#29 |
Drives: Toyota FT/MT 86
Hi thanks for your reply , can you tell me again what you told me to monitor in realtime the fuel average.. you mean to switch the option to showo n the dahshboard and see in real time the fuel consumption?. Again what about the revs I should be shifting gears.. I'm using the G-on feature. to switch gears properly on each gear.. which shows a triangle blinking when you got to do make the next shift.
Thanks. Why is that the first quarter won't reflect the normal fuel consumption ? sorry I'm not that knowledgeable I just supposed guiding myself from the first quarter tank to see the fuel consumption would suffice. But I guess it's not.. I also don't know if the fuel the dealer gave me the car with it's RON98 or it's lower.. i've read in a couple forums that if the car it's meant to be for RON98 and you add a lower octane fuel it would have an impact on fuel economy how true is that? |
#30 |
Hi thanks for your reply , why are you saying to stop gauging fuel consumption from the dash meter? which other way would you do to know how many litres are being used for a certain amount of kilometers by not using the fuel gauge?
#31 | |
Drives: 2005 Toyota Camry
My dash says I get over 30MPG. My Fuelly says otherwise, currently around 25MPG combined after I put on 18" wheels with larger rolling resistance. Keep in mind the dash gauge is estimating your mileage based on ECU conditions such as throttle position, O2 readings, knock/timing, etc. It will never actually be close to what you'd get in real world conditions, unless what you drive on daily is exactly what the computer fuel consumption map is like programmed from the factory. -alex |
#32 | |
Maybe I should disconnect the battery and reset the ECU. It could also be the fuel on the tank it's not RON98 .. bein a lower octane. Honestly I'm out of ideas. what's your bestadvice? |
#33 |
Inexpensive fix:
Drive until cheap fuel is gone. Refill with higher octane. Disconnect battery overnight. Drive normally. Expensive fix: Pump your gas out. Refill with higher octane. Disconnect battery overnight. Drive normally. If your fuel consumption doesn't improve after 2 tanks, document it and take it to the dealer. -alex |
#34 |
Drives: Scion FRS Ht Lva(AT)
Dssence
I would suggest the following: 1) the computer in the car makes changes to the timing based on many parameters. The reason the lower octane fuel gives poorer fuel consumption is that the car's knock sensor retards the timing when it hears knock due to the lower octane fuel. Once you get higher octane fuel in the car this should help fuel consumption from this perspective. 2) in the owners manual there will be section that describes the dash buttons and the two that are used to reset the odometer, select the odometers, select the outside thermometer, the average fuel consumption display, the instantaneous fuel consumption display etc. Read this section, understand it and figure out what buttons to push to change the display value you see and how to reset those that are resettable. 3) the average fuel consumption dash readout tends to show a little better than real life calculating the fuel consumption from the km. driven and the fuel added. 4) you should read and record the average fuel consumption, at refill time and then reset the average fuel consumption readout to zero. This will tell you what the computer thinks is going on. Record the odometer mileage since the last refill to full(keeping in mind the instructions on the inside of the gas cap regarding how full full is). Add fuel, and use the fuel amount added and the km. since last refill to measure the real world fuel consumption. You can then compare that to the computer readout to see the difference. Do this for 2-3 tanks of fuel( go down to 1/4 to 1/8 left in the tank before fill up). 5) Driving Style: fuel consumption from a driving style perspective will be a function of when you shift up and down and how much throttle you use. You can see the impact of throttle and shifting by setting the dash readout to instantaneous fuel consumption. It will read blank when stopped and change as you drive with how you use the throttle and shift, but go back to no value when ever you stop the car. The average readout will always show a number greater than zero until you reset it to zero. That is one way to tell the difference between the two read outs in addition to the fact that the average fuel consumption readout screen says avg and L/100 km while the instantaneous readout just shows L/100 km on the screen. 6) you will see some very high instantaneous fuel consumption readings as you accelerate but lower values when cruising. The shorter the duration of higher values and the more time at low values will result in better fuel consumption. If you are seeing real world fuel consumption worse than the worst at the fuely website for this car then you may have a problem. If you are in the range shown there then you probably just need to work on your driving technique to improve to the better end. Try this for a few tanks of fuel and see what you learn about your car and fuel consumption. Just a suggestion. Please note that if you have the dash readout set to avg fuel consumption, your readout can show a higher value because the first thing you do after fill up is accelerate away which uses way more fuel (particularly if you are heavy on the throttle) than cruising on the highway. Over the time to next refill, the average should even out depending on the mix of city and highway driving. Remember the throttle is not an on/off switch! You are allowed to use less than full throttle to accelerate!! Cheers |
#35 | |
Hi thanks so much for such a compltete answer. Sorry I didn't answer but I had some personal problems. let me go bit by bit through all your help
![]() Quote:
#36 | |
Drives: '13 FRS - STX
It is difficult to analyze fuel consumption over a short interval, there are too many variables. |
#37 |
Hi honestly not that much, around 40km , with around 1/4 tank.. using AC. Some guy from toyota told me the car needs to be rolled at least around 100km for the ECU to properly adjust.
#38 |
There is a button on dash that is marked DSP. If you press it, each press should cycle through the options that include "out side temp", "avg L/100 km", and "L/100 km". if you press and hold when showing "avg L/100km" the average will be reset to zero. Suggest you read about it the owners manual!
Yes, using air conditioning a lot will lead to higher fuel consumption. I think you may just have a heavy foot. My automatic accelerates adequately with very little throttle application. You need to read the manual and drive the car to find out how it works. Yes it will be quite different than late 70's Celica that was probably carburetted. Come back after 2-3 tank fulls of experience. |
| Quick question about a dealer trading another dealer for the BRZ I want | Prog | BRZ First-Gen (2012+) — General Topics | 17 | 09-15-2013 03:03 PM |
| Dealer can't flash my ecu... | jm1681 | Issues | Warranty | Recalls / TSB | 16 | 09-05-2013 05:47 PM |
| Would you buy a car from a dealer that stuck a dealer (ad) plaque or sticker on cars? | HitTheGas | Off-Topic Lounge [WARNING: NO POLITICS] | 49 | 04-29-2013 03:37 PM |
| 100 octane race gas: 91 octane ratio? | GhostofAkina | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 02-08-2013 01:23 AM |
| Servicing my FR-S at Subaru dealer rather than Scion dealer | dnL | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 25 | 08-28-2012 07:25 AM |
