35 watts. 50 watt and 100 watt kits trade a shortened bulb life for brighter output, and also put more light directly in front of the car, which decreases your night vision, and makes it harder for you to see objects just outside of the range of the headlights, which will make you feel better, but will make obstructions seem to pop out of nowhere much faster.
| The Following 5 Users Say Thank You to soundman98 For This Useful Post: | BabaYaga (01-29-2015), Coreyviper (02-02-2014), Gixxersixxerman (02-02-2014), Rio (02-02-2014), teamturbo (02-02-2014) |
#24 |
any reason to get relay kit for this car? Is wiring suck like Honda's? pulling trigger on
http://www.xenonlightshid.com/ or [ame="http://www.amazon.com/gp/product/B004ZF4RAK/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A3GVO71WD MGEMM"]Kensun HID Xenon Conversion Kit "All Bulb Sizes and Colors" with "Slim" Digital Ballasts - H1 - 6000k - 2 Year Warranty : Amazon.com : Automotive[/ame] leaning towards the first one due to lifetime warranty option for $100. Opinions? |
#25 | |
That kit is a PnP for the highs, 4300 is suppose to be closest to "natural daylight" I prefer to run 5000k as I like a pure white light, 6000k starts to get a blue tinge.. Hid in high beam housings are not really recommended, as they take time to warm up, so your flash to pass or just flashing in general is useless, and some aftermarket kits can take 10 secs or more to warm up.. The diode dynamics are great also, I'm a supplier of both and you can't go wrong with either.. For the best light output a retrofit of a bi-xenon projector will give you the best results.. Something like this http://www.theretrofitsource.com/com...-frs-2012.html It will turn your regular projector in to one that had both high and low function.. Also remember running a hid bulb in a regular reflector housing like the high beam in our cars throws so much glare on the road in front of you that our eyes do not dialate enough to have proper night vision to see far away, so while it may have more light and everything is brighter, it doesn't mean you'll be able to see as good at far distances |
| The Following User Says Thank You to Gixxersixxerman For This Useful Post: | mrlewistan (02-02-2014) |
#26 |
Driver of FR-S 1467
Drives: 2013 scion frs 001467
^^^ gixxer gave me advice when i was thinking about going hid. his advice is always good
#27 |
Driver of FR-S 1467
only on the outside. and not too bad in open space. but impossible not to notice in small spaces like a garage
| The Following User Says Thank You to mrlewistan For This Useful Post: | Coreyviper (02-02-2014) |
#28 | |
Second, I always run HD relays.. I've personally never seen a issue running off the OEM wiring, but the added safety, cheap price and ease of install make it worth it.. But I wouldn't say you HAVE to have it, just highly recommend it |
| WTB: FRS bi-xenon headlights | smacdon | Exterior Parts (Aero, Lighting, Etc.) | 2 | 01-28-2014 04:48 AM |
| HID Single Xenon or Bi-Xenon? | FriedRicr | DIY (Do-It-Yourself) Guides | 1 | 04-06-2013 10:06 PM |
| Xenon and/or LED DRL? | Z_Rocks | Scion FR-S / Toyota 86 GT86 General Forum | 30 | 12-11-2011 11:56 PM |
