Old 07-10-2012, 10:11 PM   #1
philstar
philstar's Avatar
Drives: Argento FR-S
Parts Shop MAX USA prototyping
Parts Shop MAX is mainly known for their coilovers, suspension arms, and extreme angle kits for drifting and it looks like they will be developing parts for the FRS / BRZ.
From their Facebook...
"Mega measuring session on the FRS today. This thing has some major issues with getting lowered. Don't plan on getting a set of coilovers only and rolling around town looking all gangstaa. This thing needs a full suite of modifications to overcome some obstacles! 1. rear coilovers are still too high even with the shortest damper. 2. the axle angle sucks. 3. the knuckles cant be welded. Luckily we are on the case and we will offer new drop knuckles, solid sub frame riser, solid diff riser, all arms and rods, and coilovers. It will require some grinding and welding on the sub frame. 4. The wheel wells are rather narrow so I think if there is lots of steering angle and power that needs to be put to the ground or just a low offset wheel is desired for looks, the body will need to go wider and we will have the adjustable arms to accommodate a wider stance."
philstar is offline   Reply With Quote
Old 07-10-2012, 10:31 PM   #2
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
What? This sounds like it's catering to the extreme setups for drifting only.
denkigrve is offline   Reply With Quote
The Following User Says Thank You to denkigrve For This Useful Post:
DriftEightSix (03-04-2014)
Old 07-10-2012, 11:07 PM   #3
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
They might as well go with air
Silverdub is offline   Reply With Quote
Old 07-10-2012, 11:45 PM   #4
NickD
Drives: '05 Corvette
PartsShop MAX usually go pretty extreme
More of their steering angle setups here: http://www.gtfactory.jp/cms/page.php?15
Can't wait to see what they come up with for the FR-S, should be interesting as far as drifting goes.
NickD is offline   Reply With Quote
The Following 3 Users Say Thank You to NickD For This Useful Post:
dabocx (07-11-2012), denkigrve (07-10-2012), PradiG (01-29-2014)
Old 07-11-2012, 12:36 AM   #5
autofashionfred
autofashionfred's Avatar
Drives: FRS
They are down the street from Autofashion and they are coming out with some dope stuff for sure. It's extreme but this car deserves it . Can't wait once they are done.
autofashionfred is offline   Reply With Quote
Old 07-12-2012, 02:04 AM   #6
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Wow nice, I do love me some PBM for my JZZ3, so I am stoked to see what they come out with for the BRZ. And although it may not be a persons particular style, it is great that more companies are jumping on the BRZ platform to see what they can do with it. I say the more the merrier!
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 07-12-2012, 02:58 AM   #7
FTEIGHTSIX
Switched to the dark side
FTEIGHTSIX's Avatar
Drives: 91 & 95 240sx KA-T SOLD, 2013 BRZ
I had PBM coils on my s14 at one point! Good stuff and they are local so rebuilds are as easy as driving down to SD.
Correction: I think they just replace the blown shock? Or they used to?
FTEIGHTSIX is offline   Reply With Quote
Old 07-12-2012, 04:01 AM   #8
staycrushing
staycrushing's Avatar
Drives: A Hot Mess
PBM makes some rad stuff and Dan can't wait to see this stuff released!!
one of the first people to ruin the frs.
staycrushing is offline   Reply With Quote
Old 08-02-2013, 01:21 AM   #9
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Any word on the subframe risers?
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 01-28-2014, 09:33 PM   #10
JordanWho
JordanWho's Avatar
Drives: Ford Focus RS & Toyota 86 GTS
Subscribed
JordanWho is offline   Reply With Quote
Old 01-30-2014, 12:08 AM   #11
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Subframe risers and diff risers are both available for purchase on their site right now.
Old 03-01-2014, 01:28 PM   #12
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
What's the install time on these? Lot of labor so to say? I wanna make my axles "very happy" is how they say it..... @TylerLieberman can you chime in if you know.... Would these help a little bit if we don't have upgraded LCA's
Sent from my HTC One
SMOKETREES is offline   Reply With Quote
Old 03-04-2014, 01:14 PM   #13
TylerLieberman
Drives: '24 GR86
These will be getting installed on my car sometime next month. Both the subframe and diff risers.
The subframe risers will raise the subframe around 5-10mm. The diff risers will raise the diff up by about 20mm. So in the end, the axles are moving up by 1", maybe a hair more.
That will definitely help take some load off the axles.
As far as LCAs go, I have Stance LCAs and I noticed no difference in axle angle from before and after the install of them. The LCAs don't really do anything for your axles. They're meant to allow you run a lower height without sacrificing so much shock travel.
I'm curious if the risers will affect the ride height/alignment of the car at all. I'll make sure to post info on it.
If you want to see the install/updates on it and stuff, or ask any questions, feel free to check out my build thread. Loads of information in there. I try to answer every question as best as possible.
The Following 3 Users Say Thank You to TylerLieberman For This Useful Post:
Baldoak (10-10-2015), Falkon240 (01-25-2023), JordanWho (03-04-2014)
DarrenDriven's Shop - SPRINGS IN STOCK! Home of the 25 minute spring install DarrenDriven Northwest 1499 08-07-2017 03:02 PM
Tint Shop In GTA ArKiTeCkT CANADA 80 04-24-2013 08:46 PM
Anyone know a trusted shop? Partial Stall New England 13 08-06-2012 11:45 PM
Installing TRD Parts / Locating a good shop Re~Mix Engine, Exhaust, Transmission 9 06-12-2012 01:05 PM
