Old 01-09-2014, 10:17 PM   #183
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
LOL, this cracked me up.
Originally Posted by Ganthrithor View Post
What horny-rific wheels.
Originally Posted by humfrz
I'm old and lazy
Old 01-13-2014, 07:24 PM   #184
Flasher
Smartass
Flasher's Avatar
Drives: Toyota GT86 & Impreza STi
Are there any dynos on this? Stock vs. Milltek resonated? Just purchased the resonated version with overpipe and Motiv Concepts catted front pipe. Reasonable?
Flasher is offline   Reply With Quote
Old 01-13-2014, 07:37 PM   #185
mkivsoopra
Just to throw this out there.. I have the non-resonated and have no scraping issues. The car is lowered about 1.5"
mkivsoopra is offline   Reply With Quote
Old 01-14-2014, 02:41 AM   #186
mush
mush's Avatar
i noticed about couple months ago the inside of my exhaust started turning black really quick
a few weeks ago(maybe even last week) i could still see the silver circle where the tips and the axel-back connects now that part is black too
i read on google that if the car does that it could be running rich?
ive had mine since august, non resonated
Old 01-14-2014, 02:58 AM   #187
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Originally Posted by Trettiosjuan View Post
Here one that a belgian forum member posted in the regional forum (Milltek full system resonated):
(edit: pic doesn't show, here is the direct link:http://www.hostingpics.net/viewer.ph...1327370001.jpg )
Hey that'd be me!
Ugh. I finally got mine up on a lift at a non-dealer where I could get under the car and look at it... what we found isn't pretty:
It looks like it's not even a weld that's torn-- it looks like the whole flange that the pipe section welds to has ripped apart.
If that shit's going to tear to bits every time the kink in the piping that goes under the diff/axles rubs then I'm going to need to switch to the non-resonated midpipe. The ground clearance on that bit of pipe that hooks under the rear suspension is so stupidly bad-- I'm lowered less than an inch from stock ride height and have plenty of clearance everywhere else on the car even for the worst California bumps / ramps / drainage depressions, but there are a few spots around town where I literally can't avoid rubbing that pipe elbow even when I'm doing half a mile per hour slipping the clutch in first gear... silly design. It's a real shame, because I love everything else about this system and the resonated setup is great for a DD sound-wise.
I got the exact same problem. Although my car is on stock suspension and I never rubbed the exhaust anywhere.
Milltek did replace it for free (under their lifetime warranty), shipped for free to their local retailer (from which I initially bought it) which didn't charge me for the labor.
Guillaume is offline   Reply With Quote
The Following User Says Thank You to Guillaume For This Useful Post:
Ganthrithor (01-14-2014)
Old 01-14-2014, 07:09 AM   #188
Trettiosjuan
Drives: GT86
Yep, just get in touch with your retailer or Milltek if there is a problem. They treated me well when I had problems with another system, that is why I bought again!
So far no probs here hope it stays that way. Important at install that the whole system gets to hang on all rubbers equally...
Trettiosjuan is offline   Reply With Quote
The Following User Says Thank You to Trettiosjuan For This Useful Post:
Old 01-14-2014, 07:44 AM   #189
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
Interesting. I'll contact Mann and see what their thoughts are. If it wasn't caused by dragging then I wonder what would cause a failure like this?
Ganthrithor is offline   Reply With Quote
Old 01-14-2014, 09:38 AM   #190
Guillaume
Guillaume's Avatar
Drives: Exige S 240
A poorly welded batch (too hot?), I hope. Otherwise, it's a design flaw and the problem won't be fixed with a replacement part. But then again, it's not their first try at fabricating exhausts so they should know what they're doing.
Old 01-16-2014, 06:02 AM   #191
Flasher
Smartass
Flasher's Avatar
bump
Does this combo make sense?
Old 01-16-2014, 06:08 AM   #192
Trettiosjuan
Drives: GT86
Surely that combo would give some gains. But dynos seem rather random as there are so many variables, and even then, how much would you notice the difference give or take say 3hp here and there...??
Lower back pressure, nice sound, still catted and resonated (not LOUD) = a "mature" choice. There is a vid of this combo on youtube (without overpipe), sounds good.
Flasher (01-17-2014)
Old 01-17-2014, 01:32 AM   #193
Ganthrithor
Just an update: I got in contact with Mann Engineering (the US Milltek distributor and my vendor). I sent them a picture of the damage which they forwarded to Milltek: Milltek are replacing my midpipe totally free of charge. Pretty cool that the company stands behind its products like this.
FWIW Gary from Mann said that Milltek have seen a couple of failures like this from their first batch of systems and think there was a problem with the stamping for that resonator end-plate / flange fitting (as you can see from my picture, the weld where the piping joins the resonator is fine-- it's the flange / collar that it welds onto that looks like it has torn free from the rest of the end-plate). Apparently only a small number of units have been affected and they don't think it should be a recurring problem.
Can't wait for my new midpipe to come in so my car stops sounding like a ricer Civic :3
Old 01-17-2014, 01:57 AM   #194
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Well that's good news on two levels. Thanks for sharing
Old 01-17-2014, 07:34 AM   #195
Flasher
Smartass
Flasher's Avatar
Yeah my orange GT86 with Aero-Kit is already eye-catching like no other car around here. Already led me to some encounters with the Cops (routine traffic control). Not trying to draw more attention with a huge & loud exhaust, but still want to have a bit more sound and performance. Thinking over adding a catted UEL header in the next couple of months - just want to have the godlike boxer rumble.
Old 01-22-2014, 11:09 PM   #196
Ganthrithor
So I had a local shop swap the new midpipe in today. Got the car home and noticed that the tips were all wonky: the left tip looked pretty normal, but the right one was sticking out a lot further than the left and angled down more than usual.
I grabbed a socket wrench and pulled the clamp off the right tip and pipe elbow; then I re-aligned the tip so it matched the left one and tightened everything back up. While I was down there I noticed that the muffler itself seems to hanging strangely-- when I went to loosen the band clamp for the right (passenger-side) tip (the tip clamps are both installed with the bolt at the top, head towards centerline) my socket wrench had clearance to slip in under the hangar and interface with the bolt. On the left (driver's side) tip, the hangar blocks the socket from fitting over the bolt.
When I drive the car I can hear something vibrating against the body when I accelerate hard. I assume it's the left exhaust tip hitting the rear valence, since that's the way the engine torques on its mounts (left tip goes up, right goes down) when throttle is applied. Could this be related to the hangar mounts seeming to be in different positions for some reason? I just don't understand how replacing the midpipe could result in the whole muffler being dramatically re-aligned like this. Should I just drop the left tip down a bit to keep it from tapping the valence, or do I need to take the whole thing off and re-mount it?
Car sure sounds better, though
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 10:30 PM
Dynosty Presents MXP Exhaust System for FR-S/BRZ Dustin@Dynosty Engine, Exhaust, Bolt-Ons 12 11-08-2012 10:15 AM
Subaru BRZ Arrives At Milltek Sport HQ For Development vividracing Engine, Exhaust, Transmission 13 08-13-2012 09:53 PM
What is the best exhaust system for the FT86 LOTUS86 Engine, Exhaust, Transmission 4 07-31-2012 03:36 AM
TRD Exhaust System... Griffdawg Engine, Exhaust, Transmission 2 07-18-2012 01:27 AM
