#2605 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
It's certainly got the better of me over the last 4 months.
I am doing R&D with the agent in SA, whom is liaising with Sprintex. We were one of the first to get the new kit unfortunately. I've had 2 specialist install the kit and check it out, both failed. Since I've taken it off And understand how it works what to look for and what each component does,I and able to sort myself out. so as the saying goes, if you dot know how to fix your mods you don't know how to mod. I am a little concerned with the Blue Gates belt on the 75mm pulley it might be too tight, so I'm going to go back to the standard belt, to ensure kit runs properly. Also fair warning don't over tighten the Allen key bolts on the charger as those bolts are very thin and strip easy.. |
#2606 | |
WUB WUB
Drives: 2013 Firestorm
and my friend who's gonna give me a hand wanted to know what kind of threading on that screw on the back.
#2607 | |
Road Warrior
Sprintex standard 80mm pulley 65 mm idle pulley ( I must double check the idle pulley size) IC add on 75 mm pulley 70mm idle pulley. So with the IC pulleys the blue gates is a huge effort to get on compared to the standard belt. I went BG as I heard it does not slip, however it may not be good for the 75mm set up and more suited with a 70mm. The above is my opinion whether accurate, I'm sure someone with more knowledge could advise. |
#2608 | |
Drives: 2013 SWP BRZ
This is why I ALWAYS do things myself. Now that you have pulled it apart, you know what you are doing and can take the time to do it yourself and not have to wait for a shop to figure it out, and on your dime. |
#2609 |
AutoX-10/10ths every run
Here's a photo of the brass fittings I referenced earlier from McMaster-Carr installed. The initial tube length is 2.5 inches. Should have the car on the road tomorrow.
| The Following User Says Thank You to whataboutbob For This Useful Post: | Ryan86 (01-12-2014) |
#2610 | |
Drives: 86
Mine squeaks only on the initial startup, when the car is cold. It squeaks for about 30sec, then it goes away. If I drive the car throughout the day, it won't squeak. If I leave it in the garage overnight, it'll squeak again on startup for 30sec. If it might be the pulley, would you chance it next weekend at the track? What do you guys think? Idler pulley? I have a track event a week from Sunday, and am thinking of buying the bearing you mention above. |
#2611 | |
That Guy
Drives: 2013 asphalt FRS MT
| The Following User Says Thank You to Calum For This Useful Post: | TemeCal (01-12-2014) |
#2612 | |
| The Following User Says Thank You to whataboutbob For This Useful Post: | TemeCal (01-12-2014) |
#2613 |
Drives: 86
#2614 | |
Drives: 86
Edit: Here is a video of what I'm talking about: [ame="http://www.youtube.com/watch?v=tZ9uhi9G5ZU"]Idler pulley bearing? - YouTube[/ame] Last edited by TemeCal; 01-12-2014 at 11:49 AM. |
#2615 |
That Guy
#2616 |
Road Warrior
I wonder if the BG belt has not caused the bearing to go, as there is not much movement on the tension with the BG compared to the standard belt.
Mine sounds very simular with the BG on, change the belt and it's quiet. I'll try post a video clip. Try change your belt back and check if the noise goes. Also if the bearing has gone you should be able to feel it if you wiggle the pulley with belt off. |
| The Following User Says Thank You to Ryan86 For This Useful Post: | TemeCal (01-12-2014) |
#2617 |
Drives: 86
Thanks everyone. I've ordered 2 bearings. Hopefully they'll arrive in time for my track event. For now, I'll try swapping to the standard belt to see if that helps for now.
Appreciate all your input! @mines13 @Innovate Motorsports - Is this a common issue? Sounds like many are having this problem. I certainly don't want to replace this bearing every few thousand miles. Are you guys working on a solution??? |
#2618 | |
That Guy
| The Following User Says Thank You to Calum For This Useful Post: | Ryan86 (01-12-2014) |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
