Old 01-23-2014, 10:32 PM   #2857
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by swift996 View Post
Getting to those lower bolts on the elbow is easier than the supercharger bolts? I'm not seeing how that makes it easier to remove.
Yes, because you need to remove the few bolts on the back of the supercharger to take the charger off, which are underneath that elbow, out of sight. Its hard to reach with that elbow there, you are doing it blind and the spot is real tight with the elbow.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
swift996 (01-23-2014)
Old 01-24-2014, 02:25 AM   #2858
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
I found it so much quicker to just remove the entire kit. Takes around 30 minutes gave me the opportunity to check all o rings grease them up and fit back to ensure no leaks.
I definitely struggled with taking off while kit on and got so frustrated at dropping bolts and hands being too big to get in there.
If you get it right easy enough really would like to know, for future.
Ryan86 is offline   Reply With Quote
Old 01-24-2014, 09:50 AM   #2859
xxscaxx
It was easy for me to remove the back elbow, but then again I have the proper tool to do it, so if you don't then I can see it being a bigger PITA.
Well my coolant dropped down again....idk wtf is going on. I built up maybe 3 pounds of boost on my way into work today, it was full last night, so idk, maybe a coincidence, but i'm going to get into boost again a little on the way home and see if the level drops.
Either way this is annoying as hell. I am guessing the leak is in the intercooler, because there is no leak anywhere else, i've checked about 10 times already. Unless I just had a bunch of air in my system but I doubt it at this point. I have to check my subaru super blue coolant bottle and see how much left I have and compare it to the 2.2l the system takes.
Old 01-24-2014, 12:49 PM   #2860
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Originally Posted by Hempo View Post
What Whp do you guys think one can manage with the IC, 70mm full exhaust without cats, a custom air intake located through a hole in the bumper running E85 with DW65 pump and 700cc injectors?
Theres a lot of variable at play there, but I would bet it would be around 300whp with that setup. The 700cc injectors may not be worth it however.
Parting out HERE
civicdrivr is offline   Reply With Quote
The Following User Says Thank You to civicdrivr For This Useful Post:
xjohnx (01-24-2014)
Old 01-24-2014, 01:02 PM   #2861
DriftEm
DriftEm's Avatar
I almost got the same setup (still on stock injectors) and made 305whp (dynojet)
Sent from my SAMSUNG-SM-N900A using Tapatalk
DriftEm is offline   Reply With Quote
The Following 3 Users Say Thank You to DriftEm For This Useful Post:
civicdrivr (01-24-2014), evo4g63 (01-24-2014), Sonolin (01-24-2014)
Old 01-24-2014, 01:04 PM   #2862
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
True, @DeliciousTuning has done this on stock injectors and the DW65 fuel pump. He has stated the stock injectors are good for roughly 350whp.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
The Following User Says Thank You to evo4g63 For This Useful Post:
DeliciousTuning (01-24-2014)
Old 01-24-2014, 01:10 PM   #2863
xxscaxx
Radium Cans are now for sale.
http://www.radiumauto.com/Catch-Can-...Z-86-P374.aspx
The Following 2 Users Say Thank You to xxscaxx For This Useful Post:
DriftEm (01-24-2014), normancw (01-24-2014)
Old 01-24-2014, 02:27 PM   #2864
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
Originally Posted by xxscaxx View Post
Nice!! Great price too for a dual set up. I just purchased a Crawford AOS on the groupbuy on here.
Sent from my DROID RAZR using Tapatalk
Area86 is offline   Reply With Quote
Old 01-24-2014, 02:30 PM   #2865
xxscaxx
Yeah, I will probably end up buying this kit . I know I can get cheaper solutions but Radium is top notch and I love the mirrored mounting on the backside of the strut towers.
Old 01-24-2014, 02:51 PM   #2866
xjohnx
Grip>Slip
xjohnx's Avatar
got the hardware to match up to the dual cans i have on order. Woohoo. I spoke with Radium and they'll be shipping by tuesday.
xxscaxx (01-24-2014)
Old 01-24-2014, 02:52 PM   #2867
xxscaxx
Sweet man. I am going to order this too, said the 31st will be when they ship. I might wait though a week or two, I need to buy my injectors first
Old 01-24-2014, 03:00 PM   #2868
xxscaxx
I believe people who have hooked up catch cans to the crankcase aren't seeing much oil blowby. If it were me and I was getting just one can, i'd get the PCV kit. That is where you will see the most especially on boost.
I'm sure someone a bit more knowledgable will chime in, but here is what Radium has to say:
This catch can runs inline with the 3/8" PCV (positive crankcase ventilation) valve. When the intake manifold pressure is close to or greater than atmospheric pressure, the PCV "check" valve closes and, thus, this hose experiences no flow. Conversely, the PCV hose will experience "metered" vacuum when the engine is idling, steady state cruising, and decelerating. This would normally draw unwanted crankcase vapor, unspent fuel, and oil sludge into the intake manifold immediately after a high load run. Note: Because the Radium catch cans are pressure sealed, they are great for boosted applications as well so connecting to the intake manifold is permitted.
Old 01-24-2014, 04:11 PM   #2869
Perihelion
Unemployed DIY Ninja
Perihelion's Avatar
Drives: 2013 SWP BRZ, 1983 MB SD300
Where do you plan on mounting it? I think the designated spot doesnt have enough clearance if you have an Innovate SC.
Perihelion is offline   Reply With Quote
Old 01-24-2014, 04:18 PM   #2870
swift996
swift996's Avatar
@xxscaxx @xjohnx
So you're saying it's easier to remove the elbow - including that circle in red? Also does that bypass piece slide off with the elbow or with the manifold?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
