Old 01-18-2014, 07:54 AM   #1
Frs32907
Drives: Asphalt grey, manual Fr-S
Hid bulb on winjet headlead went out help?
Could anyone offer some suggestions that i i could look at that would cause my new hid light to go out on the passanger side?
Frs32907 is offline   Reply With Quote
Old 01-18-2014, 08:17 AM   #2
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
are they stock halogen bulbs or aftermarket HID?
where did you purchase the headlights?
if it's aftermarket HID. try to switch the ballast from the other side and see if that works. try to see which one is bad. either bulbs or ballast.
86_ZN6 is offline   Reply With Quote
Old 01-18-2014, 08:43 AM   #3
Frs32907
I purchased them with headlight its the hid not halogen.
Old 01-18-2014, 08:51 AM   #4
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
try the swapping method first. then contact your vendor
Old 01-18-2014, 09:07 AM   #5
Frs32907
Okay thanks for the advice.
Old 01-18-2014, 05:30 PM   #6
Poodles
Drives: 2015 Series.Blue
They're kit bulbs as the winjets are H7 projectors.
Old 01-18-2014, 09:57 PM   #7
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
There's a recall on the Morimoto ballasts that cam with our Winjet headlights. Contact them and they'll help you out.
kmbkk is offline   Reply With Quote
Old 01-19-2014, 12:56 PM   #8
Frs32907
The ballast went out I had to replace both cause well cops will give tickets here so there went a 100 bucks hope phestek can help me out since I got them through there
Winjet Headlights and HIDs HakunaMiata Cosmetic Modification (Interior/Exterior/Lighting) 27 07-18-2017 11:24 PM
New Winjet Headlights LED FLICKER?! Jeremehh Cosmetic Modification (Interior/Exterior/Lighting) 4 03-08-2016 04:26 PM
WINJET Headlight Question HATED1 Cosmetic Modification (Interior/Exterior/Lighting) 5 10-12-2015 04:46 AM
Winjet HID Size? Jeremehh Cosmetic Modification (Interior/Exterior/Lighting) 9 03-10-2014 03:28 AM
Custom Purple Winjet and Black Winjet Headlights xclusive_brett Cosmetic Modification (Interior/Exterior/Lighting) 35 12-17-2013 09:28 AM
