Old 01-23-2014, 02:06 PM   #15
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Originally Posted by GrimmSpeed View Post
Thats not nit picky at all. One of the first things I did was run a hose in the front air damn near the snorkel, and test to the throttle body. The results were the same as when using the fitting at the front of the snorkel, which goes to show that I could have just taped some hose down in that area instead of adding a fitting to the snorkel.
Thanks to everyone who took the time to read this, its a long read, but hopefully it's as interesting to everyone else as it was to us.
Chase
Engineering
lol
Ranatsu is offline   Reply With Quote
Old 01-23-2014, 02:09 PM   #16
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Originally Posted by Ranatsu View Post
lol
Hahaha! I didn't even think about that when I wrote it, and I refuse to edit it!
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
Old 01-23-2014, 02:20 PM   #17
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Chase
Engineering
potty mouth.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 01-23-2014, 06:48 PM   #18
Sphirit
Drives: GT86
Thank you very much!
Sphirit is offline   Reply With Quote
Old 01-23-2014, 08:08 PM   #19
arghx7
Drives: car
This is a good topic. While there isn't really a totally standard way to do this testing, the most common way is to run steady-state rpm and torque/load points with a loading dyno. An engine dyno is easier but that's not an option here.
As airflow increases, the localized pressure will drop. You'll see this on turbo cars especially--it's important for calculating pressure ratio on a compressor map. When you get a heavily boosted engine the restrictions get crazy and that's when rubber pipes on turbo inlets start to collapse and such. You can use different instruments and different measurements, like using a pitot tube instead of a manometer, or doing static pressure only vs taking into account dynamic pressure.
What you'll end up with though is a chart like this:
So x axis might in this case be 25 grams/sec increment. Y axis would be in 1 kPa increments for something like this. Each point is a steady state test from holding the dyno at specific torque points to capture different airflow. Then through the magic of Excel you put a curve fit in there. So at 100 grams/sec you could have atmospheric pressure be 98 kPa, measured pressure be 96.5, and your pressure drop would be 1.5 kPa.
There's always an exponential relationship between mass airflow and pressure drop--when you change the intake pipe you change the shape of that line through the points. Then you can start comparing across different intake pipes or even across different engines if the measuring process is similar. Once you collect enough data trends you can place your intake within an upper and lower boundary line to see how good the design is.
The Following 6 Users Say Thank You to arghx7 For This Useful Post:
Dimman (01-24-2014), GrimmSpeed (01-24-2014), mwjcyber (01-24-2014), solidONE (01-25-2014), Turdinator (01-24-2014), u/Josh (01-23-2014)
Old 01-24-2014, 12:27 AM   #20
Turdinator
Señor Member
Turdinator's Avatar
...Thats not nit picky at all. One of the first things I did was run a hose in the front air damn near the snorkel, and test to the throttle body. The results were the same as when using the fitting at the front of the snorkel, which goes to show that I could have just taped some hose down in that area instead of adding a fitting to the snorkel...
Awesome! Thank you for being so thorough and for freely sharing what you found from your tests. It's this sort of support from vendors that keeps me coming back to this forum. I can't wait to see what you come up with for your intake
1974 TA22 Celica
2013 86 GT
Old 01-25-2014, 05:53 PM   #21
zooki
Drives: waiting on a 2021...
Since it seems that the snorkel is an integral piece of the whole induction system(and not a restriction), it makes me wonder how these aftermarket(HKS, Zeek, etc.) intake ducts affect pressure, flow, and AFR's on these cars?
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 01-25-2014, 10:02 PM   #22
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Love the way Grimspeed does things. Science, fuk yea!
Old 01-28-2014, 12:42 AM   #23
Bobfiveoneohh
Drives: 2013 scion frs
Great write up ! Thanks for the research !
Bobfiveoneohh is offline   Reply With Quote
Old 02-26-2014, 02:20 PM   #24
Basti
Basti's Avatar
A number of laws about the behavior and movement of gases come to mind... very interesting.
Thanks guys!
Basti is offline   Reply With Quote
Old 02-26-2014, 02:35 PM   #25
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
@GrimmSpeed - Thanks for your hard work and detailed explanation. This is the kind of stuff that will make me want to support you guys by buying your products, even if there are cheaper alternatives out there. Please continue to keep the community informed
leicaboss is offline   Reply With Quote
The Following User Says Thank You to leicaboss For This Useful Post:
Turdinator (02-26-2014)
Old 02-26-2014, 07:28 PM   #26
Turdinator
Señor Member
Turdinator's Avatar
I will second that!
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
leicaboss (02-26-2014)
Old 02-27-2014, 11:57 AM   #27
GrimmSpeed
GrimmSpeed's Avatar
Thank you very much for the kind words everyone, it really means a lot to us as a company!
Chase
Engineering
Old 02-27-2014, 01:22 PM   #28
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Awesome testing guys! Your results make sense. At speed, there will always be a positive pressure zone in the bumper opening of the car as the air rams against the radiator. Makes sense that the intake would be configured to pick up from there.
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
GrimmSpeed (02-27-2014)
Stock FRS air intake system AG3NT_5CARFAC3 Engine, Exhaust, Bolt-Ons 0 02-26-2013 06:14 PM
WTS: Airaid Intake System, Stock Exhaust, Stock Radiator Hoses Sony Engine, Exhaust, Bolt-Ons 0 11-21-2012 12:10 AM
INJEN and aFe Intake System, In stock and ready to ship!! 10k Redline Engine, Exhaust, Bolt-Ons 5 10-03-2012 05:05 PM
GrimmSpeed BRZ Measuring Session - Anyone need any random measurements? GrimmSpeed Scion FR-S / Toyota 86 GT86 General Forum 53 04-19-2012 07:27 AM
