| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: GTS 86 auto
clip removal tips
Has anyone any tips on removal of those black plastic clips/rivets/plugs/ whatever as found inside wheel arches and under the bumper.
Grit accumulates in and around the claws making them hard to remove and it is all too easy to bust them.
GTS86 Auto (Australia)
#2 |
Drives: Toy car
Use a flat head screwdriver and pop them opened and then pull it out with your hands.
#3 |
The Answer
Drives: Mazda 2
These are so annoying to do. I took them off and used tie wraps. Faster removed and installed.
| The Following User Says Thank You to Rayme For This Useful Post: | notout86 (09-01-2015) |
#4 |
Captain Cocoa
Drives: CBS BRZ MT
I swear I saw someone using some sort of tool designed to remove these clips with ease.
#5 |
Drives: '13 DGM BRZ Limited
I use these for plastic clips. This avoids breaking the plastic clips after they've been on the car for a while or it's cold and brittle. Using a screwdriver works, but I've found these work better for the clips where you have to pop the center out first as they apply even pressure.
http://www.sears.com/kd-tools-3-pc-b...a=00934924000P |
#6 |
Drives: Rocket Bunny'd GT86
When installing my rear spats, they were such a hassle, couldn't take them off without actually using force and breaking them, but the spats came with replacement clips so yeah. Used a flathead screwdriver and used a lot of force and it would pop out after a bit.
#7 | |
Drives: 2019 Mazda Miata RF
http://www.harborfreight.com/push-pin-pliers-67400.html I just picked one up, haven't tried it. |
| The Following User Says Thank You to Gunman For This Useful Post: | isolato (09-12-2015) |
#9 |
Drives: 2013 Scion FRS 10 Series
Harbor Freight sells a pop clip plier makes removal of those clips easy.
http://www.harborfreight.com/push-pin-pliers-67400.html |
#10 |
DADA
Drives: 2013
Go to a subaru dealership and buy youself a handful, they cost pennies.
Grab a flat screwdriver and start popping, worry free |
#11 |
Drives: Ford Focus 09'
#12 | |
Drives: GTS 86 auto
notout86
They are also known as "cable ties". Good as emergency handcuffs.
#13 |
I don't have tie wraps ... but I used paper clips, it worked but it cracked the lock of the clip...
#14 |
Drives: 13 FRS Satin
Give them a wash first, remove your wheel for easier articulation and for the push clips, use a flat head screw driver into the slot between the lock clip and the base clip and just twist the screwdriver 90 degrees.
I guess maybe some WD40 would work too. |
| *Groupbuy: Invidia N1 and Q300 Cat-Back Exhausts (SS tips, T.I. tips) -fteightysix* | 86SPEED | Groupbuys | 74 | 11-09-2016 01:45 PM |
| GT5 video clip?? | MR2fan | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 13 | 04-27-2014 11:21 PM |
| TRD air box clip | kev1360 | Engine, Exhaust, Transmission | 1 | 07-07-2013 10:25 PM |
| WTB: DC Exhaust Tips or Other Tips | Xdragonxb0i | Engine, Exhaust, Bolt-Ons | 2 | 05-10-2013 06:36 AM |
| Basic Road Salt removal tips. | DetailersDomain | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 8 | 02-15-2013 08:27 AM |
