Old 12-29-2013, 03:29 PM   #757
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by PStaff716 View Post
this is probably one of the dumber questions in this thread but can I use a Mac with my oft? I am about to do the whole process but it seems like I need Windows.
Thanks.
At this time, you will not need ANY computer to use the OFT as it will come pre-loaded with maps for all different ROM types. Just plug it in and select what Stage map you want to run. But if you do want to modify the maps or download datalog files to your laptop, you will need to run Windows OS. Personally, I use a MacBook Pro running Windows through Parallels. Or you can run Windows through Bootcamp which comes with your Mac. Easy to do and probably more stable/better performing than running Windows through a PC
Shiv
Shiv@Openflash is offline   Reply With Quote
Old 12-29-2013, 03:42 PM   #758
Malt
Drives: 2015 WRX
Originally Posted by shiv@vishnu View Post
Judging by your datalog, I can almost assure you that you still have the leak. Calculated AFR is leaner than it should be with that map. Which suggest that there still might be air entering the exhaust system at the header flange/head connection. I'm sure you will see positive fuel trims ramping up with more driving time. The only solution to get your trims in order would be to fix your header once and for all (assuming you think it is still leaking).
Shiv
That is not good news
Would some residual E85 in the tank on fill when swapping from the E85 maps to a normal Stage 2 gasoline map cause a lean condition until the LTFT's adjusted for it? If so it doesn't look like they have moved from 0 during WOT yet. I'll drive some more today and log again tomorrow to see how much it adjusts. If the leak is still there I'll cough up the cash to get a shop to install them because if the leak is still there apparently I can't install headers correctly (or the flanges are warped).
Malt is offline   Reply With Quote
Old 12-29-2013, 03:50 PM   #759
Shiv@Openflash
Drives: 2013 FRS
If you have some residual E85 in there, it would certainly result in temporary leaner AFRs until LTFT kicked in and brought AFR to the target range. But it shouldn't take too long for things to get into the desire range.
Old 12-29-2013, 04:14 PM   #760
Malt
Drives: 2015 WRX
Ok, thanks. Just checked google maps. It had 8 miles on the reflash when I started logging and put another 8 on it during the log. Not sure if 16 miles is enough time for it to adjust but I'll check again tomorrow after I put ~50 on it tonight.
Old 12-29-2013, 06:16 PM   #761
Malt
Drives: 2015 WRX
Sigh... I think you are right shiv, but I'm going to at least run this tank out to make sure the higher ethanol content isn't causing all this weirdness. Is there anything else that would cause LTFT's to jump around? DI seals, Intake leaks, etc? Logs coming home from dinner look semi fine to me on the highway. LTFT is a tad high but stable. The one pull I did getting on the highway had AFR's in the low 12's this log.
http://www.datazap.me/u/malt/12-29-1...ing-3?1-2-9-11
Old 12-30-2013, 12:38 PM   #762
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
http://www.datazap.me/u/solidone/v14...-4-7-8-9-10-11
Here's a log I took from last night. From around 6000rps WOT LTFT climbs up to 14% and stays there till redline and goes down to 8% at idle, lower rpms and low load conditions. Doesn't look to be an vacuum or exhaust leak. AFR is lightly richer than target AFR's.
I had the Advance multiplier value go down to .0 from around .8 couple of times (not on the log). How much does the engine have to be knocking for that to happen?
Mods: afe drop-in filter, cut intake scoop, a catless J2 front pipe and v1.42 STG 1 OFT.
Old 12-30-2013, 10:24 PM   #763
horrorbiz
horrorbiz's Avatar
Drives: ‘22 BRZ Limited
This might be a stupid question.... but... I'm having a hell of time trying to update my OFT. This is my first time using Windows since the 90's... so that might be the issue. I'm on 8 and I ran the update for 8.1 and I believe I installed the patch. Anyway, when I connect the OFT and it searches for updates, it find one and then when I click okay to update it I get an "Updater" error. It says "Unhandled exception has occurred in your application...
yada yada... The process cannot access the file '.\\updater.exe' because it is being used by another process."
Any ideas?
horrorbiz is offline   Reply With Quote
Old 12-30-2013, 11:08 PM   #764
solidONE
solidONE's Avatar
Today's Log:
http://www.datazap.me/u/solidone/12-...?1-2-4-9-10-11
The LTFT at WOT and high RPMs had gone up as high as 16.41% today. Any ideas, Mr. Pathak? @shiv@vishnu?
Old 12-30-2013, 11:10 PM   #765
s2d4
s2d4's Avatar
Today's Log:
stage 1 with the catless pipe?
Old 12-30-2013, 11:13 PM   #766
Shiv@Openflash
Drives: 2013 FRS
Today's Log:
Shoot me an email at shiv@vishnutuning.com and I'll send you a new map that seems to sort out the high LTFTs that some cars are seeing. I'm out of the office this during the holidays but if you send me an email tonight, i can probably send you the revised map tonight as well.
Shiv
Old 12-30-2013, 11:16 PM   #767
solidONE
solidONE's Avatar
Yup catless J2 front pipe, aFe drop in filter, and trimmed snorkel. All else stock with a 1.42b stg 1 OFT tune.
I did keep a bit more material on the snorkel than shiv and others. Although I'm sure that's not going to change much.
Old 12-30-2013, 11:16 PM   #768
Shiv@Openflash
Drives: 2013 FRS
Any ideas?
Are you running the last version of OpenFlash Manager 1.04? It's be available for download for approx 2 weeks. If you are running an older version, just remove the version you have and reinstall the new version that can be downloaded from HERE.
Old 12-30-2013, 11:16 PM   #769
solidONE
solidONE's Avatar
Shiv
Sound good! Thanks shiv!
Old 12-31-2013, 01:03 AM   #770
s2d4
s2d4's Avatar
You can check the ignition timing against the base timing map + timing advance and see if it matches or higher then there is no knock.
I screwed this one up the first time around, but yeah, iam, fbkc and flkc would be nice.
Don't know why no one pulled me up on it. Guys, if I say the wrong thing, feel free to correct it.
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
