Old 01-16-2014, 08:06 PM   #15
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Originally Posted by Fett4Real View Post
So at 6800 miles on the odometer...in 3rd and 4th gear (manual mode) in sport or normal the trans seems to slip. The RPMs drop 500RPM or so after shifting. Not everytime but alot of the time. Anyone seen or heard of this issue?
That's the torque converter lock up clutch. When it locks up it eliminates torque converter slip completely which is its job. Before it locks up the engine rpm will be slightly higher than after it locks up. It is supposed to do this.
If the time lag is very noticeable it is possible you have a mechanical fault or a software issue delaying completion of the manual shift. However, bear in mind this software is adaptive so it learns to shift according to how you normally drive. Try driving more aggressively when in manual mode. Is there a Sport setting in the automatic? If so, use it when in manual mode. Should shorten the shifts.
If you drive at WOT the transmission should shift pretty aggressively and the torque converter lock up should unlock and re-lock very, very quickly, you'll not notice it happening.
Suberman is offline   Reply With Quote
Old 01-16-2014, 08:19 PM   #16
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
Yeh went and spoke with a very knowledgeable friend at subaru. Who knew about the 86 preproduction he cleared it up similar to what you said. Thanks.
Sent from my SCH-I545 using Tapatalk
Fett4Real is offline   Reply With Quote
Old 01-16-2014, 08:23 PM   #17
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
This has been covered many times. Normal but annoying.
Old 01-16-2014, 08:39 PM   #18
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Never read about a 500RPM drop
Old 01-16-2014, 10:59 PM   #19
sprintertrueno86
sprintertrueno86's Avatar
Drives: 2018 BMW M2
This.
Also, in order for sport mode to work with manual mode, you have to turn Sport on first, and then shift in to Manual mode. Sport mode will not turn on if you're in manual mode already.
sprintertrueno86 is offline   Reply With Quote
Old 01-16-2014, 11:02 PM   #20
BlueDubbinTDI
http://www.ft86club.com/forums/showthread.php?t=23554
Oh no?
The Following User Says Thank You to BlueDubbinTDI For This Useful Post:
L8Apex (01-18-2014)
Is there an Auto Trans only dyno thread? Pure Automotive Engine, Exhaust, Transmission 17 07-17-2014 01:35 AM
What is the best way to Launch the Auto Trans DeOppressorLiber Tracking / Autocross / HPDE / Drifting 27 10-23-2013 12:24 AM
After market exhaust and auto trans russv Engine, Exhaust, Transmission 26 05-29-2013 06:49 PM
Force induction on auto trans? t00n3wb Forced Induction 12 04-14-2013 07:19 PM
Launch control with auto trans Dbringer Scion FR-S / Toyota 86 GT86 General Forum 3 06-12-2012 05:54 PM
