#43 | |
Drives: Attitude
Felt like I was riding on marshmallows. No rain, all sun and fun here...but bouncy as hell and actually affected steering a bit. Before any one says it - no, my alignment is NOT off. I should really check my tread depth to see if the proprietary outer compound has worn down and I should sell these. |
#44 |
Hail Magnet
I missed the name difference there, thanks for the catch. And that makes more sense. My friend was telling me that 90% of the time in the winter, I dont necessarily need the extra traction that I&S tires will give me. The i*cepts, from what I have been told, are a good compromise without either giving up too much of either aspect--winter traction or performance.
#45 |
Drives: FRS
might pick a cheap set up 16" rims, usually pretty dry but cold here (vancouver, bc). I do live at the bottom of a slight hill cul de sac type thing so if my car could get up the hill I would be impressed. So far i've got:
blizzak LM vs michelin x-ice 3 what else? |
#46 | |
Hail Magnet
| The Following User Says Thank You to HunterGreene For This Useful Post: | kidgogeta (12-05-2013) |
#47 | |
Drives: BRZ(sold), STI
That's even evident in Tirerack's ice rink tests, as poor as they are. I&S tires on average yield .16g under braking, whereas performance winter ~.14g. May not sound like much of a difference, but it'll lead to ~15% shorter braking distance. |
| The Following User Says Thank You to dsgerbc For This Useful Post: | HunterGreene (12-05-2013) |
#48 | |
If so - Hakka R2. If not - performance winter is a good choice. For the money, i*cepts are good. Michelin PA3/PA4 are good, but not sure what's that gonna cost in your size. |
#49 |
Drives: FRS
yes the hill freezes over, huge pain in the ass cause none of my neighbors ever try cleaning up just pack the snow down with their lifted trucks (which barely get up in the first place lol at mud tires in the snow). How are the hakka r2 in the dry weather?
#50 |
The best among top-line I&S rubber. A bit behind good performance winters, but those might not get you up a hill in a BRZ.
Get it in stock size and you'll have less of a floaty feeling. You won't need it to be narrow to 'cut' through deep snow. On a second thought, though, a set of performance winters and a several bags of salt to dump on the hill might be cheaper than R2s. Last edited by dsgerbc; 12-05-2013 at 08:13 PM. |
| The Following 2 Users Say Thank You to dsgerbc For This Useful Post: | HunterGreene (12-06-2013), kidgogeta (12-05-2013) |
#51 | |
Drives: Subaru BRZ Sport Tech Satin White
My BRZ is basically undrivable on the icy roads we have at the moment. However, it isn't tire grip because it stops just fine. Steering is nice and quick which allows you to catch the drift immediately but oh my goodness did Subaru ever screw up the back axle on this car. And they did this on purpose, apparently. Its a shame because it makes the car very slow. Others have experienced this on wet tracks also. It will also slow the car on dry tracks even though that may be less obvious. Hope somebody aftermarket designs a fix for this soon. I suspect the Torsen is a tad too tight and something odd is happening under squat. Since the car is more predictable and easier to drive, sort of, with the traction control off then I suspect it is the rear suspension which is to blame. The Torsen just makes it even twitchier. No wonder you can drop clutch drift this car on dry pavement with only 150 lb ft of torque to kick the ass end out. On ice you can do this if you sneeze. |
#52 | |
Drives: Black Panda BRZ
What cars are you comparing it to and what tyres are you running? I haven't had any other RWD cars *edit: except my miata!* so my experience is very limited with them, but my brz is certainly not undriveable and not much different to what I was expecting on ice and snow.
#53 | |
| The Following User Says Thank You to dsgerbc For This Useful Post: | SirBrass (12-05-2013) |
#54 | |
I know what I'm talking about. Used these same tires on three other vehicles. They all handled fine. This car does not handle fine. It's a shame if only because it could be such a good car, but isn't. |
#55 | |
#56 | |
Anytime you feel,like proving your point, go ahead. Otherwise your opinion about my opinions is merely "sound and fury signifying nothing." Last edited by Suberman; 12-06-2013 at 09:35 AM. |
| Tags |
| driver defective, part four in the series, suberman the great., terrible debater |
| Cheapest possible snow tires plz | Boofneenee | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 11-25-2013 03:45 PM |
| Snow Tires | Enemies | CANADA | 289 | 11-25-2013 10:35 AM |
| snow tires | debs0712 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 10-18-2012 12:58 PM |
| How effective are snow tires? | theredtape | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 06-18-2012 07:49 PM |
| Snow tires? | smbrm | CANADA | 12 | 05-27-2012 01:20 AM |
