#15 |
Drives: 2013 silver FRS
Is it normal to feel the rear end at 1st gear speeds fight itself a little?
#16 |
Drives: Subaru BRZ Sport Tech Satin White
#17 | |
It's not an LSD because it doesn't limit slip. It is an ATB because it biases torque. The difference is fundamental and important. For a lengthy period of time the Achilles heel of Audi's much vaunted Quattro drive was the Torsen center diff. Guess what, they don't use it anymore because of its limitations. Torsen themselves make a hybrid ATB that is also an LSD, they fit a clutchpack as got a true LSD. |
| The Following User Says Thank You to Suberman For This Useful Post: | Bristecom (12-23-2013) |
#18 |
#19 | |
The ratio of torque transfer capability is the bias ratio of the ATB. The one fitted to the BRZ is a 4:1 bias ratio which is very high. 5:1 is about the maximum feasible for a road car. 4:1 means that up to four times the torque driving the lower grip wheel can be transferred to the other wheel. In winter or in the wet this rarely exists so the actual drive effects can be disconcerting. A lower bias ratio is usually fitted for a winter application. 4:1 works better in dry conditions and with an excess of torque such as on the Mustang GT. It mimics a LSD only if each wheel has some grip otherwise it acts as the open differential it is. A clutch type LSD absorbs engine torque that would otherwise spin the lower friction drive wheel. An LSD does not transfer any torque, it absorbs engine energy and creates a lot of heat until it locks up. A viscous coupling also wastes engine torque generating heat which increases the viscosity of silicone based fluid in the coupling (silicone increases viscosity with added heat). A viscous coupling works like a torque converter but with its operating fluid changing viscosity with the relative motion of the stator and impeller vanes. Subaru also uses this type in their other models. Both of these devices essentially brake the spinning wheel against the wheel with more grip. That's why these have largely been abandoned in favour of ABS based traction control which actually uses the wheel brake to perform the braking function of a clutchpack LSD of viscous coupling. Even awd systems generally only have a LSD transfer case (centre diff) and rely on the traction control to control wheelspin across the axle. An ATB is not a LSD it is an open diff. Now you don't need to google Torsen. Last edited by Suberman; 12-22-2013 at 07:54 PM. |
| The Following 8 Users Say Thank You to Suberman For This Useful Post: | 6speed_Sam (12-23-2013), Bristecom (12-23-2013), CarzCarzCarz (08-22-2017), DAEMANO (12-23-2013), humfrz (12-22-2013), Manic (12-23-2013), notout86 (09-09-2017), red bread (12-23-2013) |
#20 |
Drives: UM86 - 6MT
Ha, what are you saying 'No' to? bad grammar is no bueno... :/
#21 |
#22 | |
Drives: Black Panda BRZ
What does the slip in lsd refer to? I presumed it meant the wheel with least grip. If so, the torsen is an lsd isn't it?
#23 | |
Drives: 2013 FRS, 2008 R32
#24 |
Drives: 2018 Golf R
This made me laugh in the middle of a meeting. Thanks, now everyone knows I'm not paying attention.
Parting out HERE
#25 | |||||||||||
Drives: '23 BRZ
It comes down to semantics, but for me, no, it is a limited slip differential.
| The Following User Says Thank You to ZDan For This Useful Post: | rice_classic (12-23-2013) |
#26 |
How does it limit slip if it won't stop the wheel spinning on ice?
If it is an LSD how come Torsen built the T3 which incorporates a clutchpack to limit wheelspin? It's not semantics. The difference is real and can be objectively described. Put simply, the Torsen accelerates the wheel with more grip. The LSD decelerates the spinning wheel. That's quite a difference. The two systems also produce very different driving feel as I'm learning rapidly in my current severe winter conditions. I will concede that I am unsure about the one wheel spinning as I cannot observe that and drive at the same time. Also, I'm not sure the BRZ lets you switch off the traction control completely with the console buttons. In theory, the Torsen ought to spin only the one wheel if the torque bias is exceeded. Whether that actually occurs with both wheels on the ground in reality I don't know. Certainly at the limit it does, zero torque on one wheel. That alone demonstrates that the Torsen is an open differential. The remainder of your post is just inaccurate and describes all the common misconceptions about the way a mechanical LSD operates. No torque is transferred by the clutchpack. Are you saying that the ABS type do absorb torque but the clutch do not? That's rhetorical. Both the ABS and clutchpack "LSD" operate in exactly the same way, by braking the spinning wheel. Clutchpack LSD wear out as do the brake pads on ABS types. Torsen retain full effectiveness for the life of the car. They do not wear out. Last edited by Suberman; 12-23-2013 at 10:57 AM. |
#27 |
#28 | |||||||||
Drives: '23 BRZ
In my experience with the Torsen diffs in my S2000 and RX-7, they do all that they possibly can to limit wheelspin by ensuring that both wheels get maximum possible torque before both spin together. No differential can do more than this. There is only so much total tractive force available, if you need more than that to move the car, it doesn't matter what you have for a diff, you're spinning. Quote:
If there is ONE case where it doesn't limit slip, it still DOES limit slip for its primary design mission: performance driving on the street/autoX/track. Still a limited slip, just like a Salisbury ramp-type clutch diff is *still* a limited slip with zero breakaway torque (which would cause it to behave the same way with one wheel on a no-grip surface and one on a grippy surface, would spin one wheel). Quote:
[edit]Somehow misread "ABStype" as "torque-biasing"... Revised answer: YES. ABS antilock brake virtual "limited slips" DO "absorb" the torque into the braking system, whereas clutch-type LSD transfers that torque back to the other drive wheel. Quote:
Same with the Torsen, only the torque path isn't a clutchpack but the helical gears connecting the side gears. It is still ultimately frictional and also generates heat, but BOTH are still transmitting torque from the no-grip side to the side with grip. Quote:
Torsen will have wear, as there is a TON of friction on the helical gears. In fact, Torsens create more heat than most clutch types. There was a batch of T2Rs that wore out prematurely, but they seem to have that issue fixed now. But with proper metallurgy, most seem to last a very long time, effectively forever (afaik). Last edited by ZDan; 12-23-2013 at 01:37 PM. |
| Mod that I never thought I'd want: a horn | mike_ekim1024 | Scion FR-S / Toyota 86 GT86 General Forum | 46 | 02-03-2014 12:18 PM |
| Not a BRZ or FRS just thought i would share | wrohdejr | Northwest | 6 | 03-25-2013 01:19 PM |
| You thought Pizza Hut was bad. | Carbon420 | Scion FR-S / Toyota 86 GT86 General Forum | 50 | 02-27-2013 10:49 AM |
| Anybody thought about these? | Memphis | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 08-13-2012 03:01 PM |
| Thought this was cool! so i had to get it! | 86design | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 6 | 07-17-2012 10:11 PM |
