#16 |
Drives: FRS
I'm having my warped seals replaced with my condensing taillight next week covered by warranty
#17 |
My drivers side window seal is cracked already :/. Gonna take it in next week
#18 |
Drives: 2013 DGM BRZ Ltd
Mine is warped, the drivers side window squeaks against the rubber when you close the door.
#19 |
Drives: Supercharged Golf Cart
The one on the front of the hood looks "warped" on all of the ones I've seen, brand new. Go look at some new ones next time you're at the dealership.
#20 |
Drives: Subaru BRZ Limited
Yup I noticed that too. And I just looked at pics from when I picked the car up new from the dealer, and I can see it then.
#21 |
My driver's side window seal has been gradually pulled out of it's seat. Most likely from not enough lubrication/rubber conditioner being applied. Regardless, it was out so far it was actually creating extra resistance on the window when it rolled up all the way (basically obstructing the path). No amount of lube/conditioner would have helped me it at that point
Not sure if it's related but the window started to malfunction. Could roll the window down but not up. Only the "auto close" function would close the window, but you'd have to hold it. Nothing worked while the door was open. Couldn't control the passenger side at all. I had the stealership "re-seat" the window seal and fix the window control issues. I assume the service guy didn't leave the window cracked to let the seal dry properly so needless to say it's much better but still not seated properly. Still rubs and I can see this problem happening again in the future TL;DR: Take care of the window seals. I can understand how failure to lubricate can cause it to be pulled out of it's seat, then causing extra resistance for the window when it rolls up all the way. Wish I had more info of what was done to fix it, the guy at the dealership wasn't able to answer any of the questions I asked. Luckily it was repaired under warranty, just relaying my experience because something stupid like this can burn a hole in your pocket if you aren't covered. |
#22 |
Drives: 1992 Nissan Skyline GTS-t Type-M
So these are a few of the pics I snapped when I first noticed this happening. About two months ago I had my windows tinted and it still kept happening so I decided to take it my dealer to have the seal replaced.
The rep told me that because I had my windows tinted that they would not cover it and that I'd have to have the tint removed and come back to show them. I showed him these pictures and he more or less said tough sh!t. "Well they're tinted now so it doesn't matter.." So heads up to anyone with tinted windows that they'll probably try to blame it on the tint and deny the claim. |
#23 | |
#24 |
Looks like I'm going to a different dealer then -_-
#25 | |
Drives: 2013 Scion FR-S (M/T)
Was this covered under the bumper to bumper warranty? Dammit I'm at 40k miles, ugh! Has anyone found some DIY fixes for this? My OCD causes me to hate this, it drives me insane each time I close my window. I noticed I just have to keep the strip clean and the window edge clean as well but it's really irritating. |
#26 | |
hey you, yeah you <3
Drives: 2014 37J FR-S
Also, I get water inside after light rains. I'll park it outside, and when I wake up the next day, I find drops and trickles of rain. It's like my car is sweating by itself during the night. ![]() @pooch To repair, just take to dealer. If you are unsure, email Toyota, then once they create a file/account for this issue, they'll tell you to take to dealer. At this point, just tell them which dealership you'll be taking it to and have them send the report info over. Less likely to be denied that way imo.
#27 | |
I had also since then been treating the strips with gummi pflege and it hasn't really returned. |
#28 | |
Drives: 2016 Oceanic, "base" model
Given this, AstroGlide (the water based formula, not the silicone based stuff) would seem better. After all, it was developed by NASA for its rocket motor gaskets... |
| UPDATE TRD Supercharger | greenguy101 | Forced Induction | 190 | 04-09-2015 10:38 AM |
| Mod Update.... | UM FRS | CANADA | 12 | 12-25-2012 01:50 PM |
| BESPOKE APP UPDATE OUT NOW | ML | Electronics | Audio | NAV | Infotainment | 13 | 10-12-2012 07:47 PM |
| Update and SEMA | TheChopShop | Forced Induction | 9 | 10-09-2012 03:25 PM |
| GT5 2.0 Update!... | MF_DEUCE | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 10-15-2011 02:53 PM |
