Old 12-29-2013, 12:43 AM   #183
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
I've only had the car for 9 weeks and the first 2 to 3 weeks I've experienced problems going into 1st or 2nd a few times but I just put it back to neutral and step on the clutch again and the shifter will go into the gate. By the 2nd month this problem completely went away and the tranny is much smoother. I still think this clutch has no feel tho, trying my best to get used to it.
krayzie is offline   Reply With Quote
Old 01-26-2014, 08:20 AM   #184
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
2nd session at the track and suddenly I have 4th gear synchro issues. It's a gentle grind/crunch so far.
Brand new Amsoil fluid, knob, short shifter, gearbox bushings, shifter springs, and clutch pedal adjustment
Put the clutch pedal back to stock height, hopefully today's sessions are better
F1point4 is offline   Reply With Quote
Old 01-26-2014, 09:50 AM   #185
Dipstik-sportech
Dipstik-sportech's Avatar
Sorry to say but that's how mine started. Then proceeded to change the fluid and found the synchro ball on the magnet. These trannys are shit
The Frozen North
Old 03-01-2014, 08:30 PM   #186
bryan767
bryan767's Avatar
Drives: 13' AVO Whiteout
I get a slight 2nd gear crunch at 14k miles. But that's ONLY if the car is cold. I have a feeling that if I replace the transmission oil, I will cure the problem - for me atleast.
These are the fluids you will want to look into:
-Amsoil Manual Synchromesh 75x90
-Motul Gear 300
-Redline 75w-90NS
Look into which one is right for you
INFO:
http://www.esotericperformance.com/blog/1/
http://www.ft86club.com/forums/poll....lts&pollid=234
bryan767 is offline   Reply With Quote
Old 03-01-2014, 08:43 PM   #187
SciOnDrifTtSlIdeR
Drifter
Send a message via MSN to SciOnDrifTtSlIdeR
Originally Posted by chulooz View Post
Don't, Do not, shift into first before the vehicle is completely stopped.
I hope this car doesnt start coming off as a shit bucket because of mistreatment, whether unknowingly or not.
i agree here why would any one downshift into first from second while the car is still in motion
SciOnDrifTtSlIdeR is offline   Reply With Quote
Old 03-02-2014, 01:30 AM   #188
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I do this at autoX somewhat often. From 3rd shoved back into 2nd is a lot more common. But literally sometimes a jam it into 1st and drop the clutch to really bind and rotate the rear end in a low speed situation. No I'll effects yet. 55k miles on the car also.
Old 03-02-2014, 03:39 AM   #189
SciOnDrifTtSlIdeR
Drifter
What fluids do you run in your trans? I come from the drift side of things... i also drive my car dd when we have snowless seasons here
Old 08-31-2014, 04:08 AM   #190
JamesBond000
First Class Speeder
Drives: Silent and Quick
I test drove a 2013 FR-S stock 3000 miles....The shifting Felt the same as my 2013 FR-S with 25k miles.... So maybe since it never drops below 30 F except for once in a blue moon in winter i should change the fluids to something else after some further research...
JamesBond000 is offline   Reply With Quote
Old 06-21-2016, 03:11 PM   #191
mirin_gains
Drives: 2011 civic
Is this still an issue? I'm looking at a 2014 model and it seems like there's less of these synchro and grinding posts, but it still has me worried
mirin_gains is offline   Reply With Quote
Old 06-21-2016, 05:27 PM   #192
wbradley
Sarcastic SOB
wbradley's Avatar
Yes if you take off cold you might have resistance going into 1 or 2 until the tranny fluid warms up. Nothing has changed in this regard and its not defective, just quirky.
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 08:07 PM
A problem with new rules in SCCA/NASA regarding FIA seats CyberFormula Other Vehicles & General Automotive Discussions 3 11-09-2011 10:13 AM
Help me track down my braking problem :( #87 Other Vehicles & General Automotive Discussions 32 09-26-2011 01:49 PM
