#6497 | |
If your actually interested in doing something I wouldn't have a problem working with you again John |
| The Following User Says Thank You to Visconti For This Useful Post: | Sportsguy83 (12-18-2013) |
#6498 | |
Drives: 2020 DGM BRZ Limited
Sent from my SGH-M919 using Tapatalk |
| The Following User Says Thank You to mikalem For This Useful Post: | Sportsguy83 (12-18-2013) |
#6499 | |
Boosted
Drives: Not a supra....yet
By different everything do you mean a different sensor / hardware ? Maybe the new zetronix line ? Sent from my IBrick
#6500 |
#6501 | |
@mad_sb @jamesm @Td-d @vgi |
#6502 | |
https://www.dropbox.com/s/14q9dardy5...Multiplier.png
#6503 |
that's not correct. i found that to behave weirdly in my experimentation with it though. even with the increment amount set at 0 (as stock) the iam can definitely go up and down. changing it does effect the step size though.
the easy way to disable the iam is to ensure that the current applied advance value is never greater than 3.9 degrees, as this is one of the conditions to entering rough correction mode. of course this can be accomplished by stuffing timing in the base map and reducing values in the advance map to achieve the same total timing. it is widely accepted that this is a bad idea, at least from what i've read. |
#6504 | |
btw
I will have a tune update available Friday for all roms. Quote:
How much did you see the IAM changing with the default values? |
| The Following User Says Thank You to Visconti For This Useful Post: | cuddefred (12-19-2013) |
#6505 |
in increments as low as 0.02 was the smallest i've seen. it could actually be smaller and be stepping through the other values without me seeing it though, as i don't poll the iam often.
#6507 |
Drives: Black 86 GT
#6508 |
Drives: Black 86 GT
John, with the new stuff approach from Ecutek is there any chance that we will get to see the ECU remembering the last map we used. This would be really good if it could be done.
Glad to see you back on here and just remember to try and play nice with the others cos some of us miss you
#6509 | |
Drives: Toyota GT86
And yes John. Please play nice! |
| The Following 5 Users Say Thank You to EcuTek For This Useful Post: | cobrabyte (12-19-2013), cuddefred (12-19-2013), RedAlert (12-20-2013), Sportsguy83 (12-19-2013), Yruyur (12-19-2013) |
#6510 | |
Thanks! Phil at EcuTek said there's a few more things he wants to try out in regards to the map switching. It's been a while since he's looked at it but we both agreed that a fresh look at the problem is all that's really needed, he's pretty sure he'll get it sorted. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to Visconti For This Useful Post: | cuddefred (12-20-2013) |
| LED Front Signals with Resistor Flash Correctors | DarrenDriven | Cosmetic Modification (Interior/Exterior/Lighting) | 38 | 09-20-2012 03:05 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 11:09 PM |
| How to embed a flash gallery? | DarrenDriven | Site Announcements / Questions / Issues | 2 | 04-24-2012 08:43 PM |
| Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors | blur | BRZ First-Gen (2012+) — General Topics | 130 | 09-01-2011 02:42 PM |
