go_a_way1, MisterSheep
Old 12-15-2013, 01:41 AM   #4593
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Originally Posted by bkblitzed View Post
best way to know is to just take the wheel off, put soapy water all over it and look for bubbles
I really hope it doesn't come to that this early. I'm barely at 33X miles lol. I hope it's the weather fluctuation.
Old 12-15-2013, 02:56 AM   #4594
ronnBOi720
Asphalt FR-s
ronnBOi720's Avatar
Went from Spyder back to stock tail lights.
Old 12-15-2013, 03:11 AM   #4595
ronnBOi720
Asphalt FR-s
ronnBOi720's Avatar
Very excited for these! X)
Old 12-15-2013, 03:22 AM   #4596
Originally Posted by N1rve View Post
Today I added air into my tires again. They were back down to 28 PSI.
I just had a tire shop top them off just last week or so.
Has it turned cooler .. ??
Maybe the tire shop didn't put in 30 (or whatever) psi .. ??
(or they were warm when they added air and cold when you checked it ..??)
Maybe your tire gauge isn't accurate .. ??
I doubt it's a slow leak if all 4 tires are reading "low"....
Old 12-15-2013, 03:41 AM   #4597
N1rve
N1rve's Avatar
My car's been sitting in a fairly warm garage so I can rule out the outside temperature.
The tire shop has a digital air pump, I saw the tech put in 37 PSI on the screen. (Super High Tech Air pump Machine), to compensate for heat.
Maybe the computer is wrong?
The first time my tires needed air, the tire pressure light went off. I checked it with my gauge and it was at about 28PSI (Can't recall exactly).
My tire shop said my tires were at 29/30 PSI (because I drove it), so I guess I can say my gauge is pretty close to accurate. I probably should of checked their after work to see if it was really at 35 PSI, but the light went off so I just disregarded it.
Today it was at 28 PSI too, but no light.... Air Gremlins
Old 12-15-2013, 04:02 AM   #4598
.... Air Gremlins
Could be .....
I would suggest that you remove the valve caps and place a bit of "spit" over the valve stem on each tire ..... see if it holds the surface tension across the gap. If it doesn't, either the valve is leaking .... or you have been drinking too damn much ....
Next check and bring all tires up to the desired pressure (35 psi). Check the pressures after several hours with the SAME air pressure gauge and after the car has been at rest.
If they ALL still lose air ...... either a family member is messen with you OR the air molecules are escaping via small leaks.
If that's the case, get out the kids swimming pool, fill with water, submerge each tire and look for the bubbles.
If you don't see any bubbles and the air keeps escaping, your housing may have been built on an Indian burial ground .... sell your car and move out of state.......
Keep us posted ....
Old 12-15-2013, 04:40 AM   #4599
N1rve
N1rve's Avatar
Could be .....
Keep us posted ....
Will do Captain
Might need to call ghost busters if thats the case...
The Following User Says Thank You to N1rve For This Useful Post:
humfrz (12-15-2013)
Old 12-15-2013, 04:48 AM   #4600
hotpanda1
hotpanda1's Avatar
Drives: 2013 scion FRS
ordered the FT-86 rear diffuser hole cover thingy
hotpanda1 is offline   Reply With Quote
The Following 2 Users Say Thank You to hotpanda1 For This Useful Post:
JustBoostin (12-15-2013), OICU812 (12-16-2013)
Old 12-15-2013, 05:11 AM   #4601
ronnBOi720
Asphalt FR-s
ronnBOi720's Avatar
The wife hooking up @kaiju86 with a little photoshoot. Def some great pictures! Thanks love!
Old 12-15-2013, 03:32 PM   #4602
TRDBen
TRDBen's Avatar
Drives: 2013 FRS Asphalt MT
Threw on a set of Bridgestone Pole Position S-04's. Love em so far. And signed up for the Extreme Speed track day at Willow on 2/1.
Speeding doesn't kill you, suddenly becoming stationary, that's what gets you.
TRDBen is offline   Reply With Quote
The Following User Says Thank You to TRDBen For This Useful Post:
ronnBOi720 (12-15-2013)
Old 12-15-2013, 11:24 PM   #4603
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
Gave her a nice little wash :-)
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 12-15-2013, 11:43 PM   #4604
N1rve
N1rve's Avatar
Rechecked tire pressure today, holding steady for tonight! But today was fairly warm in Southern California, about 75 to 79 today.
humfrz (12-16-2013)
Old 12-16-2013, 12:28 AM   #4605
kanundrum
Drives: 2013 Whiteout FR-S
Getting my Winters ready. They had some Curb Rash from a pothole so I did some DIY wheel repair
Old 12-16-2013, 12:29 AM   #4606
Tfrase
Tfrase's Avatar
Drives: 2013 FR-S Series 10
Gave her bath #1 and got it all shined up! Too bad the light wasn't very good ....
Also, I noticed when wiping down the back rims that there are two holes in the rear wheel well edge that look like they should have plastic rivets. Is this just a placeholder for mud flaps or is something missing? Tempted to go by the dealer and see if it's standard... both sides have the same two holes.
Tfrase is offline   Reply With Quote
