Old 12-05-2013, 08:38 PM   #295
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by jsimon7777 View Post
So I pulled the stock ROM with Ecuflash. No problems. My car has the ZA1JA01C ROM from the factory. However, Ecuflash has no definitions for the file.
Then I open the openflash ZA1JA01C ROM. No definitions. Wants me to develop them. No go.
Then I open the ZA1JA00C rom. It says the checksum needs to be corrected. My understanding is that correcting this then flashing is what bricked Skullworks's car.
Questions then.
Can I flash the ZA1JA00C rom?
Should I modify the definitions file in some way to get the ZA1JA01C rom to flash? I believe they're the same ROM with a slightly different name. Or perhaps I'm adding the wrong ecu defs somehow. I don't think I am, though.
Should I fix the checksum? My understanding is a big NO.
Thanks! My intention is to make a guide for this to make it easier for others.
@Td-d @mad_sb @jamesm
The Following User Says Thank You to Sportsguy83 For This Useful Post:
EAGLE5 (12-05-2013)
Old 12-05-2013, 10:06 PM   #296
ztan
Drives: Toyota 86
Questions then.
Make a copy of the A00 .xml definitions file and change any A00 to A01 in the <romid> section
If you open a ROM file which has been checksum corrected by RomRaider in EcuFlash, it will sometimes tell you the checksum is incorrect. RomRaider adds some date data at the end of the checksum block (view in a Hex editor) when it corrects a checksum. If you reset the date data all to FF, EcuFlash then is happy with the checksum.
ztan is offline   Reply With Quote
The Following User Says Thank You to ztan For This Useful Post:
EAGLE5 (12-05-2013)
Old 12-06-2013, 02:14 AM   #297
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
The definition are available, not need to recreate:
Romraider: https://raw.github.com/TD-D/SubaruDe...R_ZA1JA01C.xml
Ecuflash: https://raw.github.com/TD-D/SubaruDe...Z/ZA1JA01C.xml
Td-d is offline   Reply With Quote
The Following 2 Users Say Thank You to Td-d For This Useful Post:
EAGLE5 (12-06-2013), Sportsguy83 (12-06-2013)
Old 12-06-2013, 02:59 AM   #298
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Wow, thanks! The last question is, should I correct the ROM checksum in ROM Raider or EcuFlash or neither before flashing it to the car?
Oh yeah, and it's odd that the 00C definitions are like 622K ut the 01C is only like 44K. Am I missing something?
Old 12-06-2013, 03:30 AM   #299
Td-d
I would correct it in Romraider - the only difference is the time stamp as mentioned.
The difference in the size is that the 44kb definition bundled is actually for Ecuflash (which are much smaller) - not RR, hence it did not work.
The Following User Says Thank You to Td-d For This Useful Post:
EAGLE5 (12-06-2013)
Old 12-06-2013, 05:31 AM   #300
EAGLE5
Dismember
EAGLE5's Avatar
Success and failure
I have attached a log showing my success and failure. Here is my outline of it. I am running XP with a Tactrix 2.0 Rev E:
1. Stock ROM - ECUFlash successfully downloads the ROM into memory.
2. Open Vishnu's Stg 1 tune in ROM Raider. Save as to give new checksum.
3. Write ROM to car. Gets an error at the end of writing:
[00:40:52.330] checksum routine start refused.
[00:40:52.330] interface close
4. Try to read ROM:
[00:41:15.794] OBDII communications failed - trying OEM bootloader...
[00:41:15.824] OEM bootloader communications failed.
[00:41:15.834] interface close
5. Power off car. Power on. Try again. Same error.
6. Start engine. Works great. Amazing tuning, Shiv! Freaking amazing. When you hit 4k rpm, VTEC kicks in, yo! So I drive around. Car works great. Come back to garage.
7. Try to write stock ROM that is still loaded in ECU Flash. Get an error:
[01:10:15.064] writing area 00008000-0013FEFF...
[01:11:50.261] J2534 error [ERR_TIMEOUT].
[01:11:50.261] download transfer failure at address 0012EF00.
[01:11:50.271] interface close
8. Shut off car. Turn back on. Try to start engine. NOTHING. Oh dear.
9. Reflash Stg 1 tune. Get same error:
[01:15:42.655] checksum routine start refused.
10. Shut off. Turn on. Engine starts.
So I have Shiv's tune installed and running. However, I cannot read the ROM nor go back to stock. Ideas?
Thanks!
Old 12-06-2013, 07:40 AM   #301
Td-d
Hmm... I suggest you give MikeyPSF a shout (on the RR forum via PM or email) so that you can get the beta version that Colby organised for Skullworks, I'm sure that will sort it out.
Old 12-06-2013, 09:03 AM   #302
Td-d
I've also just thought of something - when you say you have Shiv's tune on there, did you copy the maps across to the stock rom that you pulled over from Ecuflash from Shiv's rom, or just use the OFT rom? You must remember that whilst the OFTtunes are out in the open, the OFT is not open source - I believe that the OFT is locked to one vehicle (through VIN verification of some sorts I would expect), so there is obviously some custom code that has been inserted to undertake this. Perhaps this is what is causing the issue - Rombinhood@OpenFlash, perhaps you can clarify?
Old 12-06-2013, 11:39 AM   #303
EAGLE5
Dismember
EAGLE5's Avatar
I did try the OFT ROM directly. It's all new and crazy, is it not? It is not locked down to a specific car, apparently, because it did work so far, but there is some sort of incompatibility. I have not had a chance to play with it as I did try to get some sleep. Probably Sunday or Monday I'll explore more.
Old 12-06-2013, 01:44 PM   #304
SkullWorks
Drives: SSM LT MT BRZ
4. Try to read ROM:
Thanks!
This is strange...
I will attempt to read my ECU afterwork today. I am currently running Shiv's OFT E85 map on my car,
I have had success flashing and running the car with and without letting ECUflash correct the checksum error.
This is the same errors I was getting that left me immobile for weeks, but it would give this error regardless of what I tried to flash, Stock, OFT stage 1, made no difference. I still get this error on occasion, but it wll retry several times now before terminating the flash...It has completely failed to flash 2X but subsequent attempts have allowed success...let me tell you, there was severe pucker factor while parked at McDonalds uploading E85 maps for the first time...and I kept getting failures...I was wigging out bad, then i got a clean flash and all was unicorns and pixie dust and stuff...
The Following User Says Thank You to SkullWorks For This Useful Post:
EAGLE5 (12-06-2013)
Old 12-06-2013, 01:48 PM   #305
SkullWorks
I expected this to be feature of the hardware, recognizing the Vin of the vehicle...I'm not sure I understand why the Rom would need to be different, I didn't see any instruction in the OFT threads about needing to copy the maps over to the factory image, Just that the factory image is stored in the device until it is "unmarried"
EAGLE5 (12-06-2013)
Old 12-06-2013, 02:12 PM   #306
EAGLE5
Dismember
EAGLE5's Avatar
Do you fix any checksums before flashing? Which program? Did you use the romraider provided defs for romraider or the vishnu supplied defs?
Originally Posted by SkullWorks View Post
This is strange...
Old 12-06-2013, 02:29 PM   #307
Td-d
Skullworks - maybe send jsimon7777 the beta version of Ecuflash that Colby sorted you out with, see if that helps?
EAGLE5 (12-06-2013)
Old 12-06-2013, 04:10 PM   #308
ztan
Drives: Toyota 86
I agree this is likely to be the problem - when using the OFT, the checksum correction + anything else needing to be corrected gets processed by the OFT or OFT manager.
For my successful flashing, I was using EcuFlash brzBeta 1.44.3948, changes to my stock ROM made in TunerPro and RomRaider, checksum corrected in RomRaider, date stamp removed in Hex editor (so EcuFlash woudn't bother me), and written with EcuFlash.
Close iJason Member's Car Journals 1 08-04-2013 09:26 PM
Close pche Engine, Exhaust, Bolt-Ons 3 08-04-2013 03:04 AM
Sorry. please close. finch1750 Scion FR-S / Toyota 86 GT86 General Forum 1 07-31-2013 02:00 AM
please close abutterman Wheels and Tires 0 07-05-2013 10:40 AM
