Old 12-31-2013, 04:48 PM   #477
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Any updates? Was thinking of ordering from these guys too. Just went to my dealership to get a quote on parts and some of them are no longer valid.
Old 01-01-2014, 05:48 AM   #478
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
That's normal....they're a little slow in updating the order status online, but soon you'll see the status change to "purchased at dealer".
Fizz is offline   Reply With Quote
The Following User Says Thank You to Fizz For This Useful Post:
chanomatik (01-01-2014)
Old 01-01-2014, 05:50 AM   #479
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Still easier and cheaper for me to get these online. Holding back for now since I have bigger projects.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 01-01-2014, 03:46 PM   #480
mush
mush's Avatar
cant wait to blackout some parts
submitted today
Old 01-08-2014, 12:40 AM   #481
mush
mush's Avatar
paid today
Old 01-08-2014, 07:42 AM   #482
speedrye
Drives: White
Yes, the automatic nanny switches fit a manual car just fine. Better yet, you only need to add two pins to the harness to use those buttons for something else. I'll use mine as switches for front lights. Snow will be for yellow fogs while Sport will be for front LEDs. Ignore the silver...
speedrye is offline   Reply With Quote
The Following User Says Thank You to speedrye For This Useful Post:
chanomatik (01-08-2014)
Old 01-08-2014, 01:15 PM   #483
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Dude sweet! I'm still debating on if I want that button. Is it firm, the "snow/sport" button? I had some weird idea that it might be flappy for some reason, no clue why.
I like the idea of hooking them up to something. I have a BRZ Limited, so my fog light switch is already there... any ideas on what else I could use that switch for? Possibilities might be endless. I have been considering fog lights with halo rings from Nigel-JDMParts, so maybe I could hook up the halos to that? Or maybe even the DRL leg strips on the front bumper above the fogs? Hmmm... Thanks for the inspiration!
Old 01-08-2014, 01:16 PM   #484
nyfries
Drives: 14 FRS Whiteout
Still no update with amayaya it's been almost a month since I got the email saying my order is "approved"
nyfries is offline   Reply With Quote
Old 01-08-2014, 02:34 PM   #485
speedrye
Drives: White
The buttons are decently firm, but they're only momentary buttons. To use them as an actual on/off button, you'll need to attach them to a latching relay. Basically you press the button and the relay leaves the lights on. Press the button again and the relay leaves the lights off.
These are the relays I usually use:
http://www.deiproducts.com/servlet/t...iswitch/Detail
Lots of options for what you want to hook to the switches at that point.
Below I've got pictures of the back of the stock 6MT switch (gray) and the Automatic switch (black). If you look at the pins on the upper right of the black switch, you'll see there are two extra pins. Those are the outputs from the two buttons. The bottom right pin is the input (I assume it's a 12v-, but I haven't gotten that far yet).
The extra pin on top is for the button on the top. The extra pin in the middle is for the button on the bottom.
The Following 3 Users Say Thank You to speedrye For This Useful Post:
chanomatik (01-08-2014), civicdrivr (01-08-2014), TM (04-14-2014)
Old 01-08-2014, 03:40 PM   #486
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
That's beautiful. Thank you!
Old 01-08-2014, 04:46 PM   #487
nalc
Drives: 13 BRZ Limited 6MT GBS
This is what it looks like inside, if you're curious. MT version, but it's the same PCB (you can see the two through-hole solder pads that have nothing attached - those are the two extra contacts that @speedrye is talking about.
nalc is offline   Reply With Quote
The Following User Says Thank You to nalc For This Useful Post:
TM (04-14-2014)
Old 01-08-2014, 05:00 PM   #488
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
I don't see why they wouldn't fit.
I think useless buttons are more stupid than a blank button though.
I swapped mine too. OCD kicked in and I couldn't stand the silver on black ring. Whats more useless is I have snow mode in a tropical country! Haha!
Tye300 is offline   Reply With Quote
Old 01-08-2014, 07:45 PM   #489
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Where did you get the TRD trim piece? Japanparts?
Old 01-08-2014, 08:12 PM   #490
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Two hundred dolla and it comes as part of a kit. Not bad. Cheaper than separate pieces from JPM and such. If you want JUST the trim piece I'll buy the leather pieces from you. The trim piece is nice, aluminum with black alumite finish.
are all control buttons illuminated? ron wright BRZ First-Gen (2012+) — General Topics 14 10-27-2015 09:44 PM
XXR527 Chromium black 18x8.75 Hankook Ventus 225-40 Black BRZ random hero Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 66 02-14-2013 01:20 AM
Oakley Halfjacket 2.0 Polished Black with Black Iridium lenses. Zadkiel Miscellaneous 8 12-02-2012 02:51 PM
Rear Seat Release Buttons NedVargar Issues | Warranty | Recalls / TSB 7 08-29-2012 02:43 PM
do you want steering wheel buttons? Spaceywilly BRZ First-Gen (2012+) — General Topics 125 04-09-2012 09:46 AM
