Old 11-25-2013, 09:17 PM   #603
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by FRS_Jack View Post
Hey guys,
My car is on 1.34b and it experiencing idle dip. When I'm on the break back down to zero the car's RPM will dip for a split second to 500 causing the car to jerk a little. Is this normal? Can I fix it? Do I have to reflash and bring into toyota.
I have stock air intake and evo 3 exhaust.
-J
That's normal from what I've seen. I don't think anyone will have a fix other than to raise your idle speed. With our OTS maps, idle targets are already 100rpm higher than stock.
Shiv@Openflash is offline   Reply With Quote
Old 11-25-2013, 10:46 PM   #604
FRS_Jack
Duel Canister 2X the Fun
FRS_Jack's Avatar
Drives: 2013 scion frs
Thank Shiv for the answer.... it happens once in a while not all the time.
FRS_Jack is offline   Reply With Quote
Old 11-25-2013, 11:57 PM   #605
Shiv@Openflash
Drives: 2013 FRS
Hi guys,
We just OFT tuned an FRS equipped with a TQ250 Phantom electric supercharger. Pretty darn good results. Check out our Facebook page
Old 11-26-2013, 12:03 AM   #606
sierra
Drives: Skoda Yeti DSG diesel 4x4
Originally Posted by shiv@vishnu View Post
Hi guys,
Any chance of posting it here for those of us that don't use Facebook?
sierra is offline   Reply With Quote
Old 11-26-2013, 12:53 AM   #607
DAEMANO
Time Traveller
Hi guys,
Incredible results on e85 with headroom for more (header, TQ300, etc.). DAYAM!
Old 11-26-2013, 04:38 AM   #608
TM
TM's Avatar
Drives: DGM BRZ 6MT
Hi guys,
Awesome! I've been following the electric supercharger thread and just purchased an OFT yesterday. Great to know that the phantom s/c will be supported once it is released.
TM is offline   Reply With Quote
Old 11-28-2013, 01:47 AM   #609
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Anyone running the OTS maps at 4500ft or higher elevation?
anyone have a basic tutorial for how to run the tuning software. i understand the mechanics of what does what on the engine and most if not all the parameters to watch but never could figure out ecuflash. hoping this will be better.
* just ordered the tablet and nameless DP about 5 minutes ago (Christmas for me)
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 11-28-2013, 04:16 AM   #610
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
I can suggest a potential fix - raising the overrun fueling RPM thresholds 100-200 RPMs higher - in other words, having the injectors kick back on from overrun fueling a tad earlier. Otherwise the idle stability tables can be used.
I don't think these are defined for the OFT yet, but they are in the Romraider definitions I put together:
The switch on is already quite high stock (1300 RPM, compared to an STI for example at 900), but worth a try.
Otherwise, I can take you through the idle stability tables.
Td-d is offline   Reply With Quote
Old 11-28-2013, 09:54 AM   #611
jamesm
+1 for the above. i was able to eliminate this issue (for the most part) in my tune by adjusting the idle stability tables. brzedit doesn't have half of the tables defined that romraider does or i'd try the overrun trick.
Old 11-28-2013, 10:34 AM   #612
Td-d
For everyone's edification, this is what the idle stability tables look like (the table is a MAP related modification to the targeted idle airflow):
I aim to please
I'll PM Shiv the relevant addresses so he can pass on to the programmers.
Old 11-28-2013, 12:26 PM   #613
Td-d
Can you add tables in BRZedit? If so I can just post up the addresses?
Old 11-28-2013, 01:09 PM   #614
brn12345
brn12345's Avatar
Just flashed the 1.34 stage one on my J rom and all I can say is I am very pleased. Much nicer to drive and the soft rev limit is cool. No more face in steering. Also the quicker warm up mapping is much appreciated. The early morning loud drone is much minimized. Thanks Shiv!!!!!!!!
brn12345 is offline   Reply With Quote
Old 11-28-2013, 02:34 PM   #615
jamesm
i wish. only the 'pro' version can edit the defs, i only have personal. personal doesn't seem to get any of the updates that the pro version gets either. would've been nice to know ahead of time...
i can't wait for logging on the open source side so i can switch back over.
Old 11-28-2013, 03:36 PM   #616
vgi
Drives: frs
so brzedit doesn't allow saving tune in bin format?
maybe you could do your tuning in RR and then load the tune in BRZEdit (diff and copy if needed from your current one whatever you missed)? I remember they posted that they made this feature (loading OFT tunes which is just a bin format) available for personal version?
vgi is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
