Drives: Asphalt grey, manual Fr-S
Winjet headlights fogging up?
Hey i just got my headlights installed and drove for an hour or so home and when i got home i noticed they had fog in them in the very front is this normal or are they defective?
#2 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
I'd say that's defective.
#4 |
Unemployed DIY Ninja
Drives: 2013 SWP BRZ, 1983 MB SD300
Made in China.
2013 SWP Subaru BRZ - Panda'd
FS: BNIB WORK 11R 17x9 +38 [Custom] 5x100 PCD [Custom] 56.1 Bore |
| The Following User Says Thank You to Perihelion For This Useful Post: | charged86 (12-29-2013) |
#5 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Probably nothing baking and a little bit of rtv won't fix.
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#6 |
Drives: Moped
I think most folks are going to discover they you are going to have to seal these headlights before installing them to avoid fogging...the price we pay for cheaper made in China stuff...
| The Following User Says Thank You to Lonewolf For This Useful Post: | suaveflooder (12-28-2013) |
#7 |
Talked with chris from phastrack and he said they should burn off after a few days of use so hopefully that works
#8 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
#9 |
Drives: Scion FR-S
Same happened to mine, it just takes a day or two and it will be gone. Haven't had any issues since
#10 |
Drives: Scion FR-S
It's cause you took the headlights out in the cold dry air and there was humid air still inside them. It will evaporate.
#11 |
I have ALWAYS sealed (usually with RTV) aftermarket headlights on all my cars. Seems that only OEM avoids the fog.
#12 |
Drives: 2013 Scion FR-S, Hot Lava
Any news on this? I just got mine installed and they fogged up instantly (in montreal at -17C.. ) Problem is that in this weather, the moisture just freezes after i turn off the lights, so it doesn't leave time for it to evaporate...
#13 |
Drift Specialist
Drives: 180SX,GT86
this is what i would expect from $400 subpar fakie cheap headlights
OEM or nothing.
| The Following User Says Thank You to GT86drifter For This Useful Post: | mush (02-17-2014) |
#14 |
thanks for the valuable response, i shall fix my headlights with OEM might! (sarcasm off)
I just want to fix these, cuz they look much more sexy than OEM, the light better than OEM, and if the moisture is fixed, they seem to be of good enough quality
| The Following User Says Thank You to Ongor For This Useful Post: | GT86drifter (02-17-2014) |
| Winjet Headlights (Post Your Pics) | ecko04 | Cosmetic Modification (Interior/Exterior/Lighting) | 265 | 03-20-2021 08:53 AM |
| Winjet Headlights and HIDs | HakunaMiata | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 07-18-2017 10:24 PM |
| New Winjet Headlights LED FLICKER?! | Jeremehh | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 03-08-2016 03:26 PM |
| Custom Purple Winjet and Black Winjet Headlights | xclusive_brett | Cosmetic Modification (Interior/Exterior/Lighting) | 35 | 12-17-2013 08:28 AM |
| Norcal GB: Winjet JDM Style Headlights | 86_ZN6 | Northern California | 2 | 12-11-2013 03:31 PM |
