#477 |
Snow Don't Hurt!
Any updates? Was thinking of ordering from these guys too. Just went to my dealership to get a quote on parts and some of them are no longer valid.
#478 |
Senior Addict
Drives: 86 GT
That's normal....they're a little slow in updating the order status online, but soon you'll see the status change to "purchased at dealer".
| The Following User Says Thank You to Fizz For This Useful Post: | chanomatik (01-01-2014) |
#479 |
Snow Don't Hurt!
Still easier and cheaper for me to get these online. Holding back for now since I have bigger projects.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
#480 |
cant wait to blackout some parts
submitted today |
#481 |
paid today
#482 |
Drives: White
Yes, the automatic nanny switches fit a manual car just fine. Better yet, you only need to add two pins to the harness to use those buttons for something else. I'll use mine as switches for front lights. Snow will be for yellow fogs while Sport will be for front LEDs. Ignore the silver...
| The Following User Says Thank You to speedrye For This Useful Post: | chanomatik (01-08-2014) |
#483 |
Snow Don't Hurt!
Dude sweet! I'm still debating on if I want that button. Is it firm, the "snow/sport" button? I had some weird idea that it might be flappy for some reason, no clue why.
I like the idea of hooking them up to something. I have a BRZ Limited, so my fog light switch is already there... any ideas on what else I could use that switch for? Possibilities might be endless. I have been considering fog lights with halo rings from Nigel-JDMParts, so maybe I could hook up the halos to that? Or maybe even the DRL leg strips on the front bumper above the fogs? Hmmm... Thanks for the inspiration! |
#484 |
Drives: 14 FRS Whiteout
Still no update with amayaya it's been almost a month since I got the email saying my order is "approved"
#485 | |
Drives: White
These are the relays I usually use: http://www.deiproducts.com/servlet/t...iswitch/Detail Lots of options for what you want to hook to the switches at that point. Below I've got pictures of the back of the stock 6MT switch (gray) and the Automatic switch (black). If you look at the pins on the upper right of the black switch, you'll see there are two extra pins. Those are the outputs from the two buttons. The bottom right pin is the input (I assume it's a 12v-, but I haven't gotten that far yet). The extra pin on top is for the button on the top. The extra pin in the middle is for the button on the bottom. ![]()
| The Following 3 Users Say Thank You to speedrye For This Useful Post: |
#486 |
Snow Don't Hurt!
That's beautiful. Thank you!
#487 |
Drives: 13 BRZ Limited 6MT GBS
This is what it looks like inside, if you're curious. MT version, but it's the same PCB (you can see the two through-hole solder pads that have nothing attached - those are the two extra contacts that @speedrye is talking about.
| The Following User Says Thank You to nalc For This Useful Post: | TM (04-14-2014) |
#488 | |
Drives: Toyota 86 TRD Version AT
#489 |
Drives: Neptune GR86
Where did you get the TRD trim piece? Japanparts?
#490 |
Snow Don't Hurt!
Two hundred dolla and it comes as part of a kit. Not bad. Cheaper than separate pieces from JPM and such. If you want JUST the trim piece I'll buy the leather pieces from you. The trim piece is nice, aluminum with black alumite finish.
| are all control buttons illuminated? | ron wright | BRZ First-Gen (2012+) — General Topics | 14 | 10-27-2015 09:44 PM |
| XXR527 Chromium black 18x8.75 Hankook Ventus 225-40 Black BRZ | random hero | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 66 | 02-14-2013 01:20 AM |
| Oakley Halfjacket 2.0 Polished Black with Black Iridium lenses. | Zadkiel | Miscellaneous | 8 | 12-02-2012 02:51 PM |
| Rear Seat Release Buttons | NedVargar | Issues | Warranty | Recalls / TSB | 7 | 08-29-2012 02:43 PM |
| do you want steering wheel buttons? | Spaceywilly | BRZ First-Gen (2012+) — General Topics | 125 | 04-09-2012 09:46 AM |
