Old 01-08-2014, 07:25 PM   #43
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Originally Posted by NemeGuero View Post
Its there in the 2nd post.
TL;DR
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 01-08-2014, 08:59 PM   #44
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Originally Posted by w00t692 View Post
There's a few key critical points to making a good header.
1.) equal length!
2.) primary runner length
3.) stepped primary runners (finding the right point to step them)
4.) merge collector angle (divergence)
5.) venturi size and angle of convergence
Both the last 2 affect the rpm range the header works at, but not as much as the length of the primaries does.
longer transitions get the header to work over a broader rpm range.
Equal length isn't the end all be all. Either through superior engineering or serendipity, the Jdl header is making the best power of any header so far. Proper wave scavenging is probably the reason. Equal length in a NA motor is not the end all be all it is in a turbo manifold with a proper twin scroll setup. You want a constant negative pressure differential on the exhaust side of the motor(to prevent reversion) which can only be achieved with UEL. Then there are all the harmonics to deal with. It's not as simple as you think it is and it really shouldn't be dumbed down. It's complex and there is no easy explanation of the voodoo that is exhaust tuning.
industrial is offline   Reply With Quote
The Following User Says Thank You to industrial For This Useful Post:
SirBrass (03-20-2014)
Old 01-08-2014, 09:47 PM   #45
w00t692
Drives: 2008 Civic Si
I'm not dumbing it down. Did you know you can put those pieces i mentioned together in any combination in multiple different configurations in multiple different sizes and different venturi entrance and exit sizes... and steps in different spots... and the list goes on?
It's INCREDIBLY complex and you could spend ages finding the right setup.
But i'm sorry, you won't find ANY race car without an equal length header, and there's damn good reasons for that you will find in any book explaining why. But the main one? Testing methodology (explained a bit below). You can't tune a header for a specific rpm range (or broad rpm range) when you make all the piping lengths different.
When you speak of UEL vs EL headers you will ALWAYS be stuck with a million threads and posts turning up before you find anything actually explaining the reasoning behind it. But if you must know? The unequal length header will make some cylinders better at scavenging than others, while others are worse. And how do you know? You don't. The gain as a whole might be better, but it can always be better with an EL header. Scavenging is all about piping length to time your pressure wave to suck in the next cylinders air (valve overlap) with negative pressure to increase VE in an rpm range that you want. This gets so insanely complex when you bring a variable cam angle into play that it could take ages to find the right combo.
You realize that there are aftermarket headers with anti reversion chambers in specific spots to prevent reversion that affects power in specific rpm ranges poorly? On the ones i'm currently thinking of they are there to prevent poor reversion characteristics at high rpms. Otherwise, the pulses are bouncing back at valve overlap events at those specific rpms, resulting in lower volumetric efficiency.
tl;dr: exhaust tuning is SUPER complex and there's no answer to everything, but there's a reason they don't make UEL's when they actually care about making power.
w00t692 is offline   Reply With Quote
Old 01-08-2014, 10:09 PM   #46
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Why all this talk of reversion in an NA thread? The stock cams aren't going to have overlap values high enough to experience reversion. It would be rare to experience it.
I suppose it could be possible if scavenging really was that terrible, or if the exhaust was poorly engineered.
UEL outperforming an EL is nearly unheard of. Everyone sees EL as the superior because it allows you to get the best scavenging when things are perfectly symmetrical. But as we all know here, an EL can still suffer from scavenging issues if pipe diameter, collector, or bends are not completely ideal.
I'm going to check out the build thread now.
Coheed is offline   Reply With Quote
Old 01-09-2014, 09:17 AM   #47
w00t692
Coheed: variable cam timing should allow some overlap and to be tunable at that!
This is the beauty of it, there's zero overlap when you have the cams at 0 cam angle so idle and low rpms are smooth and make torque, but once you get to higher rpms you increase those cam angles allowing some overlap to increase horsepower.
Old 01-09-2014, 11:21 AM   #48
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
While I appreciate a good technical discussion, it's essentially meaningless because we are generally saying the same thing.
I think you are overstating the importance of el vs Uel runners in a header design. Things like the actual runner lengths (which affects velocity, heat, harmonics) and proper merge collectors are far more important than just ensuring all the exhaust pipes are the same length in my opinion.
If all things are the same, el will be better than Uel. But with so many variables this isn't the case at all.
Old 01-09-2014, 11:44 AM   #49
w00t692
Essentially, the only reason uel headers exist for this car is ease of installation.
Once you find the proper piping length for the car it doesn't change from cylinder to cylinder. Hence... equal length.
Old 01-09-2014, 12:09 PM   #50
2point0
2point0's Avatar
Essentially, the only reason uel headers exist for this car is ease of installation and it sounds awesome.
Fixed that for ya.
The Following User Says Thank You to 2point0 For This Useful Post:
kuhlka (01-16-2014)
Old 01-09-2014, 12:14 PM   #51
w00t692
lmao, if you say so.
Old 01-09-2014, 01:00 PM   #52
bfrank1972
Drives: 2013 FR-S Argento
Originally Posted by 2point0 View Post
Fixed that for ya.
Different strokes for sure
Old 01-09-2014, 01:13 PM   #53
2point0
2point0's Avatar
I hear you there. My previous cars were a WRX and an STi, so I guess I'm a bit biased.
It's good that we don't all like the same things. Otherwise, there'd be no uniqueness.
bfrank1972 (01-09-2014)
Old 01-09-2014, 01:40 PM   #54
w00t692
[ame="http://www.youtube.com/watch?v=drzwLPYPwXs"]2007 Civic Si Greddy Turbo - YouTube[/ame]
log manifold turbo civic si. Sounds like... what's that?
Old 01-09-2014, 02:02 PM   #55
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Have you considered that it may not be possible to package ideal length runners given the way an exhaust has to be packaged? El and Uel headers won't differ much in installation unless you are talking about a radical redesign of the engine compartment. At what point do equal pipes become detrimental? When you have to utilize crazy routing schemes with less than ideal radius bends or less than ideal merge angles or longer than nessesary runners?
And Uel sounds much better on a 4 banger. That alone is worth the 1% difference in power between the two.
The Following 2 Users Say Thank You to industrial For This Useful Post:
kuhlka (01-16-2014), Malt (01-09-2014)
Old 01-09-2014, 02:57 PM   #56
jamesm
that's entirely subjective. if you ask me, i think uel's sound like farty garbage. it's an opinion, and people's differ.
as for the endless uel/el debate, it's really simple: the ideal header design probably has equal length runners, certainly so if we're talking about a turbo manifold. many people have managed to package an equal-length header into the bay, and the 'best power producing' header around by far now is equal length (nameless). uel's also make great power.
really if you're buying a header you're probably staying na, and if that's the case i'd be more concerned with the sound preference, because you're not going to be making much power regardless of what header you buy. s/c guys might put a bit more thought into it, but even then i doubt there's much between them in real life.
The Following 2 Users Say Thank You to jamesm For This Useful Post:
bfrank1972 (01-09-2014), w00t692 (01-10-2014)
My SWP BRZ: light tuned- stay tuned! Badaab Member's Car Journals 28 09-06-2013 12:35 AM
Plastic Moisture barrier replacement AL008 Electronics | Audio | NAV | Infotainment 1 06-19-2013 08:48 PM
Scion FR-S / FT-86 / Subaru BRZ Specs and Options. 200hp / 151 lb-ft tq Nardi330 Scion FR-S / Toyota 86 GT86 General Forum 510 09-03-2012 06:39 AM
200hp / 2700lbs - Really? Rickster Scion FR-S / Toyota 86 GT86 General Forum 385 04-18-2011 02:47 PM
