#253 | |
Drives: 2013 SWP BRZ
That being said, it is also very track dependent. Sometimes the dry line is where the track will dry first or quickest, or have the least number of puddles in the rain, so some people will stick to the dry line. No sense in running off the dry line if you are going to be encountering huge pools and puddles causing you to hydroplane. Also watch out for painted surfaces! They become super slick in the wet, especially the tracks that have a wide, painted area at start/finish - lift over that area. I've seen the lowest HP cars go into the wall across some start finishes at Sebring in the rain, simply because they have their foot in it across the painted surface.
2013 SWP BRZ Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781 |
#254 | |
Drives: Nevermorange FRS
But when it rains, I'll often drive off line, there's usually a bunch more traction because it's a part of the track that has less rubber and oil on it. If you watched the Formula 1 practice and qualifying sessions from the last race at Brazil you would have seen the F1 drivers doing exactly this the whole time. Going through the corners way off the line because there's a bunch more traction "out there".
PRO86 | WTCC | STL
#255 |
There are now 2 carseats!
Drives: 2013 DGM BRZ
I have my first track day coming up (birthday present from a friend who has been trying to get me to go for a while).
I have autoxed off and on for about 5 years. The car is largely stock. I did buy RCE yellows (not installed) but might sell them off to buy brake stuff (pads/fluid). We are going to Streets of Willow (run in reverse). What do you recommend I do? Should I get something like Stoptech SP for just the front, both the front and the back. Deal with and learn from the experience of feeling fade in my first novice event? (Technically this is my second track day...I wrecked at the nurburgring in the wet in a full car...etc...etc) |
#256 | |
Stoptech pads are street pads; I wouldn't recommend them for track. You're gonna fade stock pads, so why would you get a slightly upgraded pad that you're still going to fade? To me, that seems like a waste of money. I'd recommend you start with Carbotech XP8 or Project Mu HC+800 as a starting point for the track. You won't fade either one with stock tires. Project Mu G-Four (brake fluid) should last you a long time as well. When are you going to SoWS? This Saturday? We have all of the items in stock so you can drop by and pick them up. |
#257 | |
#258 |
Drives: 128i
I currently have Ferodo DS2500 pads, stainless steel brake lines, and ATE super blue fluid. I happy with the braking, but they get smoking hot after a 30 minute session with 225/45R17 Michelin PSS tires. I'll be getting RS3s for next summer.
Do you think getting brake ducts would help much, or would I be better off biting the bullet and getting a big brake kit? Would you recommend the AP Sprint kit for NA or would that be overkill? My local track is 3 miles in length and has 20 turns. On the fastest straight, I hit 107 mph.
#259 | |
Thank you! |
#260 |
Also, I had forgotten how expensive pads can be.
(the miata and the m3 spoiled me) |
#261 |
Drives: Nuisance BRZ
I literally just finished my 1k mile break in and am going to buttonwillow this saturday. Going completely stock to see what the car likes (except its raining unfortunately). That being said, completely stock car, should there be anything to look out for/do before the track? I'm still on all factory oils also.
#262 | |
A BBK is a more effective measure than ducts, but also costs more. Ultimately, you want both. |
#263 | |
-Mike |
#264 | |
Drives: 128i
#265 | |
I'm going on the 28th to that event at SoW. The car has almost 3k on the clock. I will also be autocrossing it next weekend. Should I change the oil after the autox? After the track event? Before these?? |
#266 |
Drives: 2013 GBS BRZ (AT)
Oil and brake fluid would be a good idea for autocross!
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
