Old 02-01-2014, 05:23 PM   #1093
jflogerzi
jflogerzi's Avatar
Originally Posted by Vlady View Post
Hey all I finally figured it out lol. Here is a 4th gear pull. I wasn't able to redline it but came pretty close. Could someone please leave me some input to see if my car is running safely? It feels great but don't want to run into problems down the road. Mods: Drop in filter, track pipe, stage 2 E85 EL map. Everything else is bone stock. http://www.datazap.me/u/vlady12/1stl...log=0&data=1-9Thanks!
That looks good to me. What are you seeing in AFR under normal constant load?
Old 02-01-2014, 05:31 PM   #1094
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Looks good. I will point out that your ethanol content is probably a bit low judging by the negative fuel trims and perfectly fine AFR. Did yo you mix it with some gasoline (i.e. have a few gallons of gasoline in there before filling up). Just curious.
Shiv@Openflash is offline   Reply With Quote
Old 02-01-2014, 05:34 PM   #1095
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Hey Shiv, any word on the updated 1.54b map? If you send me a .bin (for my car, yours, or just some other CAL ID), I should be able to send you something nice. I have it starting sweet >30° and pretty well from 30°+ cold and hot (okay, I didn't have to touch the hot start tables, but the cranking IPW tables being optimized made part warmer than ambient but still fricken cold starts much better).
Luckrider is offline   Reply With Quote
Old 02-01-2014, 05:46 PM   #1096
Shiv@Openflash
Drives: 2013 FRS
Fantastic. I posted up all the v1.55 in .bin format so you can view and modify the cranking enrichments. Go ahead and implement your changes and see how it works. Then post up your maps so others (including myself) can try the same changes in their cars
Old 02-01-2014, 05:53 PM   #1097
Vlady
Vlady's Avatar
Drives: Argento Scion FRS
Yeah unfortunately I think that was the case. I tried to drive it until empty but the gauge is terrible. I thought it was empty but when I went to fill up I only was able to put 10 gal before it was full. Should I be worried about the fuel trims? Glad to hear that the AFRs look good. Thanks!
Vlady is offline   Reply With Quote
Old 02-01-2014, 05:55 PM   #1098
Vlady
Vlady's Avatar
Good question. I will check it out and post another log.
Old 02-01-2014, 05:55 PM   #1099
Shiv@Openflash
Drives: 2013 FRS
No the fuel trims are went negative to compensate for the low E%. That is what they are supposed to do. Nothing to worry about. Thats probably the lowest E% you want to go though.
Old 02-03-2014, 06:08 PM   #1100
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
Eta on vortech tune pleasssssseeeee.
@shiv@vishnu
cjsporl1996 is offline   Reply With Quote
Old 02-03-2014, 06:59 PM   #1101
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
I switched to E85 on Saturday and took it easy for the day. Then on Sunday, I started feeling that extra oomph! Then...at exactly 40 miles from fill up, I got a CEL. I pulled over and read P0351. I reset shortly after and have over 100 miles on this tank now without the CEL coming back up.
When the code was thrown, I had cruise control on and had just started going up a pretty decent incline, then suddenly felt a loss of power as CC was disabled. I have since done several WOT pulls and am not sure if the code was a fluke or what. I've read some posts that others have had this and needed to get their #1 coilpack replaced.
Otherwise, loving the E85! I crunched some numbers and found that I can stand to lose 4mpg without decreasing my $/mile due to E85 being so much cheaper. Win-win!
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 02-03-2014, 10:35 PM   #1102
Foobar
SLO NO MO
Foobar's Avatar
Misfire on Cylinder 1. What were your AFR's when you were on E85? I've seen that code before with a rich condition on E85. You should be able to lean out the tune to address it.
Unless you have a faulty coil pack or plug, of course. Oh, and if you have some popping noises, then you might want to have your DI seals checked.
The Following User Says Thank You to Foobar For This Useful Post:
2point0 (02-04-2014)
Old 02-04-2014, 02:50 AM   #1103
2point0
2point0's Avatar
Yeah I read about the popping but don't recall anything like that. I don't have a log of when the CEL came on, but I did log the next few miles. I'll have to take a look at that.
Old 02-05-2014, 01:01 PM   #1104
FRS_Jack
Duel Canister 2X the Fun
FRS_Jack's Avatar
Drives: 2013 scion frs
Any updates?
All so i think i'm running an older firm ware on my oft i still have the fr-s orange background is that correct?
Not yet. It's only compatible with A00 and A01 ROM types right now. First, we have to implement a new feature that will allow those with old 700 and 900 ROM type to update to A01. Working on that as I type
Performance: Vishnu Tune, HKS Catback Exhaust, Revworks UEL Header, Perrin CAI/Inlet Hose, Cusco Front Strut Bar + MCB, Cusco Catch Can
Interior: Blox Titanium Shift Knob, Customer Name Badge
Exterior: Black-out Headlights, Redout Tail-light, 8K DDM HIDs, BlueBatMobile Foglight Overlays, Toyota Badged, 5 Axis Spoiler, 30%/70% tint
FRS_Jack is offline   Reply With Quote
Old 02-05-2014, 01:25 PM   #1105
jeebus
You will lose more than 4MPG, FYI. I run the numbers all the time...e85 costs me more to run than 91. But it's worth it.
jeebus is offline   Reply With Quote
Old 02-05-2014, 01:51 PM   #1106
Shiv@Openflash
Drives: 2013 FRS
@shiv@vishnu
I'll be spending most of next week at Vortech Engineering (Oxnard CA) working on the OFT calibration with their calibration engineer. Once done, I drive it back to Norcal, install our OFH, make our own custom calibration from scratch and voila, we offer it to the public
The Following 3 Users Say Thank You to Shiv@Openflash For This Useful Post:
cjsporl1996 (02-05-2014), mad_sb (02-05-2014), normancw (02-05-2014)
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
